Question about Bose 901 VI Main / Stereo Speaker
Bose 901 speaker with eq
I have a pair of 901 Bose speakers over 10 years old. About six months ago, I purchase a Onkyo TX sr 506. My question is how do I hook this up. Thanks
    Brigadier General:
  • 8,546 Answers
You want them to be your Main Front speakers, right? The news is not good.
There will be some limitations because you can't extract 'processed' L-R from this receiver. The following will give you good stereo and Front L-R from the 901's but it won't allow central volume control or send them any of the DSP effects you may select. Sorry. If it had a Front L-R Pre-Out you'd be good to go for all functions and listening modes.
You'll need a separate stereo amplifier WITH ITS OWN VOLUME CONTROL for the 901's to accommodate the need for the Active EQ. Modest amps would work but at very loud volumes may go into clipping, which is bad for any speaker. I'm using only 100W for mine and it has plenty of steam for the 901's.
With this receiver we have to cheat to get the Front L-R signal out to the 901's (but it's unprocessed and at a steady volume level)...
For connection I would run a pair of RCA cables from the VCR/DVR Audio Out L-R OUT jacks (*) to the Active EQ's Line IN; then the EQ's Line OUT to a separate amp's Line IN. Attach the 901's to the new amp.
* You'll lose the ability to use these jacks for anything else, but few of us use them anyway. DO NOT select this function for monitoring or you lose all audio in the Onkyo.
Posted on Dec 05, 2009
I just purchased 2 used pairs of Bose 901 series III. The problem is they came with just 1 active EQ. Can I all 4 with just one EQ. Thank Tyler
Yes, if they're all on the same 2 amplifier channels.
If you're pondering some kind of employement in a multichannel system look around fixya for the dozens of post I've made addressing various scenarios. Keyword: Bode 901
Jan 16, 2011 | Bose 901 VI Main / Stereo Speaker
I just enherited a pair of bose 901 speakers
My suggestion is do not hook the 901's directly to the Onkyo. It is compatable, but they WANT more than what the receiver can give them. I suggest going and getting a dedicated amplifier for them. Trust me, you'll be a lot happier going that route.
May 27, 2010 | Audio Players & Recorders
Proper wiring connection on bose 901 speaker with onkyo tx-sv424 purchase 5 years ago
trying to hook up sereas 2 901 to onkyo sx 424 i have access to carver c 1 if that will help
Nov 29, 2009 | Bose 901 VI Main / Stereo Speaker
Bose 901 hookup with Onkyo SR 805 and Onkyo M282 amp and 901 EQ/
The good news. I have a setup similar to what I think you're trying to do and it works great!
The Onkyo M-282 stereo amp for the 901's is the perfect solution. Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
**Onkyo SR805 Pre-Out Front >>> Bose EQ Amplifer IN
Bose EQ Amplier OUT >>> Onkyo M-282 IN
Set the Input Level on the back of the Onkyo to MAX. The receiver controls everything just fine after you run through your level setup routine again.
I was looking a the 12v triggers on both units and it looks like you only have a Zone 2 trigger so that wouldn't work for turning on your M-282. I guess you're going to have to turn it on and off the old fashioned way, like I do mine.
Mar 15, 2009 | Onkyo TX-SR705 Receiver
How to hook up bose series 2 eq to onkyo tx sr 875 receiver.?
I wrote most of this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great! I see on the SR875 there are Pre Audio OUTS. This is easy.
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Jan 07, 2009 | Bose 901 VI Main / Stereo Speaker
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
Onkyo tx sr 705 & bose 901
No. Active Equalization is required for the 901's and not to be used with any non-901 speakers.
Sep 13, 2008 | Bose 901 VI Main / Stereo Speaker
Cannot hook eq to my receiver
The speakers will not sound right. You dont have two tape monitors on this receiver? You can simply use the tape otput to the EQ input, and then the Tape monitor input to the EQ output leads. Good Luck
Jun 09, 2007 | Bose 901 VI Main / Stereo Speaker
Bose 901 VI Main / Stereo Speaker Logo
311 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
