I have a busted screen on a Sharp LC-52SB55U 52 in. 1080p LCD HDTV. What do I need to repair it?
  • 2 more comments
  • kingofkings7 Sep 07, 2009
    okay i have a sharp 52inch LCD
    tv the screen is cracked what is the cost to fix it???
  • kingofkings7 Sep 10, 2009
    thank you is there anyway i could
    get that part at a cheper price
  • SD Tech
    SD Tech May 11, 2010
    Part Number
    LK520D3LW10Z1
    Description
    52" PANEL MODULE
    List
    $2,093.89
  • SD Tech
    free advice---if the LCD screen is cracked, busted or shattered--buy a new tv---The cost of the panel is as much or more then the set cost. Sorry, SD TECH
4 Suggested Answers
  • 16 Answers
SOURCE: Sharp LC46SB54U 46-Inch 1080p LCD HDTV Shattered LCD Screen.
it would be very expensive for replacing the screen,even the dealer won't afford that.
Posted on Mar 31, 2009
  • 10865 Answers
SOURCE: I can't find the owner's/TV manual for Sharp AQUOS
http://www.sharpusa.com/files/tel_man_LC46D43U.pdf
Posted on Jun 04, 2009
bshldn
  • 736 Answers
SOURCE: Sharp AQUOS 52" 1080p 120Hz Flat-Panel LCD HDTV
Press the menu button and scroll over to the setup sub category. Scroll down to reset and press enter. Select yes and then enter. Select yes again and press enter. The television will turn itself off and then back on.
If that basic reset doesn't work call 877-332-7867 to be walked through the no sound troubleshooting up to an INIT. I cannot put the steps for an INIT into print because any wrong move could erase everything from your television.
Posted on Dec 29, 2010
Sharp LC-26DV24U has Black screen only
The Video/ luminance. or the power voltage supply line is not
working. needs repair.
Nov 01, 2012 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
LC-52SB55U Sharp flat screen tv audio only but no picture
Backlight is possible but if it is out you should be able to see that by looking from rear of set---most can be seen---if both are out (usually there are 2) it is likely the power source that fires them or a related issue.
Mar 26, 2012 | Sharp Televison & Video
How do I hook the Sharp LC-52sb55u up to the internet? To get Netflix mainly. Also, is it possible to stream tv directly to the tv, in place of cable
Your HDTV would have to have internet connectivity, either an RJ-45 ethernet jack on the rear panel or wi-fi capability. Sharp calls it the AQUOS NET feature on the TV and is usually an ethernet port. If your TV does not have this capability, you can use a laptop and hook this up to your HDTV. You still need high-speed internet service and a Netflix account.
Mar 13, 2011 | Sharp LC52SB55U LCD TV
Cannot get vga out put from a toshiba satellite to work with #4 input on the sharp lc-52sb55u
I realized I had not addressed my display settings to allow out put to
an alternate screen
Oct 09, 2009 | Sharp LC52SB55U LCD TV
I have a Sharp LC-52SB55u. IF THE TV SIGNAL IS
do you have left and right audio plugs connected?,if no,t you will hear stereo(as it will play threw one lead,but if in mono,you wont hear anything unless you plug the other lead in instead...
Aug 31, 2009 | Televison & Video
No picture controls
Check your owners manual look for the section that tells you how to adjust the televisions features using the on screen menu.You probably Have it set on auto adjust. You must turn this feature off, to use the manual controls. If this does not help go to the Sharp website and search the frequently asked questions and troubleshooting sections. Search for your problem and similar one that may have answers. If all this fails you, call technical service and ask them for help with your problem.Hope this helps you with your problem.
May 12, 2009 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Screen damaged from fall, colored vert lines on left side from the damge
Unfortunately the LCD panel would need to be replaced. Even if there is not any signs of damage to the outside portion of the panel, one of the inner screens may have been fractured. I am not sure if the panel would be available because if i'm not mistaken Sharp just started making replacement panels.
Apr 22, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp lc-46d64u broken screens
if the screen is broke its not worth the repair
Dec 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Picture Problem with Sharp LCD Model LC-42D43U
Hi...there,
It's seems your backlight inverter are busted... Need to replaced a new one.
Oct 15, 2008 | Sharp LC-42D43U 42 in. LCD HDTV
Televison & Video Logo
309 people viewed this question
Top Televison & Video Experts
