Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Kenmore refrigerator leaking at water filter
We just hooked up the water line for our ice maker and filtered water dispenser. when we filled a cup with water, the filter started leaking out of the top. Any ideas?
  • scr 789 Dec 12, 2007
    having exactly the same issue, water leaks around filter assembly when we try fill glass, no water to dispensor.
  • sstarr Dec 08, 2008
    I've got the very same problem with my 18 month old side-by-side Kenmore (model 59432). I have NOT detached the lower front grill to investigate where the link is originating from, but my theroy is that there is a disruption in the plastic water line because of too much water pressure... maybe an o-ring or coupling failer?! The leak only happens when trying to engage the water despener and the a pool collects under the left-hand side, near the corner.
I am having the same problem, it leaks with a filter and without a filter, I even tried making it really really tight. What else could it be?
Posted on Sep 04, 2008
  • soccermom22 Sep 05, 2008
  • 126 Answers
Make sure old gasket came of with old filter or make sure it is real tight you should have got a wrench with the refrig.
Posted on Dec 14, 2007
How do I "Prime the Water Supply System" refereed to in use and care guide that came with my new Kenmore French Door Bottom Freezer, #253.70413411. Cannot find instructions in the manual only reference to...
Assuming you followed the water line installation directions and you have water available to your new refrigerator/freezer here is the rest of the "priming" info you requested. (basically it tells you how to run a bunch of water through the system by filling cups or glasses to remove any debris and/or air...
Automatic Ice & Water Dispenser
Priming the Water Supply System
1. Begin filling the tank by pressing and holding a drinking glass against the water dispenser paddle. 2. Keep the glass in this position until water comes out of the dispenser. It may take about 1½ minutes. 3. Continue dispensing water for about three minutes to flush the system and plumbing connections of any impurities (stopping to empty the glass as necessary).
Ice Maker Operation & Care After the refrigerator is installed properly and has cooled for several hours, the ice maker can produce ice within 24 hours. The ice maker will fill the ice bin from the rear. You must dispense some ice to force the ice forward in the bin. This will allow the bin to fill completely.
Turning the Fresh Food Ice Maker On and Off Ice production is controlled by the ice maker's On/Off icon on the control panel. Press and hold the "Ice Off" icon for three seconds to turn the ice maker "ON" or "OFF". The ice maker is turned off when the LED above the "Ice Off" icon is illuminated.
Using the Ice Maker after Installation Before making ice for the first time, be sure to prime the water supply system. Air in new plumbing lines can result in two or three empty ice maker cycles. Furthermore, if the system is not flushed, the first ice cubes may be discolored or have an odd flavor.
CAUTION
For proper dispenser operation, recommended water supply pressure should fall between 30 psi and 100 psi. Excessive pressure may cause water filter to malfunction.
NOTE The water dispenser has a built-in device that shuts off the water flow after three minutes of continuous use. To reset this shutoff device, simply release the dispenser paddle.
IMPORTANT On occasion, unusually small ice cubes may be noticed in the bucket or in dispensed ice. This could occur in normal operation of the ice maker. If you start seeing these more frequently, it may be an indication of low water pressure or the water filter needs to be replaced. As the water filter nears the end of its useful life and becomes clogged with particles, less water is delivered to the ice maker during each cycle. Remember, if it's been six months or longer since you last changed your water filter, replace the water filter with a new one. Poor quality household water may require the filter to be changed more frequently.
IMPORTANT Your ice maker is turned on at the factory so it can work as soon as you install your refrigerator. If you cannot connect a water supply, set the ice maker's On/Off icon to Off and turn off the water supply valve; otherwise, the ice maker's fill valve may make a loud chattering noise when it attempts to operate without water.
Hope this helps. Randy
Mar 02, 2015 | Kenmore Refrigerators
Frigidaier Side by side Fridge FRS23R4A water leaking from filter casing and no water to water dispensor
Cracked filter head our water line. Best bet is to pull filter head down and inspect water lines and head. Replace if needed
Aug 17, 2012 | Refrigerators
The water dispenser in my refrigerator ice maker is leaking
if you have recently changed your filter, had the water turned off, or disconnected from the ref this is a common problem. you have air in your water line. fill 5-6 large cups of water or until it stops spurting and your drip should go away
Apr 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker stopped making ice. water dispenser works.
might have a frizen line from the fill valve to the im, or possibly a bad fill valve... this is where the house water line hooks up to, these sometimes become defective.........
Apr 20, 2010 | KitchenAid KSCS25FKSS Side by Side...
Water dispenser stopped working then the tce maker
The fridge isnt getting water check supply line and filter.
Oct 04, 2009 | Kenmore Refrigerators
After changing the filter the ice maker would not work.
It needs to get the air out of the line before the water will fill the tray. When the line is opened up air will get inside and needs to bleed out first. On units with a water dispenser it is good to run it after a filter change to make the ice maker usable faster. An ice maker times the water for a fill not the amount of water since it uses a pressure regulator, so it does not know there is air in the line.
Sep 29, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker wont fill.water dispenser on door is working
Could be the filter. Can you bypass the filter? How about the incoming water line. Is there presure there?
Aug 26, 2009 | Frigidaire FRS26R4A Side by Side...
Water to ice maker isn't filling tray.
what is the inside temperature in the freezer? it has to be below 17 degrees before the ice maker even try's to work
Dec 11, 2008 | Frigidaire FRS26R4A Side by Side...
Jenn air jcd2389g side by side refrigerator water leak
sounds like a leak where your incoming water line hooks to the water valves might just need to tighten the coupling or a mouse has chewed through one or both of the lines access the lines on the back and watch while some one gets water out the door to locate the leak
Feb 11, 2008 | Jenn-Air JCD2389G Side by Side...
Ice maker leaking
Sometimes the frozen chunk of ice in the back of your ice tub is caused by the tub being overfilled. The ice cubes pile up so high that they come in contact with the defrost heating element in the bottom of the ice maker. This melts the already formed cubes and form a blob of ice in the rear of the tub.
If the "icicle" is forming even when the tub is relatively empty, then it is probably a leaking solenoid valve. This is an electric water valve that opens and closes according to demand. Like any valve, it has seats that eventually leak, especially in areas with hard water. This will need to be replaced. Water filters go a long way in increases the usefaul life span of the valve and will also improve the ice quality.
Dec 02, 2006 | Kenmore 53642 / 53644 Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
1,653 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
tootsie mason
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
