I am able to get pilot lit, but when releasing the pilot valve, the pilot flame goes out.
    President:
  • 3,433 Answers
Sounds like a defective thermocoupler. It's thatbulb that the pilot heats up. It needs to be replaced. Easy inexpensive fix.
Posted on Sep 07, 2009
Oven lights but then flame goes out as soon as I release the knob
The flame sensor seems to be bad.
When I light my pilot light, it stays on till I release the button ...
askville.amazon.com > Home > Home Improvement
Mar 18, 2008 - Similar Questions: light pilot stays till release button suggestions ... If you have held it for a long time and it still won't stay lit, then your thermocouple is bad.... the gas valve doesn't think a flame is burning the gas coming out of the pilot ... less likely but somewhat common is the gasvalve... if the knob you are ...
Troubleshooting Gas Range and Oven Problems ' Back ...
blog.etundra.com > Tundra's Tech Talk
Dec 15, 2015 | Fisher Paykel Fisher & Paykel 24-in...
Heater pilot light will not stay lit
The thermocouple is either too far from the pilot flame or is bad.
Feb 26, 2014 | Garden Treasures Patio Heaters
Why it doesn't stay lit
Replace the gas valve or thermocoupler.
Oct 15, 2013 | Coleman 5040-751 BackHome Open Flame Patio...
Flames goes out when pilot is released
It sounds like the thermocouple that senses whether the pilot is lit is bad. You need to replace the sensor.
Jan 17, 2013 | Heating & Cooling
Pilot don't stay lit after the gas control knob is release.
The thermocouple is bad and you will have to replace it...
The thermocouple is the thing that sticks up in the flame to sense that the flame is on... if it goes bad the pilot flame will not stay lit when you release the button...
heatman101
Dec 05, 2010 | Williams 3501922 (NG) Gas Compact Heater
How do i light pilot light?
Remove front cover,or just lower section if you can. they usually just need to be lifted up about an inch or so and pulled out. However some have covers that snap in place. After you remove cover locate gas valve. It should have a control knob on top with markings for on, off, and pilot. Set control to pilot. Follow lines from gas valve to burner compartment, one goes to main burner one ,small copper colored line is the thermocouple, other line is the pilot. Turn thermostat down as far as it will go. Make sure gas supply valve in line to heater is on and then depress pilot control , when you have pilot control depressed have a match or other small flame source close to pilot assembly. If it lights then hold down on pilot control for a couple of mins. Slowly release pilot control and if it stays lit turn gas control to on. Turn thermostat up to call for heat and burner should light. If pilot doesn't stay lit when you release pilot control then try again holding pilot down longer. If it still won't stay lit then thermocouple will need replace. Good luck. Thanks
Nov 22, 2010 | Williams 6508732 Gas Heater
Pilot wont stay lit when i release push down button on gas valve
Are you certain you are connecting the generator to the correct terminals? Is the pilot head partially blocked not allowing the flame to reach the generator even though the pilot is lit? Can you read the millivolts on the generator leads? Is the reading 400mV or higher? I assume it will be with a new generator but if it is not then the flame is not across the generator as it should be. If it is, be certain you are connecting the two leads properly and in the correct order. The generator has polarity so it needs to be connected to the valve properly. The tag up inside the heater should give you the correct locations for the white and red wires on the valve.
May 29, 2010 | Hayward 150000 BTU Millivolt Natural Gas...
I HAVE A DESA LP VENTLESS FIREPLACE AND THE PILOT WILL NOT STAY LIT
the heater makes use of a millivolt generator which generates a small dc voltage (500-750mv) that is applied to the pilot valve of your main gas valve. when you light your pilot, the flame bathes the generator with a flame. after a delay you release the pilot button. if the generator is working, the pilot valve will stay lit. if the generator is not working the flame will go out as soon as you release the pilot button. change the generator.
Oct 13, 2009 | Desa International Heating & Cooling
Oven pilot light will not stay lit
The thermocouple is bad this is the probe that sits next to the pilot,the pilot flame heats the thermocouple and then it sends a micro voltage to the valve to keep it lit.Goto hobartcorp.com and find your model then the part number.
Sep 04, 2008 | Vulcan 60L Gas Kitchen Range
Pilot light will not stay lit
is it full of dust my hot water used to do the same till i blew the dust and fluff out
Nov 18, 2007 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
