Question about Ovens
I am after a manual for the Zanussi oven model number ZBM170LX. We have one at our workplace but nobody knows how to operate it. Please help
Found my answer on the internet
Posted on Sep 07, 2009
I can not find a manual for model number ZE0505X
Susan, in what country did you buy the oven? The codes differ per country.
Does the model tag look like this?
Of course it might be difficult to FIND the tag...
Let me check where they stick those....not-find-manual-model-number-ze0505x-cluqxvqmjdhmibjs3bae0uvv-4-2.png
See above location in red.
You can lookup manuals on zanussi.com by using the PRODUCT CODE as well (the serial number does not help). Check if the product code gives you a result on this page:
http://www.zanussi.co.uk/Support/Manuals/
May 18, 2015 | Zanussi ZHQ575 Electric Double Oven
Will Details about Zanussi ZCG7901XN Cooker Top Oven Glass Door fit my ZCM7901XN oven?
I think yes, because spare part number 311407328/5 of outer glass door is the same for both oven.
Dado
Mar 03, 2015 | Zanussi Ovens
F908 ERROR CODE
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Please provide model number and also the condition when this error occurs. Can you operate the oven after this fault occurs. Try to turn off the mains power and check after turning back on.
Jul 31, 2014 | Zanussi Ovens
My oven is loosing temperature
To me it sounds like the heating element is starting to go, I would suggest that you replace that and see how it go there after.
Feb 10, 2012 | Ovens
I want to change the light bulb in the oven,.Mod.no.ZDQ695A can you help me.
I will assume that the ZDQ695 bulb replacement procedure is the same as that for the ZDQ695A. The ZDQ695 uses a 25 W appliance light bulb (300 C). Unplug the appliance before starting. Open the oven and remove the racks for space to work. Insert a flat blade screwdriver between the side of the oven and the glass cover above the bulb. With your hand support the cover and pry it away from the wall of the oven until it releases. Push the top of the cover towards the oven wall and use your fingers to pry the bottom of the cover away from the housing. Then remove the cover. Unscrew the old bulb (counterclockwise) and then remove the bulb. Then screw in the new bulb. Replace the glass cover (position the flange so that it is pointing to the back of the oven) by pushing it into the hole to cover the bulb assembly. Replace the shelves and close the oven door before plugging the oven back in.
Zanussi manuals are available here: http://www.zanussi.co.uk/en-gb/Support/Manuals/ . Enter the model number in the search box. Alternatively, the manual for the ZDQ695 is available here: http://kitchen.manualsonline.com/manuals/mfg/zanussi/zdq_695.html . Click on the Get This Manual button.
I hope this helps.
Jul 24, 2011 | Zanussi ZDQ695 Electric Double Oven
Oven won't turn on, had a power outage on the street 3 times today. Tried flipping the fuse, but nothing has happened. Any suggestions? Not sure which model Zanussi it is, except it is not brand new!!
The electronic clock/timer must be in manual mode for the oven to operate. When the power to the oven is cut the electronic clock/timer reverts to automatic mode when the power comes back on.
Mar 07, 2011 | Zanussi ZBS963X Electric Single Oven
MikeandI have just purchased a Zanussi electric oven model no.ZCV550MXC but can't find in the instruction book how long to preheat the ovens for Can you help?
Your best solution for this and all the other problems you may have as a result of losing your manual, is to go to http://www.zanussi.co.uk/node182.aspx put in your model number, hit return and click on the PDF manual it offers you. Then you will have an answer to all your questions.
Feb 09, 2011 | Zanussi Ovens
My Zanussi double oven switches off during the cooking period.
If it turns off after it has been on a while, then it could be caused by overheating due to failure of the external cooling fan.
The fan is designed to prevent the oven overheating, and failure of the fan causes a safety thermostat to operate and stops the oven from working.
You need to access the fan to check that it is working.
It is usually located at the top of the oven at the rear, and entails removing the top cover and the back cover possibly depending on the model number.
What you are looking for is a cylindrical type fan about 8" to 12" long, again depending on model.
Hope this helps solve your problem.
If you requies any nore info, please e-mail.
Dec 23, 2010 | Zanussi Ovens
Zanussi zbf360 the glass on the top (HOOB)has
It depends on the make and model, that number you quoted is for your slot in oven,the hob is a seperate unit.They could cost more than the hob is worth but if you get the model number and relog the question maybe we can help.
Hope this helped.
Apr 28, 2010 | Zanussi ZBF360 Electric Single Oven
Ovens Logo
77 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
