There is a white 3cm space down the middle of the page. Shaking the cartridge will only work for one page. The rest of the printing is normal.
    Brigadier General:
  • 4,088 Answers
The cartridge probably needs to be replaced.
Posted on Sep 07, 2009
Black lines
Replace the toner cartridge :-)
Apr 05, 2014 | HP LaserJet 1020 Printer
Printer ignores white space at beginning of document
by dragging the black bar on the left with your mouse when
the cursor changes for resize
Nov 30, 2007 | Office Equipment & Supplies
Our Hp 5550 prints thin vertical black lines on high res images. They are evenly spaced (3cm apart on an A4 print).
This is caused by a damaged drum. The drum is the long metal cylinder inside the toner cartridge. You will have to replace the hold cartridge. You should be able to flip a plastic cover on the toner and see the drum. If it has black toner lines then it usually means the drum is scratched and there for toner fills the scratch and produces lines.
Replace the print cartridge (toner cartridge) and the lines should go away.
Jul 19, 2011 | HP LaserJet 5550 Printer
Our HP Laserjet P4015N is printing funny. When printing out a column of information, it will continue to print the information above it, in the white space below the column of numbers in a grey tone. I...
Hell
The "ghost print" you are getting is caused the fuser, even with 60% life left. We have seen this type of wear pattern happen if you print more on one side of the page than the other, or print darker images than standard use would be. The fuser heat roller is coated with Teflon to prevent the toner from sticking to it but when the coating gets worn down you get the ghosting like you have. You can replace just the fuser or you can get the whole maintenance kit and just keep the pickup rollers for later use. If you open the back of your printer so you can see the fuser you should be able to see the heat roller and most likely you will notice a worn area that is not the same color as the rest of the roller.
I hope this helps, if so please rate our solution.
BuddyMc
Feb 04, 2011 | HP LaserJet P4015N Printer
There is no data in the middle of the printed page
Your toner cartridge is out of toner. Replace it!
Sep 17, 2009 | HP LaserJet 1020 Printer
White space in middle of faxes sent or received
Printing irregularites on sent faxes are due to spots or a dirty scanner.
Spaces on received faxes are due to a dirty drum, corona wire, or a failing or improperly installed toner cartridge. A new cartridge should be gently shaken back and forth sideways prior to installation.
Jun 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
I have just tried to install new (HP) printer cartrige
Clean the static strip on the printer, details should be in the manual on how to do this. Also verify that your imaging unit and fuser are in good condition.
Mar 05, 2009 | HP LaserJet 1005w Printer
A white strip in the middle of a printed page
You should first try a new toner. Ther may be something stuck inside the toner cartridge. You might also try cleaning out the inside to be sure there isn't something blocking the light flow. If it still continues to happen there may be a problem with the fuser unit.
Dec 13, 2008 | HP LaserJet 1022 Printer
Spaces in printed lines
then the problem is in cartridge replace them asap, no other way around it,
cheers
Sep 04, 2008 | Dell 922 All-In-One InkJet Printer
Canon PC941 Copier: Wide white bar down middle of copies
Try replaceing the cartridge the toner has run out.
Any problems please get back to me.
Thank You
Mar 25, 2008 | Canon PC-940 Black and White Copier
22 people viewed this question
k24674
