Question about Vehicle Parts & Accessories
1995 camaro resetting the security system car wont start
  • BbyAutotech May 11, 2010
    is this the factory anti theft that you are having problems with? With the chip in the metal part of the key? or an aftermarket system
  • 144 Answers
THIS MODEL USES A "PASSKEY". THE THEFT MODULE HAS TO GET THE CORRECT RESISTANCE FROM THE KEY PELLET TO ENABLE THE FUEL INJECTION AND/OR STARTER CIRCUIT. IF THE SECURITY LIGHT IS STAYING ON WITH KEY IN ON POSITION THE SECURITY SYSTEM IS ACTIVE. THIS CANNOT BE RESET. WHEN PROBLEM IS RECTIFIED LIGHT WILL GO OUT AND CAR WILL START. THIS IS BETTER SUITED FOR A LOCAL TECHNICIAN. :( HOPE THIS INFO HELPED!
Posted on Sep 07, 2009
2 Suggested Answers
  • 12 Answers
SOURCE: anti- thief system keeps car from starting.
try locking and unlocking using key cylinder in driver's door
Posted on Jan 15, 2009
1995 Chevy Camaro will not stay running longer than 5-10 seconds
ur ignition key cylinder is worn out tripping the the security system
Jul 13, 2014 | 1995 Chevrolet Camaro
1993 camaro no secrty light wont crank
Most all mechanics pull the dome light fuse before working in the interior to avoid draining the battery.. On the 1994-95 Camaro the 20 Amp fuse courtesy light, also illuminates the orange security light in the dash cluster. If the security light is out, and your car won't start, it's because the VATS is in theft mode and you don't see it. Clean the key, if that don't work you may have an open short or broken wire in the orange jacket of the ignition (key) switch. Disconnect the harness connector and connect a matching resistor with the correct ohms of your key inline with the purple and white wires without cutting the connectors off, because you may latter need them. - Original Owner of 1995 Camaro.
Apr 14, 2014 | 1993 Chevrolet Camaro
How to reset security on 1995 camero
this hapend to mine it was a seam on the gas line in the tank it came apart or gas pump needs changed and filter
Oct 14, 2017 | 1995 Chevrolet Camaro
Battery had a dead cell i replaced it and now car wont start
Look around the dash for a light that says "security". These cars have an antitheft system that can shut off starters and/or injectors. This can be caused by low voltage or just normal wear and tear. This link explains. http://vatspasslockpasskeysecurityhelp.yolasite.com/
Sep 30, 2011 | 1995 Chevrolet Camaro
Im having problems with my 2001 3.8 v6 camaro. it wont start most of the time and when it does start it immediately stalls. i can hear the fuel pump turn on and the car turns over normal. any ideas on what...
Most GM vehicles from the mid 80's to around the mid 2000's have this problem. The problem is the "antitheft" systems that GM has been using. The number one symptom of this problem is seeing a light on the dash that says SECURITY. Read this link for info on these systems and some DO IT YOURSELF ways to fix it forever.
Effected years
1988 Camaro
1989
1990
1991
1992
1993
1994
1995
1996
1997
1998
1999
2000
2001
2002 Camaro
May 23, 2011 | 2001 Chevrolet Camaro
I have a 1995 camaro z28 5.7 that stalls out from time to time it my run for 2 days then stalls out it wont start right away, but it will start. ive replace the fuel filter fuel pump fuel regulator ait...
You might be experiencing a problem with your Vats security system. GM installed these anti theft systems on almost all of its cars in the 90's. (that little black chip in your key) They are known for turning off starters and injectors. Check out this link for symptoms, explanation of how it works, and solutions to the problem that you can do yourself. Hope this helps. http://vatspasslockpasskeysecurityhelp.yolasite.com/
May 11, 2011 | 1995 Chevrolet Camaro
95 camaro, factory alarm wont let me start the car what
U will need to bypass the factory VATS (vehicle anti-theft system) system, it is very simple and all you need to know is at the web page link below.
http://vats.likeabigdog.com/
Jul 20, 2010 | 1995 Chevrolet Camaro
My camaro wont start. the battery is new and i replaced starter..
mabe the switch that operates to show it is park is faulty
Feb 16, 2010 | 1995 Chevrolet Camaro
Starts but wont stay on
got a security system in there?
Mar 15, 2009 | 1995 Chevrolet Camaro
Anti- thief system keeps car from starting.
Jan 13, 2009 | 1995-1997 Chevy 1500 Truck Ignition...
Vehicle Parts & Accessories Logo
907 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
