Question about Home
My pool pump doesn't shutoff
I see on this site several issues that are the same as mine which is the pump can only be shutoff with the circuit breaker. I have had the pool for over three years and this is the first time I have experianced the trouble. Does anyone have a solution for this issue?
    President:
  • 1,564 Answers
It would appear that the contactor switch that feeds the pump is hanging up. Try tapping lightly on the contactor within the control panel. Tap it with a wooden hammer handle and see if it releases. Also make sure that the exciter wire is not staying live while the switch is moved to the off position. When you turn the breaker back on and the pump starts without the switch being pushed you definatly need a new contactor.
Posted on Sep 07, 2009
Blowing fuses to the auto shutoff
Well that relay powers several components, including the fuel pump relay, ECM, and injectors.
Have you narrowed down which circuit has the short to ground ?
Jun 13, 2015 | 1998 Jeep Cherokee Grand 2WD
1994 Mazda PU Truck sometimes won't start if shutoff for 5-10 minutes.. Several tries later, it will start. spark seems ok, it gets enough fuel for a second, but then poops out. fuel pump shuto
Well there is no shutoff relay, but there is a fuel pump relay that powers the pump.
I would check it first. The computer grounds the relay for 3 seconds when you crank the engine to boost fuel pressure. Once the engine starts the pump is powered only if you have oil pressure.
Apr 12, 2013 | Cars & Trucks
My pool pump trips main circuit breaker sometimes when it turns off
Get a new electrician! The pool pump should be on its own isolated circuit, usually on no larger than a 30 amp GFCI protected breaker. You said it was replaced but he only treated the symptom, not the cause. This one will take on site troubleshooting to find out why your whole house is affected.
Jan 09, 2013 | Pool & Spa
Have an intex 16 x48" salt water pool generator
I checked the Intex web site and here is what they said:
There are several things you may need to check and do:
- Test the salt level first with Test Kit, and add salt as needed.
- Remove the electrolytic cell for inspection and clean it if necessary.
- If code 91 still appears despite the above steps, there might be a possible electrolytic cell
failure. Please contact Intex Service Center, and replace the cell if needed.
NOTE: Always turn the power off and disconnect power cord before cleaning and servicing.
I hope this helps.
Aug 24, 2011 | Intex Automatic Salt Water System for ...
My hayward 1hp super pump hums when i turn it on but doesn't turn or pump it eventually trips the circuit breaker inside
Inside pump is a difram , it most likely is stuck, some times if you shut off pump, turn back on a few times it might release itself, but most likely needs to be replaced. Let me know, mike from fixya.com
Jun 08, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
Krystal clear generator red service light comes on. unit only several months old
If its in warrenty call them they will send you a new one, if its out of warrenty check your circuit board for corrision. to do this UNPLUG the system, take the 4 screws out of the peice with the display on it and pick it up there you will find a circuit board. Mine had a corroded resistor. i went to radio shack found a new one (a two pack for $1.50) soldered it on good to go works great. This seems to be a common problem i have read online.
Sep 01, 2010 | Intex Automatic Salt Water System for ...
Air in my jacuzzi pool pump
It sounds like air is entering the system through the clear dome (filter access) on the pump. Check the o-ring directly underneath the clear plastic dome. CAUTION: Be sure to isolate the pool from the pump via in-line shutoffs prior to loosening the dome lid. Sometime cleaning the o-ring and coating it with petroleum jelly helps the unit seal better.
Aug 02, 2009 | Jacuzzi Cyget In Ground Pool Pumps
Same Issue
the pump stop so will not drain spa dip # 4 may turn off for the delay but not sure if the pump will still turn off since this is new tech. good luck
Jul 05, 2009 | Jandy Aqualink Rs4 One Touch Control...
DOLPHIN DIAGNOSTIC AUTOMATIC POOL CLEANER STARTS AND STOPS
There may be moisture building up inside the motor housing. Try to Open it. http://www.i-love-my-aquabot-automatic-pool-cleaner.com/Maytronics-Dolphin-Repair.html
Then make sure no moisture accumulated in the circuits. Mine got the same problem.. after running trouble free for several years it suddenly stop running after the first few minutes..when i opened it a lot of moisture in the circuit. I tot it was toasted. so i took my hair blower and sealed it back and replace the moisture absober (it was soaked).. after first run it would run only the SELF TEST mode.. i tried several method to make it run all the way to the main program.. the solution.. start it and make sure it will not tilt in the first 10 minutes before you let i run sideways to the walls, this makes the program run back to normal.
Jun 28, 2009 | Smart Pool Inc Dolphin Diagnostic...
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
