Question about GE Spacemaker JVM1640SJ Microwave Oven
Everything works except the heating of food, etc.
Our LG microwave version LMVM1935SW works fine, the light, the control panel, the minutes the power level....it just does not heat. We had someone out once before and for $125 he took off the front panel and plugged one of the magnatrons back in.....this is not the case, everything is plugged in. Can anyone help??
    President:
  • 1,564 Answers
When the magnitron fails it will do one of two things, it will give no microwave action to the centerplate or it increases in strenghth many times to where it is very hazardous. Yours appears to be the first case. I;'m assuming that you've checked the fuse on the board, seeing you were already back in there to check the harness to the magnitron.
Posted on Sep 07, 2009
LMA1560SB microwave--everything works fine (lights, clock, turntable) except does not heat food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 16, 2011 | LG 1.5 Cu. Ft. Full-Size Microwave - Black
Everything on the microwave works (e.g., turntable lights, controls, etc.) except it will not heat food, defrost food etc. It sounds like a magnatron. Any Ideas before I call a tech? Is there a online...
It does sound like the magnetron, but you need to check the high voltage capacitor and diode because they can be the problem. I don't know if there is a online manual.
Apr 10, 2011 | Microwave Ovens
Microwave external underside light no longer works
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights fan can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 20, 2009 | Whirlpool MH1150XMQ Microwave Oven
Everything appears to work fine but it is not heating anymore.
If the microwave oven appears to be working but it is not heating the food, it is very possible that the magnetron, or its power supply has failed.
Jerry G.
May 03, 2009 | Hotpoint RVM1435 Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Mar 21, 2009 | GE JE1540 Microwave Oven
Sounds like you've had a failure in the microwave portion of the unit.
Microwave not heating problems when the timer/controller board appears to function properly, are related to the following components -
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Jan 24, 2009 | GE JE1540 Microwave Oven
MICROWAVE NOT HEATING
I have the same problem. Everything seems to work except it doesn't heat up food.
I remember last time when it was working. I pressed the start botton before I closed the door. So it didn't start automatically, and I pushed start and it worked(it still heat up the food), but it doesn't work now. Help Please!!!
I have a Whirlpool Gold GH5184XPQ.
Thanks in advance
Aug 27, 2008 | Microwave Ovens
Everything works...Except for actually heating the food
It has a bad magnetron. This is the tube that provides the microwaves to heat the food. Not too easy to replace yourself but it can be done. Cost of magnetron is probably less than $50 or $60.
Dec 14, 2007 | Frigidaire PLMV168 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
87 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
