Question about Estate TGDS840JQ Gas Dryer
Auto sensing does not work. dryer continues to run
Auto sense does not work. dryer continues to run until the off position
  • Estate Master
  • 8,220 Answers
Inside the drum under the filter is 2 long skinny strips of metal mounted in plastic. Clean then sensors up with alcohol. They get goop on them from soap and fab softener. I have a manual here that feature auto sensing circuits and photos CLICK HERE FOR THE MANUAL
Posted on Sep 07, 2009
What does the sensing light mean
The sensing light is the part of the machine that senses moisture inside the dryer itself. If it senses moisture the machine will continue to run until its satisfied that the clothes are dry
Sep 04, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool gas dryer (WGD9450WR1) not drying on auto-cycles
try cleaning the 2 silver senser bars located inside the dryer drum on the door side with isopropyl alcohol and lint free wipes,these bars sense moisture and control timer speed,and when they get coated with the chemicals in dryer sheets they become coated and can no longer sense the damp clothes (these sensers use capacitance to sense moisture)
Feb 18, 2012 | Dryers
Takes 4 ever to dry clothes. Will run & run when on auto dry.
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Jan 09, 2011 | Amana NDE5800AY Electric Dryer
Kenmore Electric Dryer Model 110-C62662101. Dryer won't stop running. Will run all day long until door is open.
Problem with the timer control unit as it is not switching off until reset with the door latch.
it is possible that the dryer control relay or driver is short and giving power continuously.
Sep 30, 2010 | Kenmore 62622 Electric Dryer
How can I check the control panel for my dryer, to make sure that is the problem?
Obviously it ain't drying the clothes. Maybe it ain't even running?
Or it could be working just for not too long. If it has auto sensing then the moisture sensing strips might be clogged with something that is preventing the dryer from sensing wetness.1753c2e.jpg That is easy, just windex them sensing strips. If they can't sense wetness then the control will shut down quickly and the clothes will be wet. Lets see what else the crystal ball has...I have some manuals HERE
Sep 19, 2010 | Whirlpool Dryers
The optimum dry is not working - dbl333eb
they have a sensor it will have a few metal strips inside the dryer. ge usually right by the lint filter. it most likely that or whatever feeds it. the auto dry sensing board or timer. sensor, sensor board or timer. most of time sensor is bad.
Aug 01, 2010 | GE DBL333EBCC 5.7 cu. ft. Electric Dryer
My 400 series Kenmore dryer's timer is not working
if the timer will not advance through the cycles and the dryer is getting hot try the timed setting not the sensed setting and if the problem continues on the sensed side only it is not the timer it is the sensor , the sensor is what senses the temperature inside the dryer that is what advances the timer on the sensed side it could be that the timer could be good and the sensor be bad try that
Apr 03, 2010 | Kenmore 400 6943 Dryer
Dryer runs but wont auto shut off
On auto dry cycles, the cycle is controlled by moisture sensing bars located on either the rear or front bulkhead, ( visible inside dryer ) if the moisture sensor bars are shorted together (normally by wet clothing) the dryer will continue to run. If the dryer continues to run when the clothes are plenty dry, check and see if there is anything stuck between the sensor bars, (sometimes a metal sequin will cause this) or see if they are damaged. If not, you may have a problem with a timer contact, if the timer advances and stops moving at the same spot each time, I would suspect the timer. If this is an EvenHeat dryer, examine the control board located to the right of the timer in the control panel, for any burned components. Hope this helps.
Sep 15, 2008 | Kenmore 73952 Gas Dryer
Estate TGDS840JQ Gas Dryer Logo
469 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
