Question about Intellinet Active Networking Intellinet Wireless Router with 4 Port Switch (521246)
Username and password not working to gain access to router.
    Brigadier General:
  • 5,158 Answers
Default is admin and password 1234
Posted on Sep 07, 2009
Iwould like to change my password for WIFI
This is easy:
Understand that you will need two passwords. The first will be the password to be able to access your router through a computer that is hooked up to it. the second password will be the one you will want to create for the wifi access by other wireless devices.
Google the make and model of your router and navigate to the manufacturer's website. At that point you will download or look at the manual for that router, and in the manual should be specific instructions on how to access the router, and then change the wireless password.
From a computer connected to the router either wirelessly or by an Ethernet cable, you will need to open an Internet browser and then you wil type in the router's IP address into the address bar of your browser. Typically it is 192.168.0.1 or 192.168.1.1
From this point you should see the username and password page for access to the router.
Most manufacturers of routers set the default username to be "admin" and the password is usually the word "password" or it is simply to leave the password section blank. If you already have a user name and password for the router, you will need that for access. If after trying to find access to the router, you are unable to either use the manufacturers default or you cannot remember the username and password you had previously assigned, then you can reset the router two factory condition by pressing a small recessed button present somewhere on the router. At that point the router will be set to its original default settings, and the manufacturer's manual should be able to tell you how to gain access with its default username and password.
Apr 22, 2014 | Computers & Internet
I know my password and username but it says invalide username and password
Either you've (1) entered the credentials incorrectly, (2) remembered them wrong or (3) someone has gained access to the router and changed them.
You can solve this problem only if you have physical access to the router. You should locate the reset button on the router itself. This may be recessed to prevent accidental contact, and if so - will require depressing it with a pointed object such as a pen. Performing a reset will wipe all customized settings and restore the router to factory defaults. This means you will not have wifi access to the router or internet *if* you have changed it from the original factory setting. If you are attempting this via wifi, you will need to know what those wifi settings are or connect the computer via CAT 5 network cable to one of the LAN jacks or ports on the router. Once you have found the the default wifi settings - or - have plugged the computer into a LAN jack, reboot the computer. Next, press and hold the reset button for 30 seconds while it is plugged in & powered up.
This will start the restoration of the factory default settings and cause a reboot the router. The PC will obtain an IP address automatically if connected by cable - or prompt you for the wifi's SSID and security code after it boots up. Enter the wifi factory defaults to gain access to the router and internet.
Next, gain access to the router's "set up" pages. The set up page is usually access by opening your web browser and typing 192.168.0.1 or 192.168.1.1, or similar private IP address in the address bar. Your manual will have these details. If successful, you will be prompted to provide the router username and password. Again, the factory defaults are in your manual - popular username defaults are "admin" or "root" and popular passwords are: ""admin" or "password"
If successful, you're "in". You should make changes as necessary to prevent others from gaining unauthorized access - again. Do not reuse any of the previous credentials if possible. This means you should (1) change the password (and admin if allowed) fields to something only you would know and do not use words that appear in a dictionary. A mix of upper and lower case letters, numbers and symbols should be used. (2) Change the SSID to something other than the default. (3) Choose the option of NOT broadcasting the SSID. (4) Select WPA or WPA2 security. WEP is NO longer considered secure and should not be used. (5) Create another "password" for the WPA security as prompted. You will have to update every device that you wish to give access to the internet; this includes laptops, tablets, game consoles, wifi enabled cell phones, etc. You can make other changes as needed - as these are only the bare *minimum* changes you should make. Be sure your changes are saved before moving to other set up pages or rebooting the router.
Finally, write down the router's admin, password, SSID, security type (WPA or WPA2), security code and the IP address on a small piece of paper. Tape it to the underside of your router. This way, it will remain out of view but readily available to you should you ever forget this information and will save you from having to do all of this again.
Feb 26, 2014 | Computers & Internet
I cannot reset my password
Im presuming its your internet connection password ?
Your Internet service provider (ISP) requires a username and password to access service features, including Internet and email.
Your ISP should provide this information when you set up your Internet service.
Typically, once you complete the setup and save the information, your router or modem transmits it behind the scenes when you try to access the Internet.
As a result, the username and password can be easily forgotten because they are not used daily.
If you reset your router or simply forget the password, gaining access to network resources and the Internet becomes a challenge.
Call your ISP's technical support department.
Many ISPs set a default username and password for their routers.
If you didn't change the username and password, your ISP can provide the original information.
Before you hang up, make sure the information is correct by entering it and trying to connect to the Internet.
If the information is incorrect and you still cannot get a connection, keep the information for later reference.
Call your router's manufacturer.
The manufacturer of your router sets a username and password prior to shipping the device to your ISP.
Look at the router for the contact information of the manufacturer.
Call their customer service or technical support department and ask for the default information.
Reset your router.
If you changed your router's username and password and cannot remember what you entered, you may have to reset the router.
Insert the resource CD into your computer's CD drive.
When the software installation program starts, search the screen for "Resources" or "Documentation" or "User Manual."
Click the documentation link and search the table of contents for resetting the router.
When you reset the router, the username and password return to the default set by your ISP or manufacturer.
Enter the information provided by your ISP or manufacturer.
Hope this helps.
Nov 15, 2012 | Computers & Internet
How do i change my password and username
If you have not set one up before the username and password will be in black writing on the back of the router, the usual ways to gain access to this is using a webpage Http://routerloging.net or through the ip "internet Protocol" 192.168.1.100 should say on the router which way to do it after you gain access to the router go to the security setup and follow the on-screen instructions
Jun 27, 2011 | SMC : Cable/DSL Broadband Router...
Where do I look on my "main" computer (hard wired
Hi dkusner,
Welcome to Fixya. If you need your Wep/Wpa Key (Passphrase) we can access the Wireless Settings Page of the router to obtain the information needed.
To access the router page you need a working computer that is connected to the router. To access your router you need to use a computer that is connected to it. Open a Browser then type 192.168.0.1 or http://routerlogin.net. The Default username is admin and the password is password. Password is case sensitive.
Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key (Wep/Wpa Key) or Passphrase. The Network Key serves as a password or security code on your network to make it secure. Network Key is case sensitive.
Don't forget to say thanks. Thanks for using Fixya
Feb 10, 2011 | NetGear WGR614 Wireless Router
I must have recorded my password incorrectly because I cannot gain wireless access for my kindle from my router. I get the message that my password is incorrect.
log into the router 192.168.1.1 username blank and password admin if default
click wireless/wireless security and double check make sure you use zero not the o button
Jan 07, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I changed my password but I forgot it
Do you have a Linksys router and you have forgotten your password or you want to reset the password to the default. Firstly you must have physical access to the router. This article is basically for WRT54g and model BEFW11S4
If you have changed the password from the default password and have forgotten the default or your router did not come with any documentation.
To regain access to the router try the following. In the username field leaveit blank and in the password field type admin
Username / leave blank
password / admin
The Rest Button on a Linksys Router
To reset the router
While the back of your router might look different, the reset button is usually clearly marked. To reset the router to the default password, insert something thin--like a pencil point--and depress the red button. Hold that for a few seconds. The password for your Linksys router should have reverted to its default.
Try accessing it from a machine that is plugged directly into it. The default address is usually http://192.168.1.1. When you gain access to the router then you can change the password to any word of your choice.
May 28, 2010 | Linksys Wireless-G WRT54G Router
My wireless HP prn stopped working suddenly with NetGear router
You need to go into the netgear router settings online with a computer that is attached to the router. You enter this:192.168.0.1 in the address bar to gain access.You need to know your username and password to gain access to the menu. Then check the wireless settings to see or change the passphrase. Good Luck
Jul 11, 2009 | Computers & Internet
Hi, I want to connect a PS3 to my wireless router but have forgotten the password?
If you have never actually set a password, go to eh IP Address 192.168.1.1 OR 192.168.2.1. The username field is blank and the password field is admin.
If you have actually forgotten the password, you need to reset the router. You can do this by gaining physical access to your router. There should be a reset button (or hole) in the back of it. You need a pin or something really skinny that is able to fit inside there. Hold the button for 20 or 30 seconds. After the router lights stop blinking about, the router is fully reset to factory details. Go to the IP Address 192.168.1.1, and the username and password is the same as above.
Dec 27, 2008 | Linksys Wireless-G Broadband Router
Intellinet Active Networking Intellinet Wireless Router with 4 Port Switch (521246) Logo
434 people viewed this question
Top Intellinet Active Networking Computers & Internet Experts
Terry
Prashant M
Prashant M
Tech support
Tech support
Are you an Intellinet Active Networking Computer and Internet Expert? Answer questions, earn points and help others
