Question about Cell Phones
How do I turn silent mode off my SAMSUNG LINK. Pressing and holding # does not work.
How do I turn off the silent mode on a Uniden 6.0 dect phone, so it will ring?
For the Uniden model D1680 & similar...
You ENTER "Silent Mode" by pressing and
holding the [ # ] key on the handset for a few
seconds until the display reads "Please Wait".
It will (chirp) and display "Silent Mode ON".
You can EXIT "Silent Mode" by pressing and
It will (chirp) and display "Handset #".
Another easy way to end "Silent Mode" is to go
to the BASE and press the [ANS ON/OFF]
button to turn off the answering machine system.
(Push the [ans] button, do not unplug the power)
"Silent Mode" will clear a moment later while the
control voice tells you "Answering System is OFF"
Now you can again turn on the answering machine
system as desired.
Jun 13, 2016 | Uniden DECT 6.0 Cordless Telephone...
How do I turn off the silent mode so the phone will ring?
system as desired.
How do you turn off silent mode on Uniden DECT 6.0 cordless phone?
In standby mode pressing and holding # brings up the "Silent Mode" special feature .. unfortunately the only options are to set the time for the device to be in silent mode and no way to turn if off. The solution is supposedly to press the # key again and hold it down, but this does not work either. The only way I can manually return to not be in "Silent Mode" is to reset the base unit!!
Sep 26, 2011 | Uniden DECT 6.0 Cordless Phone ID
My son put my Samsung phone on silent mode and I can't figure out how to get it off silent mode.... Help? Please?
Depends upon you model number but most of the samsung phone tunn on/off to silent mode by pressing and holding # button lower right corner of the key pad. if it do not work then go the settings then sound setting then incoming call then alert type it would be settled at vibration or silent by moving navigational keys remove it and sett it and melody.
Jan 12, 2011 | Cell Phones
My samsng link is on silent mode. how do i take it off?
My Samsung Link SCH-r351 has a "Silent Mode". It took me about a day to figure this out.
To toggle *Silent Mode* on or off, press and hold the "Fn" key.
Sep 12, 2009 | Samsung SGH-D900 Cellular Phone
Samsung r210 silent mode on and cant turn it off.
Try either pressing the # key until it says 'normal mode' if this does not work go into settings - profiles - and then select normal. This should take it off silent.
Jun 04, 2009 | Samsung Cell Phones
How to turn silent mode off on a metro pcs slide phone
Press the # key and hold it down. This works with nearly all Samsung phones.
Apr 10, 2009 | Samsung Cell Phones
Silent mode been activated and cant turn it off
Press Down & hold the "#" key for few seconds. it will do the trick
Mar 23, 2009 | Samsung SGH-J600 Cellular Phone
SCH-R450 How to deactivate silent mode???
Keep holding down for 3 seconds the (#) Buttom. And it's fix.
Mar 17, 2009 | Samsung SGH-U600
Wont ring
Try pressing and holding the # key for a few seconds. This turns silent mode on and off with Samsung phones. If you're sure that silent mode is NOT on, and the phone still won't ring, you may need to seek getting the phone repaired. It could potentially be moisture that has gotten into the top 1/2 of the phone, shorting out the speaker, or the speaker could have just gone bad.
If you are sure silent mode is off, and want to seek repair, I recommend www.wirelessunlimitedinc.com, or www.myspace.com/wirelessunlimited.
Hope this helps. Please rate
Aug 03, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Cell Phones Logo
193 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
