Question about Mtd 22" White Outdoor Self Propelled High Wheel Mower
How to remove old and install new blade adapter (753-0609)model 759 on MTD mower--
Removed blade. Sprayed WD40 on top/bottom of adapter & shaft- waiyed 30 sec. Lightly tapped adapter with hammer then adapter slid right off. Adapter was slottedon one side that matched theshaft slot. Then I was able to remove propeller drive belt cover and belt. Replaced everything in reverse order
Posted on May 11, 2010
  • 389 Answers
Remove the blade bolt and blade, slide the adapter off the crankshaft. If it will not slide off, spray it with a good penetrating oil and let is soak for a bit then take a SMALL hammer and gently tap on the sides of it while pulling at the same time
Posted on Sep 14, 2009
2 Suggested Answers
mowerman1857
  • 389 Answers
SOURCE: HOW TO REMOVE MTD BLADE ADAPTER AND INSTALL NEW
Remove the blade bolt and blade, slide the adapter off the crankshaft. If it will not slide off, spray it with a good penetrating oil and let is soak for a bit then take a SMALL hammer and gently tap on the sides of it while pulling at the same time. Slide the new one back on and repklace blade and bolt(s)
How to remove rear drive wheels on old MTD 21
Daren Ingold's suggestion works only for the right rear wheel on my 19+ year old MTD Yardman 21" self propelled mower. The ratchet spur on rear left wheel is held on by a bolt in the center of the axle and a spline. Remove the center bolt and washer. Pry the ratchet spur off the spline by using three medium blade screwdrivers wedged between the wheel and the spur gently tapping the three screwdrivers in succession until the spur is half off the spline. It will come off easily after that. Remove the spur, noting direction, and remove the wheel and replace it with one of the front wheels (they're all the same design) if it is in better condition and use the rear wheel for the front. Good luck ever finding a new replacement for this particular wheel. My mower is 19+ years old but runs perfectly otherwise. Stored in dry basement.
Sep 23, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
My MTD riding lawnmower is burning thru the new belts I just purchased.The new belts are 954-0371A which replaces 754-0371A. The old style belt lasted 5 years. Even before engaging the clutch, the belt...
My idea is not about the belts, but is about the deck. If the tensioning mechanism on the deck is getting stuck in an intermittant position than the belt may be just tight enough to turn blades while slipping through the pulleys, this may cause enough friction to start melting your belts. If this is the case you will have to remove your mower deck and see what is preventing the mechanism from functioning properly.
Jul 07, 2011 | MTD LAWN MOWER PART 1909404 BELT
I have craftsman Riding mower modle#917.289213 and want to mount a MTD 190-833c-OEM. Has somone out there ever run into this problem. I first purchased the riding mower, and the called Husqvarna and...
I have never run into this problem. Craftsman riders are manufactured by American Yard Products (AYP) and are owned by Husqvarna Co. MTD is their own manufacturer. I would assume that if you want to hook this MTD blade to an AYP mower there would be some "back yard engineering" necessary. If there is an adapter available to hook it to your mower, either AYP or MTD should supply that adapter. Not much help for your problem, so I hope you get it figured out.
Feb 17, 2011 | Garden
MTD bsgger/Mower 21 self propelled only number 1183AC.Need part that mower blade is attached to then to drive shaft. Can't find
Hi and welcome to FixYa. I am Kelly
The part your looking for is called the BLADE ADAPTER. The part number should be: 753-0588
These are available at most any lawnmower repair / parts store. If you walk in woith what is left of your old one they can sell you an exact replacement. I am kind of old school when it comes to blade adapters. I always match old with the new before I buy them. I have been burned too many times from on line sites mainly with blade adapters. Most anything else available on the net is fine.
Here is a whole page of adapters:
http://www.lawnmowerpros.com/MTD/MTD-Blade-adapters.asp
Thanks for using FixYa.
Kelly
Apr 02, 2010 | Garden
HOW TO REMOVE MTD BLADE ADAPTER AND INSTALL NEW BLADE ADAPTER KIT 753-0609 on shaft for 21 in. MTD model 759 mower?
Sep 07, 2009 | Garden
Mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Aug 23, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Installing blade belt
you have to raise the mower then drop the rear of the deck by removing the 2 pins on the blade adjustment lever.once you do that it should go pretty easy
May 17, 2009 | Mtd Garden
Mtd 22" White Outdoor Self Propelled High Wheel Mower Logo
799 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
