Question about ViewSonic Televison & Video
How can i tell if the remote contol is defective or whether it is the television set
    Habit-Forming:
  • 108 Answers
Some electronic suppliers, maybe radio shack, sell little cards that light up when the remote or any infra-red light hits it. If you have another same brand remote or TV you can see if it works that set (maybe a family member or friend as the same brand of TV). Other then those choices the IR pulses can be seen with an oscilloscope.
Posted on Sep 07, 2009
Nec tv RD1113e 79644901 cant tune stations, no menu button on remote
Hello
If there is no Menu button on the front panel of the tV, it will be difficult to get an auto tune function to this set. Try to muy one universal remote contol, which have setup codes for your NEC Tv.
Mar 01, 2012 | Televison & Video
My television no longer accepts commands from the remote. I have verified that the remote control is working properly. Please advise.
Hello
If your TV doesn't accept remote control signals, the infrared remote sensor inside your TV may fauty, or it doesn't gets proper voltage to work. I don't know the way you have tested your remote contol for infrared emission. Any way do this check once more. You must have a cellphone with camera option. Put it in camera mode, place your remote control in front of the its lens a little apart from it, and press all buttons on your remote to see there is any infrared signal comes from it and all buttons are working or not. Most cellphone cameras can detect infrared rays, and will show its indication of its screen.
If this test is Ok, then proceed. Take all precautions we take while working with an electrical equipment. Since as high as 27KVDC [27,000 volt DC] points are there inside your tv, you must be very carefull. Open the back cover of your TV, pull out the main board, usually slipped in, towards front. You can locate the infrared sensor there in the board, diretly solderleld to it. Usually it have 3 legs, with one leg is a little apart from the other two. Check whether there is some voltge on its leg points. One of them is earthed [connected directly to negative], and usually the center one is its supply point. That point must get about 5vDC. In some Sony sets the supply point will be at the end pin. If there is voltage mentioned above, surely it is damaged. if there is no voltage find out the reason for that. It may be due to some loose soldering, or resistor failure. If there is votage, sensor may be defective. Resolder it and take it out from the mainboard and go for the same type and number. Its number will be printed on it [usually laser printed]. Insist on the same number and type. Never use other numbers, since Sony has special circuts and charcteristics for their components.
Ok Wish you success.
Oct 22, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
My tv is block and i dont know wat to do. how can i unblock it?
Don't use the remote control the signal it block.Go to ur manual contol on the tv right side.Push the power button to turn tv on.Push button Menu now U in the tv Menu,Use the volume + or - button move the Menu function to OPTION,now use the Channel + or - go down to the word said Operation lock out(ON) Now push manual contol button said INPUT.Now the word said Operation lock out(OFF).Now remote control is relase,u can use the remote control now.Tell me this work ok.This is how i unlock the Sharp Aquos tv.
May 09, 2010 | Hisense TL1700 17 in. LCD Television
Could the front contol panel be bad if my T.V. dont turn on
More likely no power to set; either no AC from plug outlet, or internal fuse in power supply.
Apr 19, 2010 | Mitsubishi VS-45607 45" Rear Projection...
Need the remote contol code for AOC L26W861 Lcd TV
Just kept repeating the U-Vesre procedure over and over and Wham! Persistance was the key.
THX
Jun 12, 2009 | Televison & Video
Using my universal remote contol,lost sound on 2 TV channels
The solution is to change the audio input from SAP (secondary audio programming - default on TV sets sold in Canada) to Stereo or Mono. Your remote will need to be able to access the "Menu" settings screen for your television set.
May 07, 2009 | Samsung TV Remote Control
Philips Magnavox 27MS343S 27"
WHAT IS THE CODE TO PROGRAM A J.V.C. DVD INTO A PHILLIP UNIVERSAL REMOTE?
Apr 08, 2008 | Philips Magnavox 27MS343S 27" TV
Need codes please for Jensen JER 422 for Magnabox TV
magnavox tv jer 422 codes are: 1000 1004 1006 1008 1019 1062 1068 1069 1075 1076 1133 1219
Jan 12, 2008 | Jensen JER-422 Universal Remote Control
Lost Remote
Without knowing what specific make and model you have, all I can do is offer generic advice. Have you tried unplugging the set for a few minutes to reset it? This may clear the control panel lockout. I'd also try a universal remote contol that can access necessary features. They're pretty cheap these days.
J. DeRuvo
Digital Camera HQ
Dec 04, 2007 | Televison & Video
Televison & Video Logo
94 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
