Question about Garden
I have a 2003, 20 hp, walker mower, and I cannot get the engine oil press light and beeper to go off. I've tried changing the oil and it still beeps and the light stays on. Is the oil pump electric? could a wire be off or could the oil pump actually be bad for no longer thank I've used it.. advise please Is there a way of checking without going into the engine? Jack Nethercot
  • 89 Answers
Have yoy tried to disconnect the battery cable for a minute that just just might reset it
Posted on Nov 04, 2009
Mower won't start - nothing but a flashing yellow light
PTO might be on . press brake pedal down also
Apr 26, 2016 | Light Garden
My toaster oven started beeping and showed a flashing error message. Anyone have any clue what may be wrong?
I suspect that the Logic Control Board is shot. If the unit is 1 year old or less try:
In the U.S.A., warranty is offered by Sunbeam Products, Inc., located in Boca Raton,Florida 33431. 1.800.334.0759
In Canada, this warranty is offered by Sunbeam Corporation (Canada) Limited,located at 5975 Falbourne Street, Mississauga, Ontario L5R 3V8
To refresh, the beeper should sound once. The definition of the Beeper from the manual follows:
BEEPERFUNCTION
(1) When you plug the unit in, the beeper sounds once and " - - - "appears in the LCD.
(2) When you press one of the four menu buttons the beeper will sound one time.
(3) When you press the adjustable button, every time you press the button, the beeper
will sound once. If you press the button continually, the beeper only sounds one time.
(4) When you press the start button the beeper will sound once, and ":" will flash, that means
the unit is in operation. Once the unit has begun the cooking cycle, the menu selection,
time or temperature cannot be changed. The unit must be stopped and reset.
(5) When the unit is in operation, press the stop button, the beeper will sound once and the unit
will stop operation.
(6) At the end of pre-set time, the unit will sound a long beep to remind you the work is done.
Jan 03, 2015 | Oster 6239 Toaster Oven with Convection...
How to replace seat in jetta beepa walker
Contact Jett's beeper manufacturers customer enquiries, they should be able to tell you who your local spare parts distributors are. I have changed similar material seats before and they usually just clip into place on the underside of the frame.Its a simple job
Aug 07, 2013 | Baby Gear
After running my Walker mower for about an hour,the beeper goes on & the clock reads ''lube''
Grab your grease gun and start looking for zerk fittings you may have missed when you greased your machine last. You will probably find a few you didn't know about. GOOD LUCK FRIEND.
Apr 25, 2010 | Blade WALKER LAWN MOWER DECK HUB BLADE...
Spacemaker xl (1999)low volume beep
According to the owner's manual (available here), there is a beeper volume on some models in this series. If yours has one, press it and then press 0 to 3 to control the volume (0 mutes the beeper and 3 is loudest).
If your model doesn't have the beeper volume control it's just that the beeper is going bad. They sometimes do that, getting faint or quitting entirely. You can't get a replacement beeper from GE, only the entire control circuit board.
The beeper is a piezoelectric type. Radio Shack sells a variety of beepers. If you know someone who can replace electronic components, they may have one that could be used on the board. Changing the beeper for one not the same as the original would not affect the oven's operation or safety, so that's an option. I'd do that myself if I were repairing this for a friend. But you might not be able to get a professional service shop to do this because of liability concerns. They would most likely replace the entire board.
With luck, your oven just has the volume down. Hope this has helped, and thanks for using Fixya!
Feb 13, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a 26 hp efi walker mower and the problem I am experencing is that the mower engine shuts down when forward movement is activated, mower stays on in reverse, I have 712 engine hrs and have just...
Sorry about this problem but i would suggest that you flush oil and get new oil into it. Please do this and your problem would be solved.
Regards
Sep 12, 2009 | Mtd Garden
Disabling the beep on a Kenmore microwave
I have Kenmore microwave model 721.61820100.
It has an "Option" button. Press it. The display say "NUMBER"
Then press "1". The display should say "SOUND" and then "OFF".
Press "Start" and that beast turns silent, well not really, but the beeps are goooone.
If for some reason you don't like it this way repeat the sequence and the sound this time will turn "ON".
Jun 05, 2008 | Kenmore 80809 Microwave Oven
Garden Logo
351 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
