Mukini does make inline fuel pumps. If there is a wire going to it then it is more than likely a fuel pump. I would replace the fuel filter, and air filter. I would also purchase a can of Seafoam cleaner at most auto parts stores. Pour in the correct amount in the fuel tank, as listed in the directions on the can. I have seen this work wonders on small engines with fuel problems.
Had the same problem with an almost new Craftsman w/ Intek 20.0 HP. Check all the "usual suspects" and had to have a tech come out. He had me start it. It ran for a few minutes and stopped (per usual). He immediately went to the Anti-Backfire solenoid. It is an electrically operated "plunger-style" fuel line blocker. They are famous for going bad. The part is about $65 and its sole purpose is to starve the engine of its fuel supply at shutdown so it won't backfire. If it is disabled, the user must throttle the engine down for 10 seconds or so before turning the key off in order to avoid backfires. Gee... let's see, 10 seconds of my time each time I use the mower vs $65 part ... No contest! Remove the solenoid, take a pair of electrician side cutters and snip off the tip of the plunger and reinstall it. Problem solved ! ! !
