Question about Mintek DVA-8700 System
PAL, NTSC Help! I live in U.S. and accidentally clicked the PAL switch on the TV set-up and now it doesn't talk to the TV so I can't see anything to find my way back to this screen and click the NTSC back on. I've tried to 'blindly' click through the correct sequence with the remote control to no avail. Any suggestions how I can make this usable again? Thanks, Ron Same problem!!!
    President:
  • 1,950 Answers
If all else fails, you can use a Univeral digtal PAL to NTSC / NTSC to PAL convertor. Could you please tell me where you have switched the system to PAL...on your TV or DVA unit? If it's on your TV could you please tell me the model number of your TV.
Posted on Jan 02, 2008
  • Damen Wong
    Damen Wong Jan 02, 2008
    You mean you changed the system from NTSC to PAL and you don't mean the region code...right?
    Scholar:
  • 103 Answers
Try this:
Power on with No Disk in player.
Open player
Now with the remote control:
Press "SETUP" button
Select "PREFERENCES" and press "ENTER"
Input the password "2 2 2 4 4 3"
Press the "LEFT" and "DOWN" button
The screen should now show "REGION CODE 1"
PRESS 10/0 AND THEN PRESS SETUP TO EXIT
If that doesn't work try these different codes (suggested by mintek) 242112, 221441, 224441, or 245512, 251131, 251251, 255135, 253135, 251251, 251422, 212425
you enter step 4 (Each Number Separate) and step 5 (Left Arrow then Down Arrow) in one fluid action. There is no prompt to enter the code once you reach the preferences menu. You can only reach that menu when there is no DVD in the actual player.
1 Before powering on, open the lids, remove any media and leave it open so you can actually see the compartment where you place a disc.(this is how you get access to the preferences menu)
2 switch on unit from the side of the drive
Now on the remote control
3 Press set-up
4 Select preferences menu
5 Press play
6 Input 251131
7 Press "Left" then "Down" button
Should show region code menu
8 Select region free by hitting the 10/0 button, this will change the region to region free (ie 0)
9 Press set-up to confirm and exit.
if all else fails press 1 continuously while dvd is loading will play the dvd but you will be unable to use the remote for pause, stop, etc. you will have to manually shut down power to stop. restarting the player resets previous options.
  • 790 Answers
HELLO!!!
THESE LINKS MAY HELP U /....
DOWNLOAD THE MANUAL HERE AND CHECK OUT HOW TO KEEP DEFAULT SETTINGS!!!
http://www.retrevo.com/samples/Mintek-manuals.html
http://www.kenstone.net/fcp_homepage/pal_ntsc_conversion.html
  • 4,889 Answers
Pls tell us which tv set u have..
Posted on Dec 08, 2007
SOURCE:
Please help
Have you try: NTSC on PAL TV On • NTSC discs will play correctly on PAL-only TVs.
Off Use if your TV is already NTSC-compatible.
Many recent PAL TVs are compatible with NTSC input and so this setting can be switched off. Check the operating
instructions that came with your TV. See also About NTSC on PAL TV on page 124 for related information.
Sep 14, 2008 | Televison & Video
Colors are off
Hi!
maybe your PAL NTSC SYSTEM mode is in accidentally switch to PAL or NTSC try to re switch the PAL NTSC SYSTEM mode.
Nov 02, 2007 | Mitsubishi WD-52725 52". Rear Projection...
I just purchased a dvd player and it's showing vertical lines.
PLEASE CHECK PAL AND NTSC SELECTION....IF YOUR REGION IS PAL SELECT PAL IN DVD SETTINGS....OR IF YOUR REGION IS NTSC THAN SELECT NTSC IN DVD SETTINGS....ITS NOT A PROBLEM...JUST TRY TO SWITCH PAL AND NTSC IN YOUR DVD SETTINGS....U WILL DEFINATELY GET THE RESULT
Nov 08, 2009 | Televison & Video
Rf signal pal to ntsc
there should be an option in your picture settings menu
Jul 23, 2009 | Polaroid FLM-1514B LCD TV
Help! I live in CANADA and accidentally clicked the PAL switch on with my remote control the home theater system model DVA - 8700 set-up and now I can here the sound but I can't see anything to find my way...
Pls try doing a reset by unplugging the unit from the mains for a couple of hours (preferably overnight).
Alternately, you can try hooking it up to a video monitor (capable of RCA/Composite or S-video), a movie camera (switch to external video source), or another TV that is PAL/NTSC capable while configuring it back to NTSC settings.
Additionally, you can try simply pressing the NTSC/PAL button with a few seconds interval while playing a known good NTSC disc.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 24, 2008 | Televison & Video
NTSC to PAL
I am afraid this reply is too late, but if you happen to stop by the site: The set has a built-in NTSC tuner, with no PAL tuner, as it is advertised in the US. So the answer is: No, you can't do PAL.
But if your manual says it has the PAL tuner, then you should be able to find a switch on the set or a button on the remote to change over to PAL.
Jan 09, 2008 | LG 17LX1R 17 in. HD-Ready LCD Television
PAL, NTSC
Can you somehow press on "DEFAULT SETTINGS"? Do you have manual for your TV? Which model you have?
Sep 28, 2007 | Mintek DVA-8700 System
Pal/Ntsc playing problem
is your tv is the same tv that u playing before? coz according to you if u play ntsc there is no problem. if ur tv is multisystem, u can change the tv system menu to auto, but if not u cannot watch coz ntsc tv only accepts ntsc signal.
Jan 08, 2007 | Pioneer DV-373 DVD Player
Problem during 'setup'
I had the same problem too now my TV screen is all black and I can't do anything. can someone help please. thanks
Dec 13, 2006 | Cyberhome CH-DVD 300 DVD Player
186 people viewed this question
Top Mintek Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Mintek Audio Player and Recorder Expert? Answer questions, earn points and help others
