Question about Janome Memory Craft 4000 Sewing Machine
Needle Threader is not lined up
Hi the automatic needle threader has never lined up for my machine and I have to thread manually. Anyone else have that problem?
  • 6 more comments
  • Superskater Feb 24, 2008
    Hi there thanks so much for your response. I cannot read the post so I'm posting back here. Hope to hear from you soon!
  • Anonymous Mar 12, 2014
    Needle Threader Hook
  • Anonymous Mar 24, 2014
    It will not thread
  • Anonymous Mar 25, 2014
    Auto threader part worm...cannot hook thread on.
  • Anonymous Mar 31, 2014
    How do you use the automatic Needle Threader on the Janome 2013 Sewing machine?
    how do i use the needle threader
  • Anonymous Apr 01, 2014
    My new Janome 8200 sewing machine will not thread the needle. What will cause this?
    My machine quit threading my needle. What can I do?
  • Janome Master
  • 1,388 Answers
This is called the Needle Threader Plate.
If this is too small for you to read, or you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
  • Hassy
    Hassy Feb 25, 2008
    Try these for the meantime, but if still too small, you will need to to go through the "Contact Us" page at www.bargainbox.com.au
    as I will need to email this page to you direct, .....there is a 150kb limit on fixya, and it just won't magnify well enough, even using (Ctrl and +) together.
    These instructions are for adjusting the Threader, and are from the Janome Service Manual for the MC 4000.....if it turns out that the tiny hook is broken, I have the Parts List too, so we can give a part number if required as well.
    Best Wishes
The automatic threader wont pick up and thread needle. Can do manually but thats not easy?
to make manual threading of a needle easy buy a needle threader
it is a instrument that has a very fine piece of wire in a loop that you push through the eye of the needle , put the thread in that loop and pull the loop back out of the eye and the needle is threaded
available from most any shop that sells material , cotton , thread or sewing machine shops
cost --pack of 2 for $1.00 or there abouts
Oct 05, 2016 | Sewing Machines
There's nothing wrong with the Threader, it's just that the Threader doesn't reach the back of the Needle!
Usually you have to manually move the needle up and down until its height matches the threader height. Newer machines have an automatic needle stop that generally matches the threader but most older machines need to be manually manipulated.
HINT: If you do need to manually thread your needle, lick your index finger and then rub the back of the needle's eye. Your thread will literally "leap" through the eye! This works for hand-sewing needles too!
Feb 03, 2016 | Singer 8763 Curvy
My automatic needle threader doesnt line up with the eye of the needle
possibly the wrong needle length then . have never needed one myself .
Sep 24, 2015 | Sewing Machines
I cannot get the CE-250 automatic needle threader to work. Threader and needle do not align up together.
Always make sure you rotate flywheel to raise the needle to its highest position before trying to use the threader. additionally the correct needle has to also be used so the threader wire and needle eye line up properly.
Cheers,
Embroidery Services
San Diego, CA
Sep 17, 2017 | Singer Sewing Machines
Automatic needle threader won't work on brother pe-770
Always make sure the hand wheel is at the exact top. Have you replaced the need recently? If it's bent, then the threader will not work. If the needle is loose or not all the way to the top in the holder, it will also cause the threader to not work.
Jan 06, 2013 | Brother PE770 Computerized Sewing Machine
I can not align my needle threaded on my Singer XL5000
Make sure your needle is fully seated and correctly inserted into your needle bar. Then make sure your needle is at it's lowest point before trying to use the threader.
Aug 18, 2012 | Singer Sewing Machines
Cant make the auto threader work on an elna 2007
Do you mean the auto needle threader?
Mine won't work on very small needle sizes so I resort to the old manual needle threader for these. Ditto for twin needles.
Otherwise its a case of pulling the auto threader down so the hook swings into the needle eye, then pulling the thread over the face of the needle and catching it into the hook, then release the threader so it pulls back through the needle eye, taking the thread with it.
The only other thing that springs to mind is "is the needle at the top position in its stich cycle so that the threader lines up with the needle eye?
hope these ideas help a little.
Dec 03, 2010 | Elna 2007 Mechanical Sewing Machine
AUTO THREADER CAME OUT
When you activated the threader, the needle was down and the threader came off or broke.
If it is not broken, you may be able to push it back into place.
Turn off the power and tip the machine back on some towels so it does not slip and with a flash light check the area where it fits and see if you can get it back into position.
If not, will have to thread the needle the old fashion way.
Check with your Brother dealer to see if they can look at the machine while you wait.
They may be able to get it back together or they will have to replace the threader.
It is possible they will have one in stock, or they may have to order it.
May 01, 2010 | Brother CS-8060 Computerized Sewing...
Automatic needle threader on brother se-350
Hi - first, make sure that you raise the needle to as far up as it will go. When you thread the machine, make sure you pass the thread through each number along the path - there is a hook on the threader mechanism that is really easy to miss. It is always a good idea to refer to the book when you are having a problem.
You might also try changing the needle. The threader has a teeny hook that goes in to the eye of the needle from behind, grabs the thread, and pulls it back thru the eye of the needle.
The threader can go out of alignment. If you got the machine last fall, it should still be under warranty. You can call Brother and ask where you can take the machine for repair. Or, you can go to Brother's website and look for information that might be helpful.
Good luck,
Ginny
Dec 21, 2008 | Brother XL-3500
Automatic Needle Threader Doesn't Work All The Time
Needle threaders are generally finicky things. Check to make sure the needle eye is at the correct height for the threader to connect. Gently pull down the threader and wiggle the handwheel slightly to get the needle eye where it needs to be. The threader may have been been bent or slightly rotated so it doesn't connect properly. Also, if you are not aware, a needle threader will usually not work on needles smaller than 80/12 because the eyes are too small.
Admittedly, a needle threader is a very nice function to have. If you find it will not work, there are some things you can do to make manual threading easier. One hint I found that works well is to lick your finger. Swipe it across the back of the needle eye. Then begin with the thread end immediately above the needle eye and gently slide it down to the eye. The needle usually has a tiny groove above the eye that helps guide the thread. The thread tends to jump right through.
Feb 13, 2018 | Necchi 3620 Quilter Mechanical Sewing...
Sewing Machines Logo
1,211 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
