Question about Saitek Pro Flight Yoke System Flight Simulator
On saitek yoke system it wont work on fsx *flight simulator x* if you can help thanks !!!!!!!!!!!!!!!!!!!!!!!
  • 122 Answers
Ensure you have installed the drivers for it. If you don't have them, go to Saitek web site, download and install the correct one's for your operating system. Also ensure that the yoke is plugged into the USB port on the rear of the PC as these USB sockets give the most power. Additionally, you have to set the yoke up in FSX\Settings so it knows what to do with it with regard to calibrating it and assigning what buttons do what.
Posted on Jul 13, 2010
Just purchased saitek yolk with throtle but its not working ,.tried calibration still does not work
I had a friend with exactly same issues, only he used a CH Flight Yoke system.
Calibration can be very tricky sometimes, and it has very often to do with how the configuration file has been set up.
You might have to rebuild your configuration file for your Flight Simulator before it will work properly.
However here is some hints for calibration fix from Saiteks UK support.
Maybe this can solve your problem, understanding how to make a valid configuration file for Flight Simulator.
http://www.saitek.com/uk/supp/yokefsx3.html
Good luck
Aug 24, 2011 | Saitek Pro Flight Yoke System Flight...
All views move to different positions when connecting the yoke, cannot pan up or down only left or right when the FSX Options-Settings-Controls-Enable contollers is not ticked. When I "enable" Contollers I...
Hello
In the control options of fsx you need to delete the default keybind for the view you want assigend to your joystick.Then replace it with your controler axis.Or you can use the software and do your own program for fsx.The views in fsx have always been an issue or a problem with the game.
Also panning down in fsx and reverting back up has always been an issue or a clitch in the simulator.it does however work in fs version 9.
Using Fsuipc with a weather program or a virtual airline should not make a difference in control settings.
Jun 06, 2011 | Saitek Pro Flight Yoke System Flight...
In FSX (Win7 64bit) couldn't get enough speed to take off! Found that when Saitek proflight quadrant set at max only around 85% power delivered. Had to use mouse pointer in virtual cockpit to advance...
Hi Alf,
This sounds like a deadzone setting not allowing the throttle axis to go full.
There are 2 places in which the deadzones can be set:
In FSX: Settings> Controls> Calibration, there select your Yoke and then set the NULL to the left, which is 0.
Or in windows in Input Devices (Win Xp - is in Control Panel, Vista or Win7 go to Games Explorer>Tools>Input Devices).
In Input Devices->Select the Yoke and click Properties, then go to the Deadzones Tab and set the deadzones for the Throttle. Mixture and Prop to 0.
Hope it helps...
Apr 29, 2011 | Saitek Pro Flight Yoke System Flight...
I have a Saitek Pro Flight Yoke System with Throttle Quad and it works fantastic with MS FSX, but if I try to use it with my Proflight, as soon as it starts, it does a wild left hand turn and just gets...
Try to get the latest drivers from www.saitek.com
Try it on another computer and if it does the same there too you might want to consider that it can be faulty...and you might want to request a replacement for it.
Hope it helps..
Apr 24, 2011 | Saitek Pro Flight Yoke System Flight...
Bought the saitek headset how do configure to talk to the tower in the fsx game
You cannot talk to the tower in FSX, only via third part software and then the button you wish to use would be configured within that software (such as Live ATC),
May 15, 2010 | Saitek Pro Flight Yoke System Flight...
Hi, I contacted Saitek approximately 2weeks ago regarding the blueand purple backlight failure on my Eclipse II keyboard. I am awaiting your reply. I now have, what I feel to be a more serious failure on...
Hi Chris
Ensure that you have the usb lead from the yoke plugged into the rear of the PC as these give the most current. Ensure the drivers for the yoke are installed properly and they are the latest for your operating system. If this still does not work, then the yoke is faulty. Good luck!
Jul 23, 2009 | Saitek Pro Flight Yoke System Flight...
SPOT VIEW FIXED
You need to assign what view you want to the cooley hat on your controller in FSX\Settings. Rethe Zoom, press the backspace key to reset it, then use the + and - keys to zoom in and out.
Apr 22, 2009 | Saitek Pro Flight Yoke System Flight...
Saitek X52 Flight Control Problem
Remove the X52 and drivers from your system. You have to install them in a certain order, so look in the documentation for the correct way to install and you will be okay. Good luck
Feb 02, 2009 | Saitek Pro Flight Yoke System Flight...
MS FSX -view keeps switching from cockpit to spot view
The most likely problem here is that you have multiple assignments for the view change command set to multiple controllers hooked up to the system. They are conflicting with each other causing random view changes.
Firstly, go into Windows Control Panel and to Game Controllers. Remove any controllers listed in that box that are not currently connected or being used in your flight simulator.
Next, go into FSX, into the control assignments section...
Go through each controller in the drop down box (in the button/keys tab) and ensure only one controller has the assignment for view changes assigned.
Nov 23, 2008 | Saitek Pro Flight Yoke System Flight...
Saitek Pro Flight Yoke System Flight Simulator Logo
369 people viewed this question
Top Saitek Video Game Consoles & Games Experts
 TE5LA
TE5LA
juanmireles1
Michael Vincent Cruz
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
