Question about Singer 3116 Simple
How to thread a bobbin for model # 6234 sewing machine
  • Singer Master
  • 1,388 Answers
Try this page for Threading and Bobbin Winding Diagrams for loads of machines.....even if your model is not specified, there's a good chance you will be able to work it out from similar machines.
Posted on Sep 07, 2009
Necci 752 manual is needed.problem with threading and stitching
Hm, I'm not able to locate a manual but may be able to offer some suggestions.
Remove the top thread from the machine.
AVOID OLD OR BARGAIN BIN THREAD!
Use the same thread in top and bobbin.
Be sure to use a brand new needle--needs to be compatible with the thread and fabric of the project..
ALWAYS RAISE the presser foot and rethread from the beginning.
Set the top tension to the midway point.
Verify the bobbin is loaded and threaded correctly and it turns the correct direction.
Pull the bobbin thread up through the fabric before taking the first stitch. It also helps to hold both thread tails in your left hand when taking the first stitches.
Test your machine and tweak the top tension until the top and bobbin threads meet in the middle of the fabric. (Increased top tension will pull the bobbin thread up. Decreased top tension will allow the bobbin thread to pull the top thread down.)
How to Thread Necchi Sewing Machine
How to Thread Necchi 535FA 535 534FB 534 Sewing Machine and Bobbin Case (not your model, but the threading and basic instructions will be similar or the same as your machine)
How to thread Necchi model 535 FA sewing machine now with captions
Mar 18, 2018 | Sewing Machines
Can't figure out how to fill the bobbin
hi Beverly.
you have not said what make and model.
but try this.
Always wind the bobbin before threading the machine and needle.
  1. Place spool of thread on spool pin.
  2. Slide spool pin holder/cap firmly over rim of spool to prevent thread from tangling.
  3. Push bobbin winder pin to far left if it is not already there.
More items...
Winding a Bobbin ' Singer Sewing
www.singerco.com/sewing-resources/bobbin-winding-other
or try this.
How to fill bobbin for sewing machine
How do you fill a bobbin on a Brother sewing machine? Use only the included bobbin or bobbins of the same type (part code: SA156, SFB (XA5539-151)).
  1. Turn on the sewing machine, and open the top cover.
  2. Place the bobbin on the bobbin winder shaft so that the spring on the shaft fits into the. ...
  3. Remove the spool cap that is inserted onto the spool pin.
More items...
How do I wind the bobbin? ' Brother
support.brother.com/g/b/faqend.aspx?c=us&lang=en&prod=hf_pc420eus... Search for: How do you fill a bobbin on a Brother sewing machine?
or you could go and look at this link to see if it helps you out some more.
igniter button for SUNJOY PH018PSS Google Search
Nov 21, 2017 | Sewing Machines
Model 4075 white sewing machine thread from bobbin builds up and stops sewing.
Check the stitching and confirm that it is in fact bobbin thread and not the top thread that is creating knots & loops under the fabric. This is usually the case and is called thread nests or bird nests. (You can search the internet for more information about this symptom.)
Install a brand new needle.
Remove the thread from the machine.
ALWAYS RAISE the presser foot while rethreading the upper thread.
Confirm the thread path is correct.
Verify the bobbin is installed facing the correct direction in the bobbin case and the bobbin case is threaded properly.
Set the upper tension to the midway point (factory standard) although it may need to be tweaked as machines change with use and time.
Pull up the bobbin thread. This method works with general sewing projects, not just quilting.
How and Why to Bring up the Bobbin Thread
Begin to test sew slowly.
If the thread is still making a mess, then the machine most likely has a timing issue. There are multiple web sites and videos that discuss sewing machine timing. Or take it for service.
Sep 30, 2016 | White Sewing Sewing Machines
Why won't bobbin winder spindle turn?
Bobbin winder spindle will not spin - YouTube
? 1:24
https://www.youtube.com/watch?v=Fh52_ndkSKs
Jun 12, 2013 - Uploaded by djc472
Thread caught between spindle shaft shoulder and bearing. ... Sewing machine won't pick up bobbin thread ...
Why won't the bobbin winder work on my Kenmore sewing ...
www.shopyourway.com > Manage My Life > Questions
The bobbin winder doesn't spin and I can't wind the bobbin. ... What will release thebobbin winder that is stuck to the right on my Kenmore sewing machine model 385.17826690? Why won't my bobbin holder thread to the top on my Sears Kenmore sewing machine model 385.17928?
Sewing machine bobbin winder won't turn ' ShopYourWay
Dec 29, 2015 | Sewing Machines
Drop in bobbin on singer 6234 will not thread empty Bobbiin thread winds around underside od bobbin
try using a different bobbin and see if that helps, if it doesn't
then the machine may need to be checked to see if there is
something wrong with the hook and the hook race.
Nov 29, 2012 | Janome Jem Silver 662 Mechanical Sewing...
I have a singer Model #6234. The bobbin is wound
If the bobbin case is defective this can cause the problem. However, this can be a difficult problem to repair, take it in and ask for an estimate to repair.
Feb 26, 2010 | Sewing Machines
I need to know how to thread a bobbin?
TRY THIS, itma not be your model, but should help Title:
ac093.jpg Pre-tension disk ac094.jpg Bobbin winder shaft ac095.jpg Bobbin
1. Pull up the spool pin as far as possible, and then put a spool of thread on this pin. windingbobbin_a0991.jpg
2. Pass the thread around the pre-tension disk. Make sure that the thread passes under the pre- tension disk.
windingbobbin_a0992.jpg ac098.jpg Pre-tension disk c_b4.jpg Pulling it in as far as possible
Caution If the spool of thread is not in the right place, the thread may tangle on the spool pin.
3. Pass the end of the thread through the hole on the bobbin from the inside of the bobbin. windingbobbin_a0993.jpg
4. Put the bobbin onto the bobbin winder shaft and slide the bobbin winder shaft to the right. windingbobbin_a0994.jpg
5. Turn the bobbin clockwise, by hand, until the spring on the shaft slides into the groove of the bobbin. windingbobbin_a0995.jpg ac099.jpg Spring on the shaft ac0991.jpg Groove of the bobbin
7. While holding the end of the thread, gently press the foot controller or press start/ stop button (for models equipped with the start/stop button) to wind the thread around the bobbin a few times. Then stop the machine. windingbobbin_a0997.jpg
Note
  • If the sewing machine is to be operated using the foot controller, connect the foot controller before turning on the machine.
  • When the foot controller is plugged in, the start/stop button cannot be used to start sewing (only for models equipped with the start/stop button).
Caution Make sure you follow the instructions carefully.
If you do not cut the thread completely, and the bobbin is wound, when the thread runs low it may tangle around the bobbin and cause the needle to break.
9. Slide the sewing speed controller to the right (to set the speed to fast).
(For models equipped with the sewing speed controller.) windingbobbin_a0999.jpg ac0992.jpg Sewing speed controller
10. Press the foot controller or press start/stop button (for models equipped with the start/stop button) to start. windingbobbin_a18.jpg
11. When the bobbin seems full and begins spinning slowly, take your foot off the foot controller or press start/stop button (for models equipped with the start/stop button). windingbobbin_a19.jpg
12. Cut the thread, slide the bobbin winder shaft to the left and remove the bobbin. windingbobbin_a191.jpg
13. Slide the sewing speed controller back to its original position (for models equipped with the sewing speed controller). windingbobbin_a192.jpg
Caution Not winding the bobbin properly may cause the thread tension to loosen, and may break the needle.
woundbobbin3.jpg ac0993.jpg Wound evenly ac0994.jpg Wound poorly
Note
  • When the sewing machine is started or the handwheel is turned after winding the thread around the bobbin, the machine will make a clicking sound; this is not a malfunction.
  • The needle bar does not move when you slide the bobbin winding shaft to the right.
Sep 02, 2009 | Brother LS-2125 Mechanical Sewing Machine
How to thread the bobbin on a singer touch and sew model # 625
how to wind the bobbin of the singer touch and sew model 625
Jun 13, 2009 | Singer Sewing Machines
Need manual for Kenmore sewing machine, model 148-600.
hi! there, since there no model you can relay on this basic set up an old mechanical sewing machine,set your upper thread as shown65a8465.jpgfollow the red loop thread from sppol to needle,then lift needle cover plate take bobbins and follow bobbins thread directionec848a5.jpgthreads inside bobbin clockwise rotation when you pull outthe insert bobbin to shuttle race casas shown
hold bobbin like this 33ea7ef.jpginsert
this to shutttle race case as shown ignore arrow
ebd49c7.jpgthen
after inseting bobbins closed needle plate cover
manually rorate hand wheel to hook up lower thread bobbin by upper thread bobbin if two thread appear on plate needle adjust tension dial to # 3 to 4 and stich dial to # 12 this for straight stich try sew manually first to observe thread under bobbins if free rotate and no accumulation of thread loop you sew w/ foot pedal or push buttin..happy sewing and have a nice day thanks
Mar 31, 2009 | Sewing Machines
Singer 3116 Simple Logo
1,139 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
