Epson Stylus photo 925\ missing felt on ink dock area
Epson Stylus photo 925 Is my printer suppose to have a felt fabric peice that sits where the cartridge carriage docks after printing or in off position?
If so where can I order this part?
I have Epson stylus photo 925 and get horizontal lines on printed page. I have run the Print Head Alignment program but the printout is too light to see. Aolution?
Hi
I suggest you clean it manually by removing the print head and then rub the print head in a plain paper with isopropyl alcohol until ink flows. Return the ink cartridge into the printer and run the print nozzle for 2-3 times.
Please let me know if you need more help.
Mar 05, 2011 | Epson Stylus Photo 925 InkJet Printer
Tip
Manual Counter Reset Method
To manually reset the Ink Jet Counter that compels you to clean your waste pads. For the tip on how to clean your ink waste pads go here.
Please Note: In some cases, your printer may be leaking ink so much and so often that not only does your ink pads need cleaning, but you may need to replace the ink reservoir on your printer or you will have a leaking mess on your hands. This is a decision and judgment only you can make. If your printer is leaking quite of lot of ink, you may have to take it to an authorized Epson Repair Shop or Person. Find an authorized location by starting at Epson.com
The solution below is valid for most of the following printer models listed below this solution, some listed may not work, some not listed may also work it varies as this method is listed below is illegal for an authorized Epson Tech to release.
Thanks to the many user boards on the Internet for this solution that I know has worked for people I've helped here on FixYa.
Don't be discouraged if it doesn't work the first time. The key is in pressing the buttons exactly at the same time. So if this doesn't work the first time, try again and try again. Most people state they get it eventually.
[thanks to fixyourownprinter.com for the crux of this particular solution]
"Printer Onboard Control Panel Key Sequence"
"Press and hold the paper feed, paper switch and the power switch.
Once the power light and paper light flashes twice and the other lights are flashing release the paper feed and paper switch "and then press the paper feed switch".
The power, paper and ink lights will flash twice. At this point the protection counter has been reset."
Don't give up, if it does not reset the first time. The timing is tricky for some people.
Supported Epson Models that I am aware of, others not listed may work and some listed also may not work, it varies but don't be discouraged to try and try again.
You can also try the software download solution listed in this tip I posted.
Epson Stylus Сolor 400
Epson Stylus Сolor 440
Epson Stylus Color 480 LPT
Epson Stylus Color 480SXU / 580
Epson Stylus Сolor 600
Epson Stylus Сolor 640
Epson Stylus Сolor 660
Epson Stylus Сolor 670
Epson Stylus Color 680 / 777
Epson Stylus Сolor 740
Epson Stylus Сolor 760
Epson Stylus Сolor 800 / 850
Epson Stylus Сolor 860
Epson Stylus Color 880
Epson Stylus Color 900 / EM-900C
Epson Stylus Color 980
Epson Stylus Сolor 1160
Epson Stylus Color 1520
Epson Stylus Color 3000
Epson Stylus C20 / C40 / CL-750
Epson Stylus C41 / C42 / C43 / C44 / C45 / C46 / C47 / C48 **
Epson Stylus C50
Epson Stylus C60
Epson Stylus C61 / C62 **
Epson Stylus C63 / C64 **
Epson Stylus C65 / C66 and PE **
Epson Stylus C67 / C68 / D68 and PE **
Epson Stylus C70 **
Epson Stylus C80 **
Epson Stylus C82 **
Epson Stylus C83 / C84 **
Epson Stylus C85 / C86 and PE **
Epson Stylus C87 / C88 / D88 and PE **
Epson Stylus Photo RX420 / RX425 / RX430 **
Epson Stylus Photo RX500 / RX510**
Epson Stylus Photo RX520 **
Epson Stylus Photo RX600 / RX610 **
Epson Stylus Photo RX620 **
Epson Stylus Photo RX700 **
Epson Stylus CX3100 / CX3200 **
Epson Stylus CX3500 / CX3600 / CX3650 **
Epson Stylus CX3700 **
Epson Stylus CX3800 / CX3810 / DX3800 **
Epson Stylus CX4500 **
Epson Stylus CX4600 **
Epson Stylus CX4100 / CX4200 **
Epson Stylus CX4700 / CX4800 **
Epson Stylus DX4200 / DX4800 **
Epson Stylus CX5100 / CX5200 **
Epson Stylus CX5300 / CX5400 **
Epson Stylus CX6400 / CX6600 **
Epson Stylus CX6300 / CX6500 **
Epson Stylus CX7800 **
Epson PictureMate
Epson Stylus Photo
Epson Stylus Photo EX
Epson Stylus Photo 700 / IP-100
Epson Stylus Photo 750 / PM-770C
Epson Stylus Photo 780 / 790 / PM-780C
Epson Stylus Photo 810 / 820
Epson Stylus Photo 820 **
Epson Stylus Photo 825 / 915
Epson Stylus Photo 830 / 830U **
Epson Stylus Photo 870 / PM-875DC
Epson Stylus Photo R200 / R210 **
Epson Stylus Photo R220 / R230 **
Epson Stylus Photo R300 / R310 **
Epson Stylus Photo R320 **
Epson Stylus Photo R800 / PX-G900 **
Epson Stylus Photo R1800 **
Epson Stylus Photo R2400 **
Epson Stylus Photo 890
Epson Stylus Photo PM-890C
Epson Stylus Photo PM-A700 **
Epson Stylus Photo PM-G720 **
Epson Stylus Photo PM-970C **
Epson Stylus Photo 895/ 785EPX
Epson Stylus Photo 900 **
Epson Stylus Photo 925 / 935 **
Epson Stylus Photo 950 / 960 / PM-950C **
Epson Stylus Photo 1200 / PM-3000C
Epson Stylus Photo 1270 / PM-3300C
Epson Stylus Photo 1280 / PM-3500C
Epson Stylus Photo 1290
Epson Stylus Photo 2000P
Epson Stylus Photo 2100 **
Epson Stylus Photo 2200 / PM-4000EPX **
Epson Stylus Pro 5000 / PM-5000C
on Sep 17, 2008 | Epson RX620 All-In-One InkJet Photo...
I have an Epson stylus photo 925 printer. It is only printing out the top half of pages. Any solutions?
This is usually caused by the purge unit or capping assembly. Epsons have a bat habit of the purge tube falling off of the bottom of the capping assembly.
The purge unit is used the **** a little ink out of the printhead. Inkjets do this to keep the nozzles full of fresh ink. Sometimes the hose will come off of the bottom of the head capping assembly on the top of the purge unit preventing the purge pump from having any effect. This assembly should be on the right side inside the printer where the head sits when the machine is off. If you can get the head to move to the center of travel you can unplug the machine, shine a light into the right side and inspect the assembly. Depending on use it could be quite dirty with old ink making it difficult to inspect. If the rubber cap is missing or misaligned, or if there looks like there is too much old ink you should be able to tell with the visual inspection. If the tube has come off the bottom of the assembly you may be able to see that as well. If you just cannot tell, you'll have to decide if you want to try new ink cartridges or not. This can be an expensive test, but often just old cartridges can cause similar problems. If not, the machine would have to be disassembled and have the purge unit removed for a closer inspection and cleaning or repair.
Oct 07, 2010 | Epson Stylus Photo 925 InkJet Printer
ERROR MESSAGE EPSON 925
Epson programmed their printer to monitor the waste ink counter and your printer has reached the maximum value allowed, you have to reset your printer to clear the waste ink counter.
You may read the information regarding "end of life" and "waste ink counter" here: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
To reset the counter, download re-setter program here, install and follow the instruction in the web site.
Good luck and thank you for using FixYa.
Feb 27, 2010 | Epson Stylus Photo 925 InkJet Printer
Photo 925 broke print and i need to replace it
It is probably cheaper ,unfortunately,to replace the printer.Heads are roughly $60 US and it takes a tech to install plus new ink required to seal the vacuum.
Jun 20, 2009 | Epson Stylus Photo 925 InkJet Printer
Need replacement waste ink pad
Hi...
so bye bye waste pad... can't find any replacements but this is my recommendation for you a waste tank... It's what I did on my 2 Epson Printers... Click the link to get the idea...
waste tank
Or you can use some tissue papers to replace what was thrown away.
Happy Fixya...
Feb 28, 2009 | Epson Stylus Photo 925 InkJet Printer
Printer Head cleaning
I've encountered the same situation with my 925. It requires routine cleaning. Try using name brand ink if you aren't already. Cheap ink has a tendancy to dry and clog at a quicker rate. Also, be sure to turn off the printer when you are finished with it. From what I understand, when you shut it off, it caps the ink nozzles like putting the lid on a ketchup bottle.
When doing a job with lots of ink usage, use a quality paper and do a nozzle cleaning right before hand. Hope this helps.
Jun 09, 2008 | Epson Stylus Photo 925 InkJet Printer
Roller guide came off
so what are you asking? you can get them replaced you can get some tape or super glue if it broke and if u can find all the peices otherwise it shouldnt hurt it to have the guide at the end of the printing cycle go bad
May 28, 2008 | Epson Stylus Photo R800 InkJet Printer
Ink not empty
You have confused the software in either changing a cartridge when not required or having a chip failure whilst changing multiple cartridges.
Full info on how to get out of this is on my site.
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Apr 13, 2008 | Epson RX620 All-In-One InkJet Photo...
50 people viewed this question
k24674
