Question about Trango Team Losi 1/18 Mini-monster Baja Rtr 4wd Electric Truck
My mini baja dirt bike has an oil leak how do i fix it?
    Problem Solver:
  • 16 Answers
If its coming from the plug on the bottom which is the only way i can see is a messed up gasket
Posted on Jan 26, 2010
Need to find out the year of this Baja mini-bike
Hi, Jimmy for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
ID year of Baja Mini Bike DIY Go Kart Forum
MINI BIKE PICTURES
OldMiniBikes com
Baja Motorsports
Nov 03, 2016 | Electric Razor Pocket Rocket Scooter Mini...
Baja warrior 196cc mini bike engine torque specs ???
Hi, Randall for more information about your question and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Baja MB 200 Operator Manual
Baja Mini Bike Parts Baja Heat Parts Baja Mini Baja Parts
Mini Bike Easy Governor Bypass 1080P
http://docsfiles.com/pdf_baja_bike_manual.html
Mar 22, 2016 | Motorcycles
Oil is coming out of the vacuum line just above the front sprocket on my Apollo DB 125cc pit bike
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.miniriders.com/chinese-mini-s/35846-apollo-125cc-pitbike.html
new SSR 125 pitbike has oil leaking need help
Apollo DB X7 125cc Manual
http://mypitbike.ru/downloads/OrionAssemblyInstructions.pdf
http://getthemax.com/shop/powersports-products/manuals/apollo-125cc-dirt-bike-owners-manual-pdf
Mar 19, 2016 | Pit Motorcycles
My Baja 196cc takes off when I start it don't know why just that the bike was given to me recently, no manual
Hi, Jeff your mini bike has a centrifugal clutch and the previous owner may have tried to modify/bypass the governor for more speed if not done properly it will give you the undesired result which can be easily fixed by watching the video below I am sorry you can't find the first and best tool you ever bought for your Baja but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.Mini Bike Easy Governor Bypass 1080P
http://www.bajamotorsports.com/system/documents/86_OWNERS_MANUAL_-_WR65_Warrior_Mini_Bike_US_VIN_prefix_LUAH_.pdf
Mini Baja 6 5hp motor or other problems on 4Strokes com Forums
Jan 01, 2016 | Motorcycles
How do I start a baja mini bike when I havent started it since fall
drain oil -- put fresh oil in it -- drain gas -- put fresh gas in it -- charge battery if it has one -- and it should start
Feb 26, 2015 | Motorcycles
I havent started my baja mini bike since last fall and now it wont start it seems to be not getting any gas
Chances are the carb is plugged up with stale gas. The carb will need to be disassembled and thoroughly cleaned, including all passages.
May 20, 2010 | Mini Motorized Bike
196 cc baja mini bike dies if I try and give throttle
Well i had the same Baja mini bike and to be honest with you, you will run into alot more problems with that bike bec they build them so cheap, I and alot of others had 1 thing go after the other on that modle and to me they just aint worth the trouble or money, But check the coil and make sure to
Jul 21, 2009 | Mini Motorized Bike
2004 honda shadow 600 VLX leaking fork seal bike has 600 miles on it should I replace left and right if only right is leaking.
check first to see if the leaking fork has any rust pitting on the chrome,if it has and its a very small blemish then fettle it off first,and just replace the leaking seal,as the saying goes..if it aint broke dont fix it,if the seals had been in the forks for years and the bike not used then consider replacing both..
Jun 05, 2009 | 1986 Honda VT 1100 C
Drain and change oil
I can't tell you all the particulars from the limited amount of pictures of your bike. -Remove the oil drain bolt on the bottom of the crankcase (the universal bolt size for bikes use a 17mm wrench). -Drain the oil (remember to recycle). -Re-install the drain bolt with a new sealing washer if necessary. -The oil fill cap should be some where on the top of the crankcase. About 1 or 25mm in diameter with a raised tab for turning. -Fill with recommended oil. -There are 2 ways to check oil level on dirt bikes: 1) Oil level check bolt. On the right side cover. 2) Oil level site glass. A 1 round piece of glass on the side of the crankcase. Usually by the kick start & R brake lever. -Always check the oil level with the bike upright (as if you were sitting on it). -Check bolt - fill with oil slowly until oil comes out of the check bolt and re-install it. -Sight glass - fill with oil to cover 3/4 of the sight glass. -Remember to hold the bike upright when adding oil.,
Nov 10, 2008 | 2008 Derbi Senda Baja 125 R
Trango Team Losi 1/18 Mini-monster Baja Rtr 4wd Electric Truck Logo
460 people viewed this question
Top Trango Toys Experts
ray gallant
Are you a Trango Toy Expert? Answer questions, earn points and help others
