Question about Krups 287 SensoToast Deluxe 4-Slice Toaster
The toaster was turned upside down and now it will not heat. The carriage does stay down
    President:
  • 3,433 Answers
Sfety switch needs reset. Open the bottom and look for a switch in the cord wires circuit.
Posted on Sep 07, 2009
When you press the lever to push the bread down in the toaster, it will not stay down
How to Fix a Broken Toaster - For Dummies
www.dummies.com/how-to/content/how-to-fix-a-broken-toaster.html
Toasters are uncomplicated appliances with heating elements, a thermostat, switches, and plugs and cords. ... If you get a shock when you touch the toaster, it's not grounded. ... What to do when your toast won't stay down ... Take off the carriagelever and front cover and look for a knob, screw, or nut located near the toast ...
How I fixed my toaster - YouTube
? 6:15
https://www.youtube.com/watch?v=QKiJkpuHy-Q
Feb 5, 2010 - Uploaded by paisteboy
Hey I know its been like 5 years since you posted this but how didyou get off the black knobs? I have a similar ... Thanks much - I shall try this on my mother-in-law's Oster toaster! ... But now that side won't stay down, so what to do? .... About · Press · Copyright · Creators · Advertise · Developers · +YouTube.
Jan 16, 2016 | KitchenAid Kitchen Aid KMT222OB - 2-Slice...
The bread won't stay down. The lever keeps coming back up
There is a bottom pan that gets clogged up with bits of bread, turn the toaster upside down and turn the set screw on the pan and open, flip the toaster back over and shake it, this will release a lot particles, keep at it until you removed as much as possible, this should the toaster for sometime.
Jan 17, 2011 | Kenmore KTES3 2-Slice Toaster
When I depress the carriage control levers they do
my toaster did this once, i suggest that you get a new toaster from a different company, because if you've only had the toaster a month
and its doing this already that's a crappy toaster
Apr 20, 2010 | Cuisinart CPT-180 Metal Classic 4-Slice...
"Down lever" doesn't stay down
You can try taking the toaster over to the kitchen sink and hold it upside down. Shake the heck out of it and you may dislodge something (like an old breadcrumb) in the switch. I've had to do this numerous times. You have to flip it upright, shake it, turn it upside down and shake it again -repeat until nothing comes out and nothing sounds like it's rolling around in the toaster.
Mar 14, 2010 | Kitchen Appliances - Others
The toaster arms will not stay down on either side , have power to the toaster and can see the elements light when arm is held down but won't stay down.
First, turn it to the darkest setting. It may be set too light to stay down. Also, try cleaning it out. Take it outside and turn it upside down and shake it. Also, open the crumb door on the bottom. Hope this helps. Good Luck.
Feb 10, 2010 | Cuisinart CPT-180 Metal Classic 4-Slice...
Toaster control lever will not stay down
Unplug the toaster, turn upside down, and gently shake all crumbs out. There's been plenty of times when a stray raisin causes this problem!
Otherwise there may be a break in the element. In Australia toasters won't stay down unless the power is connected, and if there is a break in the element there won't be a continuous circuit.
Nov 26, 2009 | Black & Decker Kitchen Appliances - Others
Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Aug 04, 2009 | Kitchen Appliances - Others
Sunbeam 3831 Toaster (2-slice) -- toast/carriage won't stay down
great ! its a great fealing when you save a appliance from the junkyard .
Mar 30, 2009 | Sunbeam 3831 2-Slice Toaster
The digital control panel is on the fritz,
We ran into the same problem today with our toaster. There was never a problem before I cleaned it--not only by sliding out the crumb drawer, but by turning it upside down to dislodge every last crumb. After that, It would not stay down when pushed down--and none of the buttons were functional.
My husband took the cover off and found that a magnet is what keeps the lever down when the toaster's on, and allows it to go back up when the toasting is done. It's an electro magnet that works only when the toaster is on. It seems that when I turned the unit upside down and rightside up again, crumbs landed on the magnet's contact plates (which are about 1/4" x 1/2") and would not allow the magnet to engage. Because the magnet wouldn't engage, the lever would not stay down, and the toaster shut off. Brush off the magnets, replace the cover and toast away!
Nov 28, 2008 | Oster 6330 4-Slice Toaster
Bread won't toast
We ran into the same problem today with our toaster. There was never a problem before I cleaned it--not only by sliding out the crumb drawer, but by turning it upside down to dislodge every last crumb. After that, It would not stay down when pushed down.
Dec 27, 2007 | Kitchen Appliances - Others
Krups 287 SensoToast Deluxe 4-Slice Toaster Logo
293 people viewed this question
Top Krups Kitchen Appliances - Others Experts
Mike
ArcFlash
Level 1 Expert
Oloyede Monsuru
Are you a Krups Kitchen Appliances - Other Expert? Answer questions, earn points and help others
