Question about HP OfficeJet 6110 All-In-One InkJet Printer
Keep getting Remove and Check Cartridge message even when I replace the black cartridge with a new HP one. How can this be fixed?
    President:
  • 1,564 Answers
I believe you have to press the "select" button or the "options" button. Both are located right under the LCD display
Posted on Sep 07, 2009
Replaced black print cartridge rejected.
Hi there remove the cartrideg & reset the printer first. After that off the printer. Now fix the cartridge in printer. Turn on again. If you face same problem then reset again with cartridge, give a test print from print preferrence. I hope your problem will solve then. Thanks & waiting for your feedback.
Mar 18, 2010 | HP OfficeJet 7410 All-In-One InkJet...
I keep getting the message "remove and check cartridge on right. I do this, but it doesn't solve the problem. The printer worked fine until I installed a new black ink cartridge. After so many times of...
The cartridge on the right is the black ink cartridge. The one on the left is the color.
Make sure you have pushed the cartridge in all of the way and that you have removed the tape cover from the cartridge before you insert it.
If you bought aftermarker or third party cartridges, you have a cartridge that is not filled properly. If you purchased it from a local retailer, return it and try another cartridge.
The Hp reads the levels from the gold connectors on the cartridge. If they are blocked, or damaged or the cartridge is not full, you will get this message.
Jan 14, 2010 | HP Photosmart 4180 All-in-One Printer
Hp c7820 printer 02 black catridge
Open the printer and remove the ink. Clean around the ink carriage and the under the ink with alcohol and a cotton swab. Pay special attention to areas with copper contacts. Keep in mind too that some printers will not print, even with full ink, if the exact type of ink it expected you to have installed is not right. Double check that the ink is correct against the manual or written instructions inside the printer using the number not the shape or color of the cartridge. Not every cartridge that fits the printer necessarily works.
Nov 13, 2009 | HP Photosmart C7180 All-In-One InkJet...
Get "remove and check print cartridges" on printer, a new black cartridge has been replaced but still get same message.
Is the new black cartridge that you fitted made by HP?
If it is not I would try with a new HP cartridge, I would also try replacing the colour cartridge.
Regards
Alan Hood
ami-man
Sep 26, 2009 | HP PSC 2410 All-In-One InkJet Printer
Hp PSC 950 gives me a message to remove and check black cartridge
Did you remove the tape from the contacts of the new black cartridge? If so once the new one is in, unplug the printer from power and power it back on, it should do a full check after a power on off.
Sep 23, 2009 | HP PSC 950 All-In-One InkJet Printer
"Remove and check color cartidge."
ok the problem is very common.initially remove both the cartridges.then unplug the printer from main outlet and plug back in.this will reset the printer circuit.then after u on the printer bring back the cartridge carriage to cartridge installation position.then first clean the circuit in the carriage that touches and sense your cartridge circuit with a damp cloth.both colour and black carriage circuit.then clean the cartridge circuit too even if its new.then install both the cartridges and close the door and off the printer again and on it after 30 seconds atleast.then check it should work normally.
Mar 25, 2009 | HP PSC 1610 All-In-One InkJet Printer
"Remove and Check Color Cartridge" won't go away w/ new cartridge
Replaced with brand new HP cartridges. If either one (black or color) is a refilled cartridge, my machine has issues.
Dec 13, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
My HP printer is displaying the following message: Remove and check cartridge. I have removed and checked the cartridge, even replacing the black cartridge and still get the same message.
One of the printer cartridges had a expiration date of 2008/9/2. I replaced the cartridge with a new one and the printer now works. Thanks for asking.
Sep 28, 2008 | Office Equipment & Supplies
PSC 2200 All 4 lights keep flashing the message is to remove and check cartridge.
Hey I figured out how to fix this problem. The problem is not the cartridge it is the clamp that holds the cartridge down if you look at the bottoms of the cartridges the offending cartridge is lower. I beleave it is the spring that gets tired in the hold down lever. What I did was put a piece of cardboard behind(above) the black plastic with spring in the lever. What I used was a coaster from the bar and that tightend it up enough and it worked right away.
thanks
Cory
Jun 30, 2008 | HP PSC 2210 All-In-One InkJet Printer
My Hp PSC 1350v
Hi, I really appericate all your efforts to fix the issue the issue usually occures if any one of the cartridge is defective or low in ink or both the cartridge are defective. We can isolate the issue only by removing the both the cartridges out of the printer and check for the expiry dates printed on the cartridges as if the cartridges are expired also leads to this message. If the cartridge are not expired and have minumial ink in it you can try the below procedure to isolate the defective cartridge Once the both the cartridges are out of the printer insert only the black cartridge in the printer and check for the message if the message is install color cartridge the black cartridge and printer is detecting fine. If the message is check right cartridge this shows that the black cartridge is defective. If the message is insert left cartridge or color cartridge remove the black cartridge out and insert only the color cartridge and check with the message if the message is insert the black cartridge the color cartridge is working fine. And when the color cartridge is in the printer and if the message prompts to check left or color cartridge the color cartridge seems to be defective so replace the defective one will fix the issue So in isolation we can find the defective cartridge and fix the issue by replacing the defective one.. Hope this will help you to fix the issue.. Wish you success. Regards, Barret.
Sep 12, 2007 | HP PSC 1350 All-In-One Thermal Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
90 people viewed this question
Seeker5211
Seeker5211
