Question about Pioneer GM-5200T Car Audio Amplifier
My light wont come on period.
I have a Lead (Hot) coming out of the Power and a Ground hooked straight to the battery and My amp wont even come on. Im gonna try it some other wayz but dunno other than to keep at it if U might know whats wrong Plz email me at ChaosDragon2424@yahoo.com. I did check the fuses and they are good. I have 16 Gauge wire for ground and a Solid terminal wire for my hot the hot is im guessing 8 gauge can anyone help me out with my problem plz email me at the address ill be on tomorrow.
  • 733 Answers
The remote needs to be plugged in as well. it should be next to the power/ground terminals. put 12volts on it. lights should come on. if not amp is faulty.
Posted on Sep 07, 2009
How should I hook up a 2000 watt schumacher inverter to a 12volt battery
i normally mount it under my seat run one lead straight to the positive (red) lead of battery with a 30 amp fuse using an inline fuse holder fully sealed.than the ground (black) using a ring connector to the chassis or seat mounting stud.must run positive under carpet and through fire wall using a grommet or other possible wire channels.
Aug 16, 2014 | Schumacher Electronics - Others
Simple on off sw with 2 leads to hook up to 12 v spotlight (in Boat 2 lead wires
Switch the ground on the switch to a fused hot wire from the battery and then from the switch to the spot light --ground the light. This will give you the spot light even if the power from the key switch is interrupted.
Most boat nav lights come from the aux or bat side of the key switch.
Aug 06, 2012 | Boating
1990 Corvette,s fan comes on when the key is turned but car wont start. THANK YOU !
Do the lights come on (dash)? Is the battery up? Is it in park? Try moving the gear selector through the neutral range while holding the key in the start position. If it cranks, the neutral safety switch is out of adjustment or going bad. If the dash lights go out when you hit start, the battery termanals need cleaned (baking soda & hot water & a brush). If the dash lights never come on, do you even have a battery and is it hooked up (including the ground strap between engine and frame)? Ray (garage owner)
Sep 20, 2010 | 1990 Chevrolet Corvette
1999 Oldsmobile Intrigue security light on/power only sometimes
first thing you need to do is unhook any wiring installation you did. It sounds as if you have running your power straight to ground. Somewhere you made a wrong connection.
You have also discharged your battery as part of connecting your power lead to ground.
Disconnect what wires you hooked up for the light system and then recharge the battery. Bill
Nov 23, 2008 | 1999 Oldsmobile Intrigue
Amp not turning on
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If neither is too low, the power supply in the amp is probably blown.
Nov 10, 2008 | Rockford Fosgate Punch 301M Car Audio...
No power to my amp
I'll assume that you've checked the amplifier's on-board fuses.
Jun 02, 2008 | SPL DK-2600D Car Audio Amplifier
Jensen Amp and Sub
If you followed the instructions correctly, then the amp must be defective. This is sort of simple.
My generic suggestions:
You have the power, the ground, the outputs to the speakers, and then the input.
Make sure that none of the speaker wires are somehow being grounded. Make sure that nothing is shorted that feeds the speakers.
Jerry G.
Apr 27, 2008 | Jensen A300HLX Car Audio Amplifier
Amp
Sisnce you didn't mention the protection LED, I'll assume it's not on.
You need to measure the voltage across the B+ and ground terminals of the amplifier to confirm that the voltage at the terminals is least 11 volts. Also check the voltage on the remote turn-on terminal. Place the black meter lead on the ground terminal of the amp and set the meter to DC volts.
Nov 07, 2007 | Power Acoustik LT-980/2 Car Audio...
Pioneer GM-5200T Car Audio Amplifier Logo
67 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
