Question about Garden
I have a featherlite that will not run
I have a featherlite le gas blower by Weedeater. My problem is that it is not getting gas. I have rebuilt the with a carb. kit, done all the checking, etc.. I can choke it and pull start it but no gas appears on the plug and it will not hit. It has a good spark. I can squirt gas into the cylinder and it will run until this burns up.I am just about ready to pitch it. HELP?
  • 388 Answers
Does it have a primer bulb? If so, check it for cracks, also check the fuel lines and the uptake filter in the fuel tank which may be clogged, check all the seals of the carb inder a magnifier to check for dirt or cracks...this is going to sound stupid but are you sure you put the carb back together correctly?
Posted on Sep 08, 2009
Testimonial: "bulldogchief! I did all mentioned, but after watching u tub pictoral I believe my trouble might be a crankcase gasket. I haven't had time to check yet"
  • bulldogchief
    bulldogchief Sep 08, 2009
    Ok, well I am glad you are going in the right direction. Cheers!
My weedeater 150 mph starts hard and barely runs at full throttle. I put in new gas, plug, and clean air filter. Please help. John
One cause of such a symptom could be an obstructed exhaust. Make sure the outlet of the muffler is not obstructed (ex. dirt dobber nest), also check the exhaust port by removing the muffler.
Feb 16, 2011 | Weedeater Featherlite Blower 18 Cc 150 Mph...
Weedeater featherlite seized shaft
If you are talking about your crank shaft being stuck, there is nothing you can do that will work for the long haul. Usually what happens to cause this problem is running straight ( no oil added to fuel) gas to these 2 cylce engines. When you get a "lean seizure', the engine slowly loses power then quits. If you leave it alone for a while, the pull rope will be harder but it will start. The second tome it does this..........well your done. time to buy a new one. Sorry.
Nov 10, 2010 | Weedeater Featherlite Blower 18 Cc 150 Mph...
I am needing a repair kit for gas tank on the weedeater featherlite 1500 where do I get repair parts at?
I have a Weedeater Featherlite SST and need to replace the fuel lines but do not know where they go is there a diagram that will show me this?
Nov 11, 2009 | Poulan Featherlite Gas Blower, with Low...
We have a featherlite gas blower model # F1 1500 LE - need part # for pull cord and assembly
Recoil starter pulley - Part # 530071792 (Rope & Handle NOT included)
Recoil starter spring - Part # 545008011
Hope this helps,
Dolf-
Oct 15, 2009 | Poulan Featherlite Gas Blower, with Low...
What is the gas/oil mixture ratio for the featherlite gas weedeater?
its a 40:1 ratio. remember to never tap the tap-n-go too hard or it will bend the shaft, and make the head hot to the touch, and eventually will melt the inside. And always keep fuel stabilizer in the gas, because if you dont, especially in winter and fall, it will clog the carb so you have to keep pumping the throttle to keep it running and you have to run it on half choke all the time
good luck!
,devin
Apr 25, 2009 | Poulan Featherlite Gas Blower, with Low...
Garden Logo
307 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
