Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door won't close, with out hold down on button.
Starts to close, then comes back up. Green light on control, and light on
motor flash. If you hold down button on wall control, or either remote it will close all the way. The door returns to open without a problem. I have checked for any think breaking the safety light, and found nothing.
    President:
  • 3,197 Answers
If the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit and not blinking.
Posted on Sep 07, 2009
Testimonial: "That resolved my problem. Thank you for your assistance."
My garage door starts down then goes back and the motor light flashes 10 times. The owner's manual only refers up to 6 flashes.
Richard, what is the make of your GD Opener unit? However, make sure the antena wire on the unit is turned up. 2. sometimes direct sun on the sensors prevent operation from the remote. 3.adjust sensors on both sides making sure the green or red lights are on.4. check the remote battery ensuring red light works when you press the remote button. 5. finally, has on vacation switch on the unit has not been switched on. GL
Dec 01, 2014 | Building Materials
It is sears/craftsman K1026 139.53779 HBW 0709 . Button on the wall inside the garage will open, but does not close . it starts vibrating and the motor light flickering and no advancing. Only if you hold...
If the main light is flashing 10 times when you try to close the door it is a door sensor problem. Make sure the small light on each one is lit, not flickering and that one is not dimmer than the other. Tweak them a bit if necessary.
Oct 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Model 139.53684 Security+ Keyless Entry Garage Door Opener... Green light flashing on door control push button. Remotes no longer work. Can open and close garage door from keypad. Why is light...
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
Dec 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Okay, I'm having an issue with my Sears Craftsman garage door opener. Not exactly sure of the model number, but can dig it up if that's necessary. Symptoms: 1) Door opens fine from either wall button or...
It sounds like you have a problem with your wall button. I would remove the button from the wall and then disconnect the 2 wires on the back. Remember where they go as they are color coded. You can then momentarily touch the two wires together to check the operation. There isn't enough voltage there to bother you.
One thing to remember. If when the door reverses the main light flashes 10 times it is a door sensor problem and nothing else.
Sep 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Wont Close Craftsman 1/2 HP (1998)
What it is is the electric beams at the door are getting blinded buy the sun or out of line. They are the two black boxes on both sides of the door about a foot from the ground. Put a piece of card board in front of them not blocking the beam dut to block the sun. All that they are is safety beams for kids so they do not get hurt. If you have to move them to the top where the sun will not hit them. Sorry to say though you can not remove them all the way. Also make sure the lite on them is not blinking if so they are out of line.
Good Luck and Please Rate FixYa!
Mar 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Pressing remotes the door won't go u[
It sounds like you have the lock enguaged. When it is flashing it locks out all remote access. Hold the lock button for 3 seconds. The green light should go solid. On the issue of closing, it is most likely a safety eye issue. Hold down the wall button. If it closes it is the safety eyes. Holding the button overrides the safety eyes. Make sure that thelight on both eyes are both lit.
Jan 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
The remote opener reset button goes off and will not work
The green button is not a reset it is the program button.
If you hold the button down for about 20 seconds it will erase all codes. Then, press and release the button - press and hold the button on your remote for about 10 seconds. the next time you press it it should activate the door. Repeat the 2nd step for all additional remotes.
The lock button on the wall control locks out all radio signals for vacations etc.
If the lock has been activated the green led in the wall control will flash - when the lock is deactivated the led stays solid green.
Hope this helps
May 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
191 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
