Question about Westinghouse 19" Widescreen Flat Panel LCD Monitor
AS soon as I Turn On computer screen comees on for 2 seconds then shuts off immediately
    Brigadier General:
  • 5,158 Answers
I've repaired three LCD monitors with that issue before. it involves taking it apart and replacing all the capacitors that have failed. you can tell which ones have failed as the top of it will be swelled up.
robert
Posted on Sep 07, 2009
Howw do you reset user passwords on Acer Aspire one w/ windows 7 home basis
You would have to perform a factory restore. Turn off the computer, then turn the computer back on, but as soon as you push the power button to turn it on, immediately hold down the ALT key and tap on the F10 key about 2 times per second. Once a menu comes up, you can stop with the ALT and F10, and select the option that looks most like factory restore, and then follow the on-screen instructions to perform the factory restore.
Mar 01, 2012 | Acer Computers & Internet
My Medion MT6 desktop has developed a problem. When I power it up, the fans power up then shut down immediately. They then power up for a couple of seconds longer, then shut down. The process continues...
take it into a computer repair shop for a proper diagnosis
could be a faulty power supply or failing mother board
check that the power lead is properly connected top the pc
Jun 20, 2017 | Medion (40002895) CD-RW/DVD-ROM (Combo)...
I was watching TV and suddenly the screen went black. No picture, no sound. On/off timer LED on TV started blinking. I could not turn it on (or off) with remote or ON switch on TV. I found that if I...
The television is shutting itself off to protect itself. The blinking light is a code pattern. The specific code determines whether or not you need an LCD Controller Unit, Main Board, power supply or something else. You would need the service manual. There are parts distributors you can get it from and the parts as well. If soldering and tv repair is not something you are entirely familiar you may want to seek a tv repair person. The manufacturer's support may walk you through the service menus to complete a factory reset depending upon the symptoms.
Sep 28, 2010 | Televison & Video
Im getting blue screens right after the toshiba welcome screen thing as soon as the computer turns on. i have no recovery/installation discs as its a 2008 model and really wanna reboot it now
Probably the easiest way to resolve this issue is by following the steps outlined below.
1. Shut down the computer.
2. Turn the computer on and immediately press F8 repeatedly until you get the "Advanced Boot Options" menu.
3. use the down arrow to select "Safe Mode" and press enter.
4. Window is should start with a "Help" window.
5. In the help window there is an underlined "What is System Restore?"
Click on that and "Click to open System Restore"
6. click on that and a new window comes up recommending restoring to a previous state.
7. Click ok and the operating system should restore your computer successfully and reboot into normal mode.
//javaftper
Jul 31, 2010 | Toshiba Satellite Pro L300 Notebook
Push Button and Computer fan starts then immediately shuts off (1 Second) .Yellow light on front does the same comes on 1 second then off .Nothing else happens . It is a Dell Dual Core 2 fans.
chek your power unit or the cpu fan working or not if the cpu fan is not working computer will turnoff immediate to save it you better show you computer for technician soon
please rate this solution.....
Apr 11, 2010 | Dell Inspiron 531s Desktop Computer
Receiver shuts off as soon as I turn it on
having the same problem. it doesn'T Shut off immediately. but after 30 seconds or if I turn the volume up, then it shuts off
Dec 05, 2009 | Denon Audio Players & Recorders
My Acer LCD Monitor AL1707A goes blank after 2 seconds
Try this,
When laptop on booting immediately press del.
And the screen will run normally.
But if the screen is still white, force to press power button soon.
And it will shutting down.
After shutting down, repeat this action.
It will work.
Vincent-Jember
Nov 05, 2009 | Acer Computers & Internet
Sansa e260 won't turn on
Here are instructions on how to use recovery mode procedure to make the mp3
player turn on. Do the following steps:
1. Turn player off. Hold the power button down for 20 seconds to make sure
it shuts down then put the "Hold" switch ON. The Hold switch is located at
the top part of the mp3 player.
2. Now hold the "Record" button while you connect it to the computer. Keep
holding it until it finishes installing the new device.
Mar 16, 2008 | SanDisk Sansa e260 MP3 Player
Westinghouse 19" Widescreen Flat Panel LCD Monitor Logo
265 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Paul Bade
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
