Question about Dell 926 All-In-One InkJet Printer
I HAVE DELL 926 PRINER I CANN'T GET IT TO WORK IT FREEZES AND EVERYTIME I TRY TO TURN IT ON IT SAY JAM PAPER I CHECK AND ITS NOTHING THERE I NEED TO DISASSEMBLE IT DONT KNOW TO FIGURE OUT THE JAM PROBLEM
I bought one black and one color cartridge for my dell aio 926 printer...and it says there is a carrier jam. a checked and there is nothing blocking the papers path through the printer. can you please...
Did you actually open the unit up and search the unit thoroughly? I also had a jam error and after an in-depth search I found a little piece of paper the size of a dime! Was not easy to find or remove... Good luck!
Jul 18, 2011 | Dell 926 All-In-One InkJet Printer
Paper jam on Dell Photo 926
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 18, 2010 | Dell 926 All-In-One InkJet Printer
My dell photo 926 printer keeps jamming up
When you refer to jamming up, what has happened is that the rollers are actually collecting fibers from paper every time you print.
First try and use iospropyl alcohol on the rollers and fan out your paper before printing.
If this doesn't work, check to see if the paper is grabbing evenly.
Jul 24, 2009 | Dell Office Equipment & Supplies
Printer wont pull paper down then says paper jam
Dell does not make printers. They put their name on Lexmark printers.
I just repaired a 926 which had a paperjam alarm...and no paper jam. The paper sensor microswitch had been bent up onto a paper roller so the printer thought a piece of paper was stuck under it. It was hard to get the little lever off the roller and back, hanging free, without breaking it. This did not happen on its own so I can't fault the printer.
Look for this tiny black plastic lever hanging down right in the middle of the upper paper rollers, just behind where the carts run.
Jul 03, 2009 | Dell 926 All-In-One InkJet Printer
Won't pick up paper, yellow light on paper jam
ok if you checked the rubber wheels ..that is ok but have check the clik inside the printer if not than chk it out .....might it will work cause if ur priners rubber is clean than there must be some problem in wiring or clicker
Jun 11, 2009 | Dell 1700 Laser Printer
Paper jam
hmmm..I think there is a back door on that printer..try to open it on the back of the printer...
it will allow you to grab the jammed paper..^^
turn off the printer before grabbing the jammed paper..
May 07, 2009 | Dell 962 Photo All-In-One InkJet Printer
Dell AI0 926 All in One shows Clear Paper Jam with no paper in it.
I put my hand inside and found something clicked just below the right of the first two rollers. THen it worked i think whatever clicked must have gotten stuck but i dont know why
Oct 05, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell printing problems
Try fanning the paper and see if that works.
Jun 30, 2008 | Dell 926 All-In-One InkJet Printer
Dell 926 All-In-One InkJet Printer Logo
314 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
