Question about Whirlpool ED5FHEXMQ Side by Side Refrigerator
Whirlpool sideby side ref. ED5FHGXKQ02 condensation on walls of freezer causes accumulation of water on freezer floor
  • hpalma4027 Nov 16, 2009
    Hello, I own a Whirlpoo side by side refridgerator model ED5FHGXKQ02. It comes with an ice dispenser and a water dispenser. The problem I have is the water dispencer started to leak. Can you help me how I can repair that problem, what part do I need to buy? Any tips are appreciated, thanks.
    Hector
  • Anonymous Mar 20, 2014
    the water is condensing on the front wall
  • Whirlpool Master
  • 4,654 Answers
Most times that is a defrost drain blockage behind the rear wall of your freezer back panel. Sometimes the door seals allow some moisture to accumulate if air is drawn in through the seals leaking or the door to the dispenser is stuck open. But when you say it has accumulated in a pool of ice on the bottom of the freezer then the drain is blocked. I'm going to send you to some links and I want you to read through most of what is said and just use the parts the refer to your refrigerators problem, Sea Breeze
Posted on Sep 07, 2009
  • John Tripp
    John Tripp Sep 07, 2009
    WATER LEAKING FROM REFRIGERATOR OR INSIDE THE FREEZER OR FRESH FOOD SECTION
    Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan. Your drain tube may be stopped up with ice at the upper end because it drains too slowly because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Or use a wet and dry vacuum cleaner. Flushing it out with hot water and Clorox may help.
    Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
    HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
    If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
    SEA BREEZ TIP's
    appliancepartsse@yahoo.com
    http://servicepartstec.blogspot.com/
    http://appliancepartsse.blogspot.com
Accumulates water on bottom floor below bins
I am pretty sure you are having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down ther rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more si mple in clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators!
Thanks, Sea Breeze
Jul 19, 2012 | Sub-Zero 695/O Side by Side Refrigerator
Model: ET19DKXFW00 refrigerator. Water accumulates on top shelf of refrigerator below freezer compartment and near vertical staff which runs between freezer and frig.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 15, 2011 | Whirlpool Refrigerators
Water accumulates beneath freezer basket and drips outonto kitchen floor. cannot get into area to cleanout welland see no type of removable tray.what can I do ? this is a whirlpool model # GX2FHDXVY04...
Leo Ponder
imufo2
Sep 03, 2011 | Whirlpool Refrigerators
Our Hotpoint Ice Diamond fridge/ freezer has developed a slow leak, or rather, it collects water condensate on its floor in the upper compartment which then oozes out onto the floor. I don't have a...
Thier are 2 possible thing causing that leak.
1 ) a blocked defrost drain..this tip i wrote will tell ya how to clear the defrost drain
FREEZER ON THE TOP OR BOTTOM http://www.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
SIDE BY SIDE http://www.fixya.com/support/r9991618-wrong_when_side_side_refrig_leaks_from
2) the water inlet valve that distributes water to icemaker and in door dispenser (if equipped) hasa pinhole in it and spraying water onto the floor...to check that gotta pull out ref.from the wall and remove lower rear service plate and inspect the valve for a pinhole
GENE
Aug 31, 2011 | Hotpoint Refrigerators
My fridge is having a problem in the defrost. A sheet of ice forms on the base in the freezer and water is leaking into the fridge and accumulating on the shelves. It is a 2004 Whirlpool model...
Leo Ponder
imufo2
Aug 20, 2011 | Whirlpool Refrigerators
Condensation at top of inside refrigerator
you have a drain hose from the top back of the freezer down to the condensate pan on the bottom of the refrigerator near the floor
this hose is blocked causing ice to build up behind the rear inner wall.
remove the back of the freezer wall and using a funnel pour hot water in to the hose to clear the condensate hose also remove all the ice behind the wall; remove the back cardboard to see the water come through the hose into the condensate tray when you pour the water it should pour right through if it's clear
Aug 31, 2009 | GE Refrigerators
Water accumulating in bottom of kenmore
It's likely the condensate drain is plugged. You can access it from the back of the refrigerator. You can disconnect from the inside of the fridge and blow it out to ensure it is not blocked, then reconnect.
Aug 15, 2009 | Refrigerators
Freezer quit freezing
HI,
you can try this suggestion first.
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks,
Mar 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water accumulates under vegetable bins and spills out the front
the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
Jul 06, 2008 | Whirlpool EL7ATRR Refrigerator
this is normal this is the mulliion heater , it is a loop of tubing from the high side of the condenser it is used to keep moisture from forming between the doors of the ref, cool it will not be
but is cool how the manufacture thought about doing this
May 16, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool ED5FHEXMQ Side by Side Refrigerator Logo
438 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
