Question about Schwinn Cycling
How do you use the 21 speeds on the Schwinn ladies coaster bike?
  • 1,889 Answers
There are 7 cogs on the rear wheel hub; three on the crank hub:
7x3=21 gear change possibilities
large gears move the wheel faster and farther around but, with more effort
small gears move the wheel less distance but, with less effort
i.e. 10 teeth divided by 30 teeth= 3:1 per 360 degree rotation of the bicycle wheel
Posted on Sep 07, 2009
Can you show me a picture of a stem cap bolt and stem clamp bolt for a Schwinn Surburbia 26-inch, 21-speed bike?
Found this with Google - multiple pics of bike: Schwinn Suburbia 21 Speed Bike Current price 105 It would be very helpful in assisting you if you said what problem you are having.
Jun 13, 2017 | Schwinn Cycling
I have a schwinn serial number dp509984. I would like to known what year make and model it is as well as a price range if at all poossible. Thanks for ur help
It would help if you had at least provided the type of bike (old coaster brake, 3 speed, 10 speed, etc.) The make is Schwinn, the model is written right on the bike frame or chainguard. If the bike is repainted so that the model is not visible it's not worth much. As far as year, just Google "Schwinn serial number" (and note info about date codes) and see my tip for more info: How to determine the year value etc of your bicycle
Nov 05, 2016 | Schwinn Cycling
How do I correct the clanking noise in the rear of my Schwinn 24" Meridain Tricycle?
It could be that the chain needs tensioned, or if it is a coaster brake, the hub may need serviced. The noise could be coming from anywhere and your best bet is to have a qualified mechanic look at it.
Oct 31, 2014 | Schwinn S4025 Meridian 24" Single Speed...
I have a Schwinn women's 21 speed Frontier. Frame in purple serial #0378. I wanted to know the year and specs. On it? Thank you!
First thing, is headbadge black and red? Does it say it was made in China, either on the headbadge or somewhere else on the frame. If so, the bike has no value as an antique bicycle. If its in running condition, tires hold air, brakes work and gears shift its about a $60 to $ 75 bike
Sep 22, 2014 | Schwinn Frontier 21 Speed Mountain Bike...
I found a very old Scwinn 26" boy's with a 3 speed coaster brake on it. I figure someone swapped it decades ago. Do you know how far back that 3 speed w/ coaster bakes goes?
Three speed Schwinn's go back to the late 50's and 60's. Just type Schwinn Photos in the command line on the internet search page area and a full page of pictures will come up. Here you may see the exact bike you purchased with the descriptions.
Feb 26, 2014 | Schwinn Windwood 26 Women s Cruiser...
When coasting the pedals keep moving so you have to continue to pedal and when peddling backwards the bike goes backwards, how do I stop this?
I assume that this bike normally has a coaster brake. If so, your coaster brake mechanism (inside the hub of the drive wheel) is jammed or broken. You will have to disasssemble the wheel hub. This bike might have a coaster brake on both rear wheels or maybe just one side. Lift both rear wheels off the ground and turn them independently to determine which side the problem is on.
Sep 18, 2012 | Schwinn Meridian Adult 26-Inch 3-Wheel...
The brakes are getting stuck and the wheel doesn't tuen
You do not say what kind of bike, speed bike?Coaster brake? hand brakes, pedal brake? If, it is a hand brake, it usually means that your wheel is bent and needs to be trued. You cannot adjust brakes with a bent wheel and you need a truing stand.. If it is a coaster brake you need you hub rebuilt as there is an part broken inside the hub.
Apr 16, 2011 | Schwinn Cycling
I just purchased a Schwinn "Safari" 16" boys bike
Why do you need the manual? It is more than likely a coaster brake bike, and a users manual is not going to answer any technical stuff anyway. If, you are concerned with the safety of it, go to a Schwinn bicycle dealer and have them check it out. Tire pressure is on the sidewall of the tire.
Dec 17, 2010 | Cycling
How do you set up brakes after changing tube? What is the position of the lock washers - inside or outside of frame?
The lockwashers go outside the frame, right next to the nuts. But I would need more info to answer the brakes question. Schwinn called lots of bikes "Jaguar". If this a single-speed bike with a coaster break, then you can Google images for COASTER BRAKE..
Aug 18, 2010 | Schwinn Men's 26" Jaguar Cruiser Bike
Cycling Logo
152 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Tony
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
