Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Kud101 diswasher heater element
Manufacturer sent us replacement heater element for kud101il dishwasher, we replaced it. can't really tell it makes any difference. What does it do?
  • 27 Answers
The dishwasher will heat the water to a temp of aprox 140deg if the heater is not working then the dishwasher will not shut off because it has to heat the water to a point where a thermostat will close during the heating time the dishwasher time stops advancing, also heater is used to heat the air for dry cycle
Posted on Sep 07, 2009
I have a bosch diswasher which is quite a few years old no sgs3042gb/03. the water isn't getting hot and it doesn't dry?any help will be grateful
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 13, 2011 | Bosch Dishwashers
My diswasher is not wash
There are many probable causes of failure .
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishwashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher
Nov 03, 2010 | Dishwashers
The soap does't disolve just lies in the bottom of the diswasher, I've just used the diswasher about 10 times, brand new
heatman101
Sep 18, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
My kenmore HE diswasher, model number 665.1312 won't dry
is your heating element was working?,if working check the blower if working too.
Jun 04, 2010 | Dishwashers
Early in the wash cycle, my Bosch diswasher makes a chirping soun
yes the problem from the heater.
if the sound coming from boiler heater means
1)scaling on the boiler tank(tank to be cleaned).
2)check any loose connection on the heater wire.
Jan 09, 2010 | Bosch Dishwashers
Kitchenaid Diswasher Model kudpo1iilbl1
i am assuming you mean model # KUDP01ILBL1
no they are not prone to breakage unless thumped or subjected to really hard acidic water..
part comes with electronic control
8194200 - Heater Kit
$75-80
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | KitchenAid Dishwashers
Error code on my bdw13 dishwasher
Turn off the water and electric!
Its really easy to change the heater element, once you have taken out the dishwasher!, remove the bottom panel and remove the wiring to the element, slacken off the nut under the electrical contacts voila!, also it may be a faulty thermostat that you cannot reset and has to be replaced, I would do this at the same time, as again its easy with the bottom off.
May 03, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Ge dishwasher not drying
1 make sure heated dry is on.
2 run your cycle and when it says drying open the dishwasher. see if it has steam coming out.
3 give me your whole model number.
4. if heater is not turning on then you may have one of three issues.
1. Bad door switch
2. Wire off element or bad thermistat
3. No power going through the control. to the heating circuit.
Jan 07, 2009 | GE ADW1100N Built-in Dishwasher
Jennair dishwasher jdb8910aww
Start by puting timer in heat dry for about 4 seconds and see if element got warm. If so check you rinse aid and make sure it is full. I like the turbo dry made by jet dry. If it is empty, this is your problem. about the smell, you would use a cleaner such as diswasher magic made by GE. If element did not get warm, put unit on heat dry and and test voltage at the element. 120 volts present replace element. if not check voltage at thermal fuse for 120 volts. If no voltage there replace timer.
Jul 26, 2008 | Jenn-Air 24 in. JDB8910 Built-in...
Dishwashers does not dry most dishes even on longest cycle?
make and manufacture would be helpful in trouble shooting for you
Mar 10, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
295 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
