Question about Samsung ML-2510 Laser Printer
Ml 2510 printer will not print on Mac
Exactly the same problem on Mac Pro OS X 10.4.11
Samsung ML-2510 Printer will not work with Macbook Pro - OS X
try to use the Generic drivers and not the Samsung ML driver for your model. In the drivers list type in GEN and it'll show up.
Dec 12, 2009 | Samsung ML-2510 Laser Printer
Samsung ML-2510 will not print from MAC OS on Macbook
This printer has problems with Leopard last updates.
Contact Apple to see if a patch is available to run the printer on updated Leopard:
Apple - How to Contact Us.
Regards.
May 23, 2009 | Samsung ML-2510 Laser Printer
Installation problems SamSung ML 2510 printer with Windows XP
Why no updates? No windows validation? That could be your problem if that's the case.
If not, I suggest going to Windows update and at least installing all critical updates, if not SP3 as well, and try again
May 18, 2009 | Samsung ML-2510 Laser Printer
Driver for Samsung ML-1640 for WIN98SE
I got the same problem. It seems they did not develop specific drivers for win98se. However, I found that you can print using the drivers for the old Samsung ML-2510. Win98se drivers for that printer can still be downloaded from Samsung website. I've been using the 2510 drivers with the 1640 printer for a couple of months, and worked fine so far. It seems very little change in electronics from the 2510 to the 1640 model.
You need also Virtual Printer Port for USB from microsoft.
Jan 07, 2009 | Samsung ML-1640 Monochrome Laser Printer
Hi, sorry to hear you are having problems,
OK, first of all, you can stop worrying about solution #3, this printer is a USB or Parallel, there is no networking on this printer so no possibility of an AppleTalk connection.
You say you have downloaded the latest version of the driver from the Samsung website.
And, the Mac is connected DIRECTLY to the printer via USB.... ( It won't work if it's connected to a PC and then shared.. well it might work but I have not been able to make this kind of connection work...)
Well, if this is the case and you are unable to print while the PC prints fine, I expect that it is over the Parallel port or do you plug and un-plug between the Mac and PC...
It might be that the printer needs to reset after switching between the Mac and the PC, Shut off the Printer, I mean really, shut it down, unplug it for 30 seconds then connect it to the Mac and restart the Mac and start up the printer....
If it still does not work, do you have another Mac you can connect to for testing?
Also, the first test should not be FireFox, open the Text Edit app and type ( TEST ) and just print that...
Give that a whirl..
Dec 22, 2008 | Samsung ML-2510 Laser Printer
I had the same problem and spent some time trolling the Net. But....I found it.
Run installer from CD.
Tthen go to system preferences > print and fax
Delete the ml-2510 by clicking the minus square
Click the add square..
Select the ml-2510 again, and make sure that at the bottom of this window, under the "Print Using:" field, you again select the ml-2510.
Click add.
That's it! You're good to go!
Aug 05, 2008 | Samsung ML-2510 Laser Printer
How to print from DOS?
type
prn and then the file location
you will be able to get printouts from DOS
Jun 09, 2008 | Samsung ML-2510 Laser Printer
I had the same problem and found the solution on the Apple discussion boards. Apparently, OSX 10.4 installs the printer as a Lexmark 510 series, not a Samsung ML-2510.
Just add a new printer and change the type from Lexmark 510 series to ML-2510 series.
Worked a charm for me!
See: http://discussions.apple.com/thread.jspa?messageID=5955598
Aug 12, 2007 | Samsung ML 2010 Laser Printer
Samsung ML-2510 Laser Printer Logo
89 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
