Question about Vacuums
Why is my swiffer vacuum working up to full power and then it needs emptied and then it loses power after I empty it?
    Problem Solver:
  • 12 Answers
It can't be that it loses power, it just gets loud when it's full, not so loud when it's empty?
Posted on Sep 07, 2009
How and were do you empty the dirt?
Check it. When the bag is full, it's time to empty.
Apr 20, 2016 | Dirt Devil Red Versa Power Stick Vac
Why does red ball stop operation?
Hi there! The red float is there to let you know when your dirty water tank is full and needs to be emptied. If the float is popping up and the dirty water tank is empty or not full this is an indication that the dirty water tank filter is dirty and needs to be cleaned or replaced. Follow the link below to order a replacement filter for you vacuum.
Search Results
Hope this helps!
Jul 28, 2014 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
My Dyson DC40 Animal sounds like it's running on half power. I've only had it one day and it seemed great considering it was sucking up an incredible amount of half/dirt. I took the canister to empty it,...
I would recommend you check the gaskets and make sure they are all connected properly so the vacuum doesn't lose suction. Also, check the filters. If they get too dirty the vacuum will lose suction.
You could check out Dyson's site: dyson.com/support.aspx
Hope that helps.
Greeley Epoxy Garage Floors
Aug 24, 2013 | Dyson DC40 Animal Upright Vacuum -...
Can't find booklet. Need to empty full container. Thanks.
Remove the dust cup by pressing the button on the top of the cup.
Pull cup out.
Place over garbage can or into a bag and press the red button.
Shake a bit until cup is empty.
Return cup to holder and secure it by pressing in until it clicks.
The manual is located at the following link. It's downloadable and printable. Emptying instructions are on page 8.
http://dl.owneriq.net/4/4d79dca8-65d8-4c46-a58a-a2fef1f89635.pdf
Mar 02, 2011 | Dyson DC14 All floors Bagless Upright...
I can not get the dirt cup out to empty it.
Just slide the dark gray release tab, located just below the cup, all the way to open position, and then pull the Easy Empty Cup toward you.
Jul 10, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
I have the Miele cat & dog S5000 vacuum. I have had it about 1 year and lately the suction doesn't seem as strong and the full bag indicater is always full. I have followed instructions in manual but...
Greetings,
I would say that you have a slight clog in the hose or in the power nozzle somewhere. The full bag indicator is just a guage that will indicate full when it feels like it's lost suction. Example: If you were to take the hose and cover it with your hand, you'll notice that bag full indicator will show full.
To check and see where the clog in the vacuum is, remove the wands and floor attachment so you just have the hose on the vacuum cleaner. With just the hose attached, turn the vacuum cleaner on. Does it still show a full bag? If yes, then remove the hose completely from the vacuum cleaner so it's just the canister part by itself and turn on the vacuum again. If the bag full indicator is now showing an empty bag, this means that you have a clog in your hose.
If the bag full indicator displayed an empty bag when you had the hose on the vacuum, but shows a full bag when you have the wands and floor tool attached, this means that you have a clog in the vacuum either in the wands, or the floor attachment.
For removing clogs from the hose, the quickest way is to just purchase a plumbers snake at your local hardware store, and run the snake through the hose until you find the clog. You may also take a high pressure hose and spray it down the hose until the clog is cleared, but if you use a water hose, MAKE SURE the hose is 100% dry before you use it again.
Also that bag full indicator can be adjusted if you are getting a lot of suction power and it still shows full.
I hope that these suggestions helped you diagnosis your Miele canister to figure out why the indicator showed full. If this helped you please rate my repair helpful.
Feel free to contact me if you need further assitance, I'm always happy to help.
Chris J.
Mar 13, 2010 | Vacuums
13 yr Electrlux.Cuts off if hose plugs in.Says Bag Full-bag empty
This sounds like the valve assembly (full bag control) is faulty or one ov the tubes is clogged. You will have to take it to the shop.
Jul 15, 2009 | Electrolux Guardian Bagged Canister Vacuum
I am using a hoover ultra steam cleaner but the red ball keeps coming to the top . I assume this indicates it is full and ready to empty however it is still empty . The red ball will not stay down in order...
Thankyou,
The redball indicates that it is full, that is due to the high resistence its suction system is inducing, because it is empty and it still stays up, I would try to turn the power settings a little lower, or it is experiencing high pressure from operation. Also, if you could adjust the bristles, or losen around the air vents. This should do the trick.
Thankyou, :)
Jun 24, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Empty bag shows as Full
You have a clog, either in the hose, the dirt inlet by the brush roll or the filters are clogged.
Mar 17, 2008 | Vacuums
Vacuums Logo
96 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
