Question about E-Machines eMachines Desktop PC
Definition of beep codes on power-up beep-------beep beep beep-------beep beep beep---------beep on a t2542 emachine
  • Mike Giandre Sep 07, 2009
    i have the on-board video and pci slot video niether one works. I have a known good video card and monitor
  • 555 Answers
Sounds like a video error. It may be caused also by a bad memory, but I suspect problems with video.
Posted on Sep 07, 2009
  • 43 Answers
Ram error.
either u didn't install the rams properly...or the rams gone bad.
    Problem Solver:
  • 18 Answers
Memory...
Emachine T3042 BEEP CODES
Remove the power cord, open the case and sit the computer on its side. If you have more than 1 memory chip inside the computer remove 1 and set it aside. Now plug the power cord back in without putting the case back on and press the power button. If it boots without beeping, the mark an x on the memory chip that is set aside because it is probably bad. If it does not boot, Remove power cord, move the memory chip that is inside the computer to the next Memory Slot and then plug in power cord and reboot. If it boots, remove power cord, put the memory chip that is set aside that has the x on it into the open slot and then reboot. If it does not boot we definitely know the chip with the x on it is bad.
To verify further that the chip with the x on it is bad you can remove the chip without the x marked on it into both memory slots like we did above while the other chip that seems to work is set aside.
Mar 25, 2012 | E-Machines eMachines Desktop PC
Front power switch broken. Bezel won't come off easily. Thought we could just get a switch and install on the back but don't know which of the colored pairs of wires go to the original switch in the...
I would suggest this generic Power On switch,
1) http://www.directron.com/atxswitch.html,
and the Red, and Black twisted pair of wires go to the Power On switch.
Your statement of ,"....don't know which of the colored pairs of wires go.....", leads me to believe you may have all of the Front Panel wires disconnected.
How about information as to where ALL the Front Panel wires go?
(Provided I have correctly interpreted your statement)
Back in the time that the eMachines T2542 was made, TriGem was the motherboard manufacturer.
The Model Name of the motherboard is Imperial, and the Model Number of the motherboard, could have been one of four variations offered.
Model Name: Imperial
Model numbers could be G, GL, GV, or GLVE
(Imperial G, Imperial GL, Imperial GV, or Imperial GLVE)
ALL four variations used the same Front Panel header.
(The connector on the motherboard the Front Panel wires connect to, is named the Front Panel header)
I would like you to view this page,
http://www.e4allupgraders.info/dir1/ecase/support/front_panel_header_support.shtml
Scroll down to the heading -
Trigem Imperial Front Panel Header Pinout.
A) Pins 1, 2, and 3 are for the Power On LED light.
B) Pins 5 and 6 are for the HarDDrive activity LED light.
(Pin 4 is not used. NC. No Connection)
C) Pins 7 and 8 are for the Power On switch
D) I wouldn't connect any wires to Pins 9 and 10, nor Pins 11 and 12
E) Pins 14 and 15 are for the Reset switch. (The button you press to restart your computer.
If the T2542 doesn't have a Reset switch, don't worry about it. There are many other ways to restart your computer)
F) Pins 17 18, and 20 are for an internal speaker.
This speaker is used for BIOS Beep Codes.
In the chart to the right, you will see GRD used many times.
GRD stands for Ground.
ANY Black wire in the twisted pair of wires, is a Ground wire.
Most of the eMachines I have worked on, use a Red, and Black pair of twisted wires for the Power On switch.
I could be mistaken on the T2542.
Best method, is to follow the color code of the wires that come from Pins 7 and 8, and be sure.
Aug 17, 2010 | E-Machines T2542 PC Desktop
I just lost all my cd 's with my emachine t2542,i re install new W XP OS because my hard disk was damaged and replace new one,the problem is,it's usb ports doesn't work,help me pls.tnx
In order for us to assess possible drivers that are available for the eMachines T-Series T2542, please download the trial of Driver Detective and run it to ensure a more accurate list of drivers for your computer with less chance of error.
http://www.drivershq.com/Drivers/eMachines/T-Series/T2542/22605/22647/22688/Drivers.aspx
Oct 05, 2009 | E-Machines T2542 PC Desktop
Battery change on T2542.
SEE WHAT HAPPENS WHEN THE BATTERY IS 100% CHARGED.
May 04, 2009 | E-Machines eMachines Desktop PC
Short but rapid beep code when powering up emachine
The beep code most likely is either video card or memory.
If you have a video card or can borrow one that you know it works try it first, if that doesn't resolve your issue try the memory.
You can take the memory out and have it tested to see if it is defective.
Go to this site and get the Beep Codes, http://www.computerhope.com/beep.htm
I hope this helps.
Good Luck.
Feb 26, 2009 | E-Machines eMachines Desktop PC
Emachine t2542
When you say out, do you mean they are broken, or just disconnected? Most of these computers have a plug on the end of the wires to the front panel and it just plugs into the system board. If you look at the board you'll see where the front panel wires go. Sometimes it's hard to read the small type, but there are labels on the board that tell you what connector does what.
Nov 17, 2008 | E-Machines eMachines Desktop PC
Emachine T2542 Won't power on
you need to open the PC and check the power supply for some fuse and safety device that acts like a fuse , these fuse looks like a 3 leg transistor only that it have 2 , look for this , and of course the typical fuse . hope it helps
Apr 19, 2008 | E-Machines eMachines Desktop PC
Emachine help
Hi. could be a few things
1st thing if theres no power going to the base unit, the power supply is gone will cost about £20 for a new one.
2nd thing it could be graphics card, memory needs refitting. ie take them out and refitting them usually fixes it.
theres a few other things it could be but less likely. i suggest trying the above..
have a great new year
John
Dec 29, 2007 | E-Machines eMachines Desktop PC
My T2542 won't start.
There might be a problem with your mother board, or processor, or both of them.
Oct 07, 2007 | E-Machines eMachines Desktop PC
Emachine t5026, 3 beeps
try a cheep video card from your local used computer parts store they're every where, you'll ask for a pci video card.
Mar 28, 2007 | E-Machines Emachine T5026 power supply **...
E-Machines eMachines Desktop PC Logo
1,407 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
