Question about Vacuums
Model 8975-C - broken foot lever
Model 8975-C
the foot lever that holds the vacuum upright is broken [small plastic bent lever has snapped off].
Can it be replaced by me or do I have to go to a service depot? And where would I get such a part?
Is there an exploded view with part numbers somewhere online?
  • 4 Answers
I'm fairly upset with Bissell over this issue and considering switching to a better brand after constantly having to replace this item on every vacuum of theirs I've had. It is shocking that they would have a part that gets stomped by your foot and jerked with the entire weight of the vacuum made out of cheap plastic. The curved piece acts like a spring to hold the vacuum upright. Can you imagine a curved leaf spring made out of plastic?? In any case, they call this an "internal part" and therefore not user serviceable. You have to call their 800 number to get a dealer local to you, usually a sewing and vacuum place, and then get them to sell you the part. Otherwise, you are going to have to take the vacuum to them and have the dealer replace it.
Posted on Dec 01, 2009
  • 430 Answers
You have not listed a brand. You can google or search manufacturers repair parts on line with a brand and model.
Release pedals are generally spring loaded with a metal clamp inside the body. They are relatively easy to replace by removing the bottom plate on most vacs. Pay attention to how the original spring is loaded. Do not remove the old one til you have the new part in hand.
Posted on Sep 07, 2009
  • Chemist1961 Sep 07, 2009
How do i put the plastic bagless part back
I have an Bissel Cleanview Helix which I think is similar. The lock'n seal lever has to be in the unlock position first. Place the filter cup in first and then the Dirt container next and hold it in place and move the lock'seal lever to the lock position. I hope that this has helped you.
May 26, 2011 | Bissell 8975 CleanView Bagless Upright...
Bissell 8975-R CleanView Bagless Upright Vacuum - motor is loud when vacuuming
<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution"><span>Hi,<br />Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...<br /><br />Bissell Bagless Upright <a href="http://www.fixya.com/support/t4975919-vacuum_pick_up" target="_blank">Vacuum</a> not working<br /><a href="http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not" target="_blank">http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not</a><br /><br />heatman101 <br /></span></span>
Aug 26, 2010 | Bissell 8975 CleanView Bagless Upright...
Foot controlled handle release lever is broken. Where to get parts?
I had same problem - the foot release pedal would not spring into place when unit was upright (but would work if you nudged in place with your foot). I installed a replacement part, and it didn't fix the problem. I cut out a small sqare of sponge and jammed it behind the flat end of the bent plastic spring on the release pedal, and it now springs back as it shoud. Hope this helps.
Jan 11, 2010 | Hoover U6630-900 WindTunnel Bagless...
Stand up lever is plastic, broke when stepped on to release handle, can it be repaired, replaced with a better one, plastic breaks too easily?
The pedal release can be replaced but the base will need to be checked for cracks as well. if the base is broken most common is the socket the pedal release snaps into. some of the plastic parts have been made with better materials
Oct 20, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
Foot latch is broken. need to replace with new one. how does one access to remove the foot pedal latch. By foot latch, I mean the foot lever that releases the upright to lower the handle and begin...
it is accessed from the bottom underneath by the rear wheel. However, If there are and cracks on the pedal release socket area then the base will need replacement. parts are little cost but the unit needs to be completely disassembled.
Oct 17, 2009 | Hoover U6446-900 WindTunnel Bagged Upright...
Replacing the foot pedal
there is two C clips on the pin that must be removed first. then the pin will come out. if you need a picture of this or have any other trouble feel free to let me know. I also stock those foot pedals if you need one.
Aug 10, 2008 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
Bissell Bagless Vacuum cleaner
There is no release, the part is a plastic handle release lever, you can find those at www.hesco.com, the cost is approximately 2.29 each, I have replaced more than 20 of these on the commercial vacuums for my cleaning crew, the part is easily broken and easily replaced. I always have 6 or more on hand.
Turn the vacuum over, remove the bottom plate, with a flat head screw driver punch out the old part. turn the vacuum upright again after the broken part is removed. With the body laying back on a hard surface, carefully push in the new part. Unfortunately, these are plastic, too bad they cannot design a more sturdy part for this.
Apr 10, 2008 | Bissell 3522 PowerForce Bagged Upright...
Foot Pedal was knocked out of alignment
You will have to take the top loose so you can put the handle release in its place. It probably isn't in the right place, either that or a piece of it broke off and it needs to be replaced.
Mar 16, 2008 | Bissell 1699 ProHeat Clear View Upright...
Canister problem
If it won't latch after cleaning the latch and making sure that everything is seated well, get in touch with Dyson, they're great about making things right with their vacuums.
Sep 18, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
144 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
