Can a 2nd tray for legal paper be added to the
Is it possible to add a 2nd tray for legal paper be added to the brothers HL-5250DN printer?
  • 32,281 Answers
Yes
Posted on Sep 07, 2009
How to you turn on the manual feed for the HL 5250dn?
Simply pull down the door on the front of the machine and insert paper into the manual feed tray. There is a sensor that recognises paper in the manual feed try and will then print from it.
Feb 11, 2010 | Brother HL 5250DN Laser Printer
I just bought a new Dell with Windows 7. Installed the updated driver from brother. Printer worked OK. As a page was feeding back into the machine it got stuck. I removed the page. But since then the paper...
This could mean that the printer is expecting paper of a particular size (for duplex printing). Press the job cancel button and check that the paper size is set for the correct paper type (A4, Letter or Legal). That light will also blink if the back cover is open or the duplex tray is not installed.
Dec 11, 2009 | Brother HL 5250DN Laser Printer
Brother HL-5250DN Laser Printer making noises and not printing
some gears are not in proper position , pull out the paper tray and closed it strongly .
Nov 17, 2009 | Brother HL 5250DN Laser Printer
My printer wont properly feed the paper through -- keeps saying no paper bt the tray is full of paper
There is a sensor flag (plastic peice) that hangs down from above the tray. Remove the tray and make sure it is in place and moves freely.
Just in case you have a further problem, I have uploaded the service manual for you at Mega Upload. Hit the link below, click off any ad that appears, select regular download and enter the visual verification code in the top right corner. It's free. Hope that helps you. :)
http://www.megaupload.com/?d=MMBOCCQN
Nov 03, 2009 | Brother HL 5250DN Laser Printer
My Brother 5250DN is not pulling paper through. What could it be?
do a test print... see you manual. You hold a button for 3 seonds and it'll print a test page. If that works you should be OK. Make sure that your paper tray is NOT over loaded. Maybe try less paper. Try the manual feed using one sheet of paper
Oct 27, 2009 | Brother HL 5250DN Laser Printer
I have a brother hl-5250dn with an extra tray for legal size paper. I have a problem printing loan documents sent via swiftview or elynx. I can only print on letter pages or legal pages but not both and...
Sounds like your secratery's printer is set to ignore paper mismatch errors. It depends on the setting you have in your driver. Can you set your driver on your printer to ignore paper mismatch errors. If not when your printer errors, just try hitting the go button and it should print the document any way.
Sep 07, 2009 | Brother HL 5250DN Laser Printer
Paper tray not lifting the paper up for the initial paper feeder
most common problem on these is the rear paper stop pressing too hard against the rear of paper causing paper not to lift. make sure you have about an 1/8" gap.
good luck,
razors
Jan 09, 2009 | Brother HL 5250DN Laser Printer
Feeder wheels are spinning backwards
I see that you have mechanicals problem the doublex maybe faulty
i need from you to tray clean the printer all printer roller and tray to disable the doublex future from the driver try to print and send to me feed pack
Dec 05, 2007 | Brother HL 5250DN Laser Printer
Brother 5250DN printer noise
Check my solution here:
http://www.fixya.com/support/t641678-paper_tray_noise
Here's a solution for you with Brother HL 5250 D/DN/DNT
Change the paper setting tab in the tray to make sure you have a small gap between the top part of the paper and the bottom part.
so if this is the old settings : |paper| --> you want to make it: | paper| so you can have slide the paper back and forth.
DON'T adjust the setting to the next paper size because the roller wont catch the paper if it slide too far.
Good luck to all.
Nov 02, 2007 | Brother HL 5250DN Laser Printer
91 people viewed this question
jasbo
jasbo
