Question about Jandy Laars Lite2 Pool & Spa Heater - Electronic Dual Ignition - 125,000 BT
Jandy 'Lite 2' 325 btu "LG" Natural gas unit will not fire up!!
We bought this unit second hand, manufactured in 2004, and it was apparently running when it was being used, We have hooked up the plumbing, with no leaks, able to hook up to gas with no leaks, and same with hydro, we are hooked into 115 volts, It has hydro as we are able to get the screen up and running, it shows Normal function, and we are able to set the heater for 80 degrees, we have reset it to original with the reset button, but nothing else seems to be working, It will not fire up, and it doesn't make any noises to even indicate it is trying to do anything, we are unsure where to start looking for the problem, It states it is normal and does not give any error codes! Any ideas??
Thanks
  • 990 Answers
You have to make sure the heater is wired for 110v where you hook the wires up to it. Depending on model it has a red and a black and a red tracer and a black tracer wireyour leads hock to two and the other two wire nut together It will have a tag or scematic to tell you how in a couple of places on the unit. If not that it will simpley be a plug that pulls out in one place and plugs in another. On the early units of that model it may be you just need to reverse polarity also. One more thing if it is a forced draft (with an internal fan) It is imperetive that you gas meter and gas line are sized correctly or it won't fire at all.
Posted on Oct 04, 2009
My Jandy lite 2 natural gas heater has a loud clicking noise. It fires up and heats my pool nicely. My problem is.... as it is heating there is a loud clicking noise from the gas valve area. It acts a
I would suspect that it is not the valve making the noise. I would bet it is the thermal expansion of the metal that you are hearing. Other than that, I have seen cases where there is a flow control valve, and depending on its operation, when it opens or closes on spring power it will over shoot and make a loud clicking noise as the clutch overshoots. This will usually only be about 2-4 clicks though, and around pool equipment I doubt you would hear much of it. I would bet more on the thermal expansion. Kind of like the clicking noise you will hear after you have parked your car and the engine is cooling down.
Apr 10, 2013 | Jandy Laars Lite 2 Pool Heater 250,000 BTU...
make sure pressure switch is good and wires are tight sounds like pressure switch cutting in and out opening and closing gas valve also make sure wires to gas valve are tight
The heater will fire up and the blower will work for a couple of cycles and then the AGS will flash and/or the blower will flash. Is this the result of poor gas pressure or a faulty circuit board?
This issuesounds tricky. I recommend you call the Jandy technical support at 800-822-7933and they should be able to help determine what to do next. Ihope this helps.
Sep 17, 2011 | Jandy Laars Lite 2 Pool Heater 250,000 BTU...
Can we convert Laars lite llg175N to propane from natural gas? If so how
You can convert this laars with a new burner tray, new gas valve etc..I have lots of customers who was the visa versa to you Natural to LPG and LPG to Natural..I offer an exchange service please see..
http://www.laarsman.co.uk
Miles
May 20, 2010 | Jandy Laars Lite 2 Pool Heater 125,000 Btu...
Hello i have a problem with a brand new lxi heater it not lighten .gas is on igntor lite but heater will not lite
What has the contractor who installed it or the dealer who sold it to you said? It is under a manufacturers warranty so if it needs servicing you should leave it to someone in your area who provides warranty service for Jandy. You can locate one on their site.
Mar 29, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Pilot lit clicking noise no burner
make sure knob on gas valve(inside heater)is turned to on position.3/4" should be fine as long as heater is not larger than than 175,000 btu
Jul 14, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy Lite 2 LG Model not firing up. Was working during day
ok 24 v at the transformer is yes than a safety swicth turn the heater off check fuses
Jul 10, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Heater fires runs for 3 min shuts off
Sounds like a problem with the thermal bypass or high limit system.
what is the model?
Jun 24, 2009 | Jandy Laars 400,000 Btu Natural Gas, Laars...
Jandy Laars Lite2 Pool & Spa Heater - Electronic Dual Ignition - 125,000 BT Logo
182 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
