Question about Breville Ikon Tea Kettle Electric Kettle
Breville Kettle model SK500XL: Sometimes does not work, sometimes does. After pushing the on switch a light is supposed to come on. If it does not, the kettle won't heat the water. Can this be fixed. How?
  • 2,200 Answers
Hi
This can be fixed but is not always an economical repair depending on the cause.
A common issue with Breville kettles is that the electric contact between the base and the kettle will become poor through general use. Early signs of this are intermittent problems where at times the kettle makes a good contact with the base and works - other times does not.
Eventually the contact fails altogether and kettle will not work at all.
First Stay Safe!
When working with electrical items always ensure the mains supply is completely disconnected.
Inspect the base itelf to see if there is anything obstructing the contacts in the base. These contacts have a tendency to wear out or lose their shape and become unreachable for the other contacts in the bottom of the kettle. you may have to remove some non-standard head screws to get access to these.
Next have a look at the bottom of the kettle. Ensure the kettle contacts are not sticking or obstructed in any way. Use a pen or similar item to test that the movement is not compromised.
Unfortunately when these kettle to base contacts start to give trouble they can remain temperamental even after you get them working again. However if you feel competent to try this it is certainly worth investigating.
Hope this helps. Please do rate this answer. Many Thanks.
Posted on Sep 07, 2009
You have to turn it on the base to find the right spot make the light come on and work.
I just read these notes because I was having the same problem.
My breville sk500xl 1.7 L is now working perfectly...at least right now.
For my fix I didn't NEED to use my micro-screwdriver (like those for eyeglass repair) to remove the screws from either the base or the pot.
The issue on mine was that the contacts were moving freely but the springiness was not really there.
So I cut 2 1/4 inch pieces of paper q-tip stick and shoved them between the plastic housing and the copper contact. Basically it holds the contact out.
(This may be a model specific fix and requires NO disassembly. I had already taken everything apart and cleaned and tighten all contacts possible)
Aug 14, 2011 | Breville SK500XL Stainless Steel Cordless...
Bran new, never used...trying but no water flows trough.no steam
Australian Cafe Roma is ESP6 or ESP8C
Husband would like to know if you're only having a problem with the steam or is there no coffee coming out either.
If it's only steam, undo the nut at the end of the steam spout and clean it as it may be blocked.
If that doesn't work there may be a problem with scale, so he'd recommend you descale the machine.
Nov 29, 2009 | Breville 1.7 liter Premium Stainless Steel...
Strong metal taste, how do I get rid of it. Coffee tastes terrible with very strong metal taste. I have boiled kettle about 8 times, but am unable to get rid of bad taste.
Professional chefs face this problem many times over with their stainless steel wares. Fill the coffee pot with water. Add a tbs of bleach. Let set for 2 hours. See if that helps. If it doesn't, please let me know.
Oct 20, 2009 | Breville SK500XL Stainless Steel Cordless...
Breville kettle blew fuse (trip switch) now won't switch on
If the 'neon' light is on, the power is getting to the kettle, so if its not heating up then the element must have broken.
This kettle has a little white trip switch inside the 'socket' of the kettle (not the base unit). If its not heating, light is not on and the plug fuse is OK, then poke the white trip until it clicks.
Feb 07, 2009 | Breville Kitchen Appliances - Others
Intermittently working
That means that there is either a lost contact inside, or a defective switch.
The kettle must be taken apart to fix the problem.
Dec 27, 2008 | Breville SK500-XL Stainless Steel Cordless...
New kettle breville
There's several home remedies you can try: Try 50% "White Vinegar", 50% Hot Water or 2 Denture tablets in warm water over night or Baking soda in warm water. These remove the alkaline, minerals, and nitrates that build up on the surface. There is even a commercial product you can use to clean it. I can't recall the name but look in any supermarket, you should be able to locate it.
Sep 11, 2007 | Breville SK500XL Stainless Steel Cordless...
Problems with Breville SK500XL Stainless Steel Cordless Electric Kettle
There's a thermal cutout that trips if the regular safety switch isn't enough. According to the manual, if the thermal cutout trips you have to send it back to Breville for servicing.
That may be what happened, if just letting it cool down and trying again didn't work.
Aug 13, 2007 | Breville SK500XL Stainless Steel Cordless...
Breville Ikon Tea Kettle Electric Kettle Logo
244 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
