Question about XFX GeForce FX 5500 Graphic Card
No signal on monitor
Have noc monitor which has been working for months. Had power cut when comp powered up again you could hear fans, lights flickered etc. Screen then said no signal and remains blank. Tried monitor on another comp works well. Do not have access to another floppy drive to make xp boot discs to retrieve drivers should this be the problem. As i mentioned the screen is blank from start to finish. Getting into bias etc is impossible, can't see anything. Have xp instillation disc but no use as i can't see screen to continue. I believe the rom is working as light flickers and cd spins. Any help with this would be much appreciated.
  • frizztku Sep 07, 2009
    Yes have tried another monitor and that also reads no signal.
    Thanx
  • 555 Answers
Do you have another monitor to test your computer? Looks like a surge went into the computer display and damaged the video card.
Posted on Sep 07, 2009
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
My monitor cannot pick up signal.
If your monitor displays No Signal, it means there is no video signal coming from the computer. Monitor is working fine.
It may just be the monitor cable. Do you have another one, or one you can borrow from another computer, for a test?
If a known, good, working, monitor cable yields the same results, the problem is your computer.
The computer isn't working.
The problem may be due to the power supply. Most of the time it is.
This statement is given because of,
A) Most of the computers that come to my shop, have this problem.
B) If you look on the internet, it is a common problem stated.
C) Most of the problems on here, are due to power supply issues with the computer.
You may see, or hear fans spin. Lights light, and it may sound like the harddrive is running.
Problem is, the processor doesn't have enough power to operate, so nothing is going to get done.
The main rating for power of a power supply is Watts.
Voltage times Amperage = Watts.
1) ALL the lights use less than 1 Watt
2) EACH fan uses 2 to 3 Watts
3) A typical Processor uses 55 to 125 Watts.
Depends on what processor it is.
The power supply has 3 main voltage power rails.
A) The 3.3 Volt rail
B) The 5 Volt rail
C) The 12 Volt rail
If the power supply develops a weak, or failed voltage rail, the Processor does not get enough power. Won't turn on.
Most of the time a power supply fails because it is dirty inside. (And the inside of the computer)
The simple solution is to unplug the computer from power, open the computer case, and use a can of compressed air for computers, on a regular basis.
Install the plastic 'straw' into the nozzle, and shoot air into the inside of the computer in rows.
Start at the top inside part of the computer, going from one side, towards the other side.
Then go down towards the bottom.
Tip the case slightly with one hand, and use the other hand to shoot air towards the bottom, to remove the remaining dust/dirt.
Shoot air into the power supply, from the back of the power supply through the ventilation holes. (Inside of computer)
Use a few Q-tips, and clean the fan blades, center hub, and surrounding cage, of the power supply fan, then use air. (Back of computer)
The rest of the time the fault lies in bad Electrolytic Capacitors inside the power supply.
CAUTION!!
NEVER open a computer power supply!
The Electrolytic Capacitors inside, hold a charge for Weeks, sometimes Months, after the power supply has been unhooked from power!
You can get shocked Badly, or even Fatally!
Best solution is to replace the power supply. If you have another working power supply, you could use it for a test.
[Be sure to work on a table. Be SURE to touch the metal frame of the computer case, (Case open),
BEFORE you reach inside!
(Computer UNPLUGGED from power)
Your body carried Static electricity. Static can fry out computer hardware components, in a New York second!
Computer unplugged from power you're safe.
Touch the metal frame before reaching inside, the computer is safe.
If you get up for any reason, leave, then return, touch the metal frame again!]
Jan 03, 2010 | HP L1706 17" LCD Monitor
Binking blue power light on LX6200-01
unplug the ram & cleane the ram and then try again
Oct 03, 2009 | Gateway LX6200-01 PC Desktop
Screen does not turn on but green light is on.
Green light indicates the monitor is getting power. Nothing coming up on the screen indicates, No Signal.
No signal from the computer. This means the computer itself isn't working.
A bad power supply in the computer can cause this. A bad power supply is the leading cause of desktop computer failure. It is replaceable, and can be done by the owner relatively easy.
You may have a computer tower that the Power light comes on, you hear fan/s spinning, (Including the Power Supply fan), and it sounds like the harddrive is running.
ALL the lights in your computer use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
A harddrive sitting there spinning in an endless loop, consumes about 2 to 3 Watts.
A Processor uses 51 to 125 Watts. Depends on what Processor it is.
A weak Power Supply will have enough power for lights, fans, and that harddrive sitting there spinning.
It won't have enough power to turn on the Processor.
[No processor operating, then the harddrive sits there spinning in an endless loop, because there is no processor to find the boot sector]
For a test, connect your monitor to a know good computer. See if it works.
Now connect that other monitor to your computer.
Sep 05, 2009 | Sampo P7011M (Silver) 17 in. Flat Panel...
Solid amber light on front amber on mother board
take the PSU (Power Supply Unit) from a known working computer, preferable to be the same model and test with it. when you do so make sure you disconnect any peripherals e.g ( Printer, CD-ROM, Floppy).
Look closely at the memory bay for any bent pins, and test with one memory at the time.
Let me know if this is still an issue.
Regards
Dec 23, 2008 | Dell OptiPlex GX280 PC Desktop
Hanns g JC199D will not turn on, comp is on, try to turn monitor
no signal indicates a couple things... i suspect your computer isn't even booting up. reboot the computer while tapping the F8 key.... you should see writing on the screen... boot to safe mode. after it sucessfully boots up... reboot again... should be fine.
Robert
also is that an add on video card ?
Dec 18, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
Working fine until psu packed in, replaced psu, begins power up
The PSU dying may have destroyed the motherboard also. Try removing all interface cards and disconnecting all drives to make sure.
Nov 11, 2008 | Foxconn WinFast K7S741MG Motherboard for...
Pc Seems to be dead wont load bios post moust doesnt work or keyboard or monitor
I have the same problem, the CPU fan spins, keyboard lights blink, no start up screen, or bios.
But, when I push a few times on the pc reset button, then the CPU fan is becoming still, the keyboard light are out and I can start the computer again in a normal way.
Can this one be a temporally solution for you too? Do you have any suggestion about?
I guess it can be an electricity dysfunction of a wrong fixed cable.
Oct 15, 2008 | Biostar P4M80-M4 Motherboard
XFX GeForce FX 5500 Graphic Card Logo
184 people viewed this question
Top XFX Computers & Internet Experts
David
David
KG John Justin
KG John Justin
marley mcelhinney
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
