Question about KitchenAid K45SS Classic Stand Mixer
I have a kitchenaid mixer Model K45SS and need a capacitor (#F11.037/97) and would like to know where to get one from. Brisbane Qld
  • 9 Answers
SOURCE: Kitchenaid Mixer K45SS
I just did this last week!
1 Unplug Mixer 2 Remove screw on TOP of mixer body, at back. 3 Remove rear cover and paper-gasket thing (its not the end of  the world if you end up tearing it a little). 4 the phase control (little circuit board w/wires) is at the top (you  should see it very easily) held on by one screw, remove it. 5 when the circuit board is unscrewed, disconnect all the wires  that are connected FROM THE CIRCUIT BOARD to the  black control plate (NOT all wires-there should be 4 left on  the control plate at this point).  you don't need to  remember where all the colors go as the control plate is  labeled->but looking at them and making sure you  understand the abbreviations would be beneficial  (BK=black, BL=Blue RW=Red&White W=white R=red etc.   6 install new phase control (screw), either buy new thermal  grease (used to keep the board cool->it transfers heat to  the mixer's housing) or try to salvage what you can from  the old one. 7 connect wires, paying attention to labels. 8 reinstall paper gasket, then cover, then screw to hold on back- cover.
Posted on Feb 09, 2008
SOURCE: kitchenaid mixer k45ss slow gear
If you look into the brush holder you will see a stopper at the botom ,(this is so when brushes are wore the spring is not driven into armature) .. the brushes have to be inserted so the groove is lined up , try that
Posted on Apr 07, 2008
Illeagle
  • 525 Answers
SOURCE: KitchenAid K45SS Mixer Service Manual
We are sorry, but nothing has been found for the brand KITCHENAID and model K45SS in english.
function formchecker_wishlist(theForm) { var allvalid = true; var alertstr = ""; var validstr = "All form data is correct.\n\n"; var error_empty = "Please enter a valid e-mail address"; var error_default = "Please enter a valid e-mail address"; var default_text = "I enter my e-mail address"; var error_wrong_email = "The e-mail address is invalid"; var num_of_elements = theForm.length; for (var i=0; i 0)) && ((checkEmail.indexOf('@') 0)) && reg.test(checkEmail) == false) { alertstr += error_wrong_email; allvalid = false; // .... End of loop through form elements .... } // All elements checked - now determine if form is OK ... if (!allvalid) { alert (alertstr); return false; } } //--> If wish to be informed when product reference K45SS is available, please click on the link below:
http://safemanuals.com/zearch_404.php
Hope this helps!
Thank you for contacting us at Fixya.com
Posted on Jun 10, 2008
  • 118 Answers
SOURCE: Repair manual for a KitchenAid K45SS stand mixer
You should be able to look up your manuals HERE
Posted on Nov 30, 2008
hslincoln
  • 235 Answers
SOURCE: k45ss kitchenaid stand mixer, i took out the brushes
jrichards - I hate it when that happens! It seems that power is not getting to the armature from the brushes so I would suspect that one or both of the brushes is (are) not seated properly. Did you remove the brushes to replace them or were you just inspecting them? I'd suggest removing them again and making sure the contacts are facing in the right direction to contact the armature. The concave contact face should be resting completely on the armature. If you've turned it 90 degrees too much, it wont' seat properly. I hope this helps... Howard, Burke, VA
Posted on Nov 03, 2009
Kitchenaid K45 Mixer will only run at one speed, fast
is it a K45 or a K45SS? If it is a K45 you will have to replace the filters inside and probably the speed control plate, if it is a K45SS then you need a new phase control board. The K45 is pre 1978 and the K45SS is post 1978. Your information is correct on pre 1978 K45 models that the capacitor is bad, but it might be cheaper to go garage sale hunting and find a second machine as the parts are no longer made and having spares on hand may be a significant advantage in the future, also there are a great many of the K45SS parts that will also repair the K45 mixer so it may not be a practical solution. Watch ebay regularly for K45 parts, they come up every couple of months. On the parts diagram also look for the K5 diagram as it is identical to the K45, one is a 5 quart mixer and the other one is 4.5 quart, same parts same motor same everything.
Jan 30, 2013 | KitchenAid Food Mixers
What kind of grease can be used on a stand mixer after replacing a stripped worm gear? model:K45SS
Food grade grease is what Kitchen Aid put into the gearbox originally. They do supply it as a spare part if you cannot find it as a non Kitchen Aid part.
Nov 02, 2010 | KitchenAid K45SS Classic Stand Mixer
I need a manual for my kitchenaid model # k45ss
You can get the manual on the link below. Once there scroll down to product manual then click manual to download.
http://www.amazon.com/KitchenAid-Classic-250-Watt-2-Quart-Almond/dp/B00004SGFX
Good luck please rate 4 thumbs up and please leave a testimonial
Oct 25, 2010 | KitchenAid K45SS Classic Stand Mixer
I just got a KitchenAid INC Classic model K45SS-won't turn off
Yes it sounds like it should be easy to fix. You will need to establish what is preventing the speed control mechanism from moving as it should. It sounds mechanical. Try removing the back cover and checking what moves (or doesn't) when the speed lever is moved.
Jul 03, 2009 | KitchenAid K45SS Classic Stand Mixer
K45ss kitenaid mixer surges at low speeds
Hi. Go to mendingshed.com and download their free Kitchenaid Service Manual. This valuable document will help you to tune up your mixer, and covers the K45SS model. They also sell kitchenaid parts.
Go to kitchenaid.com and search for a parts manual for your mixer. Enter your model# thusly k45sswh.
If this solution has assisted you, please rate it. Good luck! ricardok45.
Apr 12, 2009 | KitchenAid K45SS Classic Stand Mixer
Need whip for model k45ss
Hi. Go to mendingshed.com. Locate their phone #. Call and ask them your question. They will assist you. They also have a free kitchenaid repair manual on their website. Download this valuable manual as it will come in handy if your mixer ever needs repair.
Apr 06, 2009 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid classic plus mixer
Below is a link that should allow to download a manual.
Let me know if this helped by rating my resolution, or posting me for more information.
http://www.retrevo.com/s/Kitchenaid+mixer+model+k45ss?rt=tr&p=http%3A%2F%2Fforum.kitchenaid.com%2Fforums%2Ftopic.asp%3FTOPIC_ID%3D1548,
Jun 10, 2008 | KitchenAid K45SS Classic Stand Mixer
http://downloads.mendingshed.com/KitchenAid_Service_Manual.pdf here is a Service manual that gives good breakdown & repair in English with B & W photos. Can anyone who does a full download on this (16.2 mb, 32 pgs) please email me a copy. I only have dial up & connection does not stay up long enough to do a full download. Email : jesseddieus@yahoo.com or jesseddieus2000@yahoo.com . It would be greatly appreciated. Thanks & have a great day.
Jim
May 29, 2008 | KitchenAid K45SS Classic Stand Mixer
Need Kitchenaid k45ss manual
Hi. All of you should goto www.kitchenaid.com and enter your model# into the search window. You can download Operators and Parts manuals for your model. Kitchenaid does not provide Service Manuals but the parts drawings will be very helpful with disassembly and reassembly.
If this solution has assisted you, please rate. ricardok45
Apr 01, 2008 | Food Mixers
KitchenAid K45SS Classic Stand Mixer Logo
245 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
