Question about Maisto Ford Svt F150 Lightning P/U Truck
Check engine light is on and codes are 171 and 172
Check engine light is on and codes are 171 or 172 and i know the engine is running to lean but theres no leaks and i already change gas pumps, sparks, mass sensor, and reprogam the compurer, injectors and coils are fine i already taked to many shops in my area and none of them fixed my problem incluting ford dealer all of them told me is running fine tested and droved but the light still on... theres only two modifications intake sistem and 6 pound crank pulley
Im getting P0171 code- lean .
About 259,000 results (0.64 seconds) Search Results
    obd ii - 'Check Engine' code P0171 System Too Lean - Is it ...
    mechanics.stackexchange.com/.../check-engine-code-p0171-system-too-l...
    Feb 11, 2014 - 'Check Engine' code P0171 System Too Lean - Is it safe to drive? ... My question is: is it okay to drive my car while it shows these codes? ... This will cause you to get increasingly worse fuel mileage. ... I am going to defer to your expertise, but I just want to ask if you've considered that lean-running engines ...
    P0171 and P0174 - OBD-II Trouble Codes - RepairPal
    repairpal.com > Encyclopedia > OBD II Codes
    Definition of error code P0171 and P0174 - System too Lean (Bank 1 and Bank 2). ...Before we get into the main causes of P0171, let's explore why this code matters. ..."Lean" running cars and light trucks are highly polluting vehicles. Most of ...
    Mazda tribute codes p0171 - Cars & Trucks 'Cars & Trucks
    www.faqqq.com/.../mazda-tribute-codes-p0171-cars-trucks-cars-trucks-6...
    Question Product: Cars & Trucks Question Details: Mazda tribute codes p0171 ... I am getting the following (4) codes in a 2003 Mazda Protege5 engine: P0090 ...
    P0171 Code thrown while idle - Toyota Nation Forum : Toyota Car ...
    www.toyotanation.com > ... > Yaris/Scion iA, Vitz and Echo Forum
Jan 27, 2016 | Cars & Trucks
I got a diagnostic test on my car cause my check engine light is on and it is shaking real bad when driving it and when i stop at a red light it seems like it wants to stall out
P0305 is a # 5 cylinder misfire , do you know what that is ? Check engine light flashing indicates a severe misfire that can damage the catalytic converter . Don't drive this vehicle ,take it immediately to a qualified repair shop or the dealer .
A Ford P0171 is a LEAN code for cylinder bank 1, and P0174 is a LEAN code for cylinder bank 2. These codes commonly occur on many Ford vehicles, and are set when the powertrain control module (PCM) sees the air/fuel mixture is running too lean (too much air, not enough fuel).
Flashing check engine light CarMD
Oct 24, 2017 | 1998 Ford Mustang
Engine light on 2005 chevy aveo stays on
Engine light lit ? Have it checked for DTC'S - diagnostic trouble code's ! Do you know what DTC'S are for ?
Dec 08, 2017 | 2005 Chevrolet Aveo
I have a 97 wrangler 2.5. Check engine light is on, running lean, loss of power and high fuel consumption. I have replaced the o2 sensors, reset check engine code. light stays off and engine runs great for...
Something odd about what you posted. An engine that is running lean shouldn't be using a lot of fuel. Lean is when there isn't enough fuel going into the engine. Two other sensors that regulate fuel flow are the map sensor and throttle position sensor. Temp sensor generally would cause a rich condition but I'd test that too. Be sure to check for vacuum leaks at the manifold and lines as well as fittings... A vacuum leak will give the O2 sensor a lean reading...seeing that, the computer will try to compensate by adding fuel. Clearing codes can change the way it's running but as soon as the computer runs through it's internal diagnostics it will turn the light back on if there is a problem.
Mar 24, 2011 | 1997 Jeep Wrangler
Vehicle running lean
I would want to know why you think that it is running lean. Did you get a fault code from the ECU stating that the engine was running lean? The O2 sensor registers the fuel mixture to the ECU and then it changed the fuel acording to your engine needs. Is the check engine light on with a fault code? I have had a few friends use the "sea foam" or the "lucas fuel injection cleaner" to help with the O2 sensor problems. I haven't tried it myself, but they swear by it. They are also mechanics too. Hope this helps.
Dec 31, 2010 | 1997 Ford Explorer AWD
Engine codes run on 2004 Freestar
Make sure you have all the vacuum leaks repaired.
Disconnect the battery for two mins,codes my clear.
The codes you got are O2 Sensors,because of the vacuum leak,which leaned out the readings and set the codes.
May 03, 2010 | 2004 Ford Freestar
Check engine light keeps coming on. Lean fuel
A lean code can be caused by several different things. The most common, if you are getting a lean code on BOTH banks, is a dirty Mass Airflow Sensor (MAF) Cleaning the MAF usually fixes it.
If not, it could be caused by anything from a crack in a vacuum line to a bad fuel pump. (Anything that could make the engine run lean.)
Oct 31, 2009 | 1997 Mercury Cougar XR7
Have a 2004 nissan armada pathfinder.. The service engine soon light comes on and then flashes.. I had a mechanic check it and put a new fuel pump in it( computer says fuel lean) but the light is still...
ide need to know why he says its lean it could be a mis-fire or possibly and O2 sensor, dont drive if light is flashing could cause catalytic converter damage, i need to know the check engine light code is to further ***.
Jun 16, 2009 | Nissan Armada Cars & Trucks
I do have a check engine light i forgot the code but they explained the truck was running lean could the muffler cause this
No. your air/fuel mixture is off. The car runing lean is not allways a bad thing you will get alot better gas milage. :)
let me know what code it was maybe i can help somemore
May 17, 2009 | 2003 Lincoln Navigator
Maisto Ford Svt F150 Lightning P/U Truck Logo
448 people viewed this question
Top Maisto Toys Experts
ray gallant
17 SOUTH INDUSTRIES
17 SOUTH INDUSTRIES
Are you a Maisto Toy Expert? Answer questions, earn points and help others
