Question about LG Vu CU920 Cellular Phone
Lg vu phone took a dump after taking a picture
I have an lg vu and when I turn it on it goes to a blue screen which says : "Error Fatal file:fs_logr.c line 150 No space found in log" This is as far as I can go. Wil not allow me to charge or anything.
How to fix fatal error
In order to fix your phone, you need to be calm and patient. Make a wrong move and no one will be able to help you.
Method A) First thing to do is determine if you can connect your phone to your computericon1.png and open its file-system up. If you can, just replace the files that you messed up with the original files (If you didn't back-up get the files above) and then restart your phone.
Method B) If you cannot access your file-system because your phone is constantly rebooting, the first thing you need to do is turn your phone off. If the on/off button doesn't work, pull the battery out to turn it off (DON'T TURN IT ON). Then connect your phone to your computer (While its off, and it should turn on by itself and go into a charging screen) and see if you can access your phone's file-system, again if you can replace the messed up filesicon1.png, and restart your phone.
Method C) If you STILL can't access your phone file-system, don't fear there's still hope. Some users have reported success using this method, but it may or may not work for you. Try holding all 4 buttons (camera, lock/unlock, and volume rocker) on the side when the phone is starting, see if you can get it to a white screen with information stating "This phone has the IMEI. If you want to make the gang image erase the IMEI," if you see that, connecticon1.png your phone to your computer and replace the files, then restart.
Method D) If you find that you cannot stay in the gang image screen above, meaning it turns blue/black with error fatal when you connect to the phone, then do this: Remove the SIM card out and turn on the phone. Hopefully you will get the emergency call screen to display (where you can only make 911 calls). Connect to your phone now and replace the files.
__________________________________________________ _________________________________________________
I also got the fatal error screen and another way to get it to the gang image screen is to remove your sim card and leave the battery in then plug it into a wall charger and then use the four button thing to take it to the gang screen, after it gets there unplug it from the wall charger and plug it into the data cable and the screen will remain at the same position..
This is Basically a Factory Reset for your phone. Try the other solutionsicon1.png above, then go for this one. Kind of a..Last Resort i guess you could say.. This is also known as the "GrCobb Method"
I had the same type of problem and had trouble resolving it by putting back the files I thought I had changed. I was getting LG's 'blue screen of *****' with a message like Fatal Error: Dog: 1 or something like that. Here is what I did:
1. Downloadicon1.png the LG Vu firmware files from this site (http://www.lg-vu.com/index.php?topic=3902.0). Unzip it. These files contain the entire LGAPP firmware folder. Then unzip it. It should create a LGAPP directoryicon1.png with every file that was on your phone when you got it. I know DH said to not replace the entire LGAPP folder because it may brick your phone but, hey, it's already bricked so not a problem.
2. Get into EFS and connect with your phone. Get to the gang screen on your phone using the steps if you have to.
3. Rename the LGAPP folder to something else (LGAPP_bad). Do not delete it. There are some files that are read only and you get an error message replacing them when you copy the new GAPP on top of an existing LGAPP directory. This doesn't happen if you rename the old LGAPP to LGAPP_bad before you do the copy.
4. Copy the LGAPP directory you unzipped above to the phone and restart it.
That is what I did and it came back to a clean state as if you did a factory reset.
Hope that helps.
Jul 20, 2014 | LG Vu CU920 Cellular Phone
My phone is showing blue screen with "error fatal
1. remove the battery and power cable 2. remove the sim and memory card 3. reinstall eveything 4. estart your system
Jan 28, 2011 | LG Vu CU920 Cellular Phone
I have blue screen saying error fatal file:fs_device.c line: 110 Unexpected device read failure, page=91077
Here are some common causes of blue screen,
Also provides you sulotions of Blue Screen fix.
Click here to fix Blue Screen.
Feb 19, 2010 | LG Vu CU920 Cellular Phone
LG invision blue screen of death
Must be flashed. take it to your nearest lg service center.
Nov 20, 2009 | LG Invision CG630 Cell Phone
My lg vu has the blue screen of death and is saying... error fatal ui dog file????? what happened and can this b fixes?
My lg cu 920 has the blue screen of death and saying... error fatal ui dog file??????what happened can this b fixes?.
Oct 09, 2009 | LG Vu CU920 Cellular Phone
My lg view is stuck on a blue screen with a code showing....error fatal file dog ui. what do i do can it be fixed?
that is called the "LG blue screen of death"
you will have to restore it to factory settings.
follow the steps below:
1. Download the LG Vu firmware files from this site (http://www.lg-vu.com/index.php?topic=3902.0). Unzip it. These files contain the entire LGAPP firmware folder. Then unzip it. It should create a LGAPP directory with every file that was on your phone when you got it. I know DH said to not replace the entire LGAPP folder because it may brick your phone but, hey, it's already bricked so not a problem.
Oct 08, 2009 | LG Cell Phones
Dropped LG Vu CU920 phone in the pool.
You might want to go to ur local AT&T and ask them to look at it........
Jul 07, 2009 | LG Vu CU920 Cellular Phone
Blue screen Error Fatal file: dog: UI line: 0
take to be flashed.
at the phone repair shop..
Mar 13, 2009 | LG Vu CU920 Cellular Phone
My LG VU shows a blue screen with error fatal file:dof: UI line: 0
take it to the nearest phone repair shop ask for flashing Phone ROM
Read Only Memory.
Mar 07, 2009 | LG Vu CU920 Cellular Phone
LG Vu CU920 Cellular Phone Logo
132 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
