Question about Mitsubishi WS-55311 55" Rear Projection Television
Where are the fuses located on a HD1080 model WS-55413?
  • mah1456 Sep 07, 2009
    According to the self diagnostic I performed when the power button would turn on for 3 seconds and shut back off, its a short protection error code. Reading the solutions on this website, I understand that to mean a fuse is blown. I've taken the back panel off but can't see anything that looks like a fuse.
  • SD Tech
    SD Tech May 11, 2010
    What is the problem with the TV? it has several fuses................
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
These sets use pico fuses ---a 2-2 code usually means one of the convergence chips is shorted and has taken one or both pico fuses out that protect the chips--set detects no voltage and shuts set down instantly--this model uses 2 STK-394-250 CHIPS---I can send you a photo of what the fuses look like--if you find either or both bad--you need to replace the chips--if you just replace the fuse(s) it will just do more damage.
They are not glass fuses--the set you have is a V22 chassis and the chips are location numbers: IC8C01 AND IC8CO2.
etower.766@netzero.net
Posted on Sep 07, 2009
Its a mitsubishi ws-55413 projection tv. the tv stopped receiving the remote funtions.
Have the remote tested alone--all shops can do this and if it tests good suspect the remote receiver in the set (usually is dead center behind the screen in the middle above the lens.
May 19, 2012 | Mitsubishi WS-55413 55" Rear Projection...
Mitsubishi Medallion 1080 WS-55413 - colors not aligned
There is no "reset" as the set has in the customer and tech menus ways to attempt to manually adjust this.
under convergence in the customer menu select advanced and follow the instructions on the screen.
If Red or Blue or Green are skewed and will not adjust it means one of the two STK-394-250 CONVERGENCE chips this set uses is bad.
Depending on where you buy them they will range in price from about 12 dollars each to nearly 35 dollars each.
Let me know what you find; this may or may not be a do it yourself repair as some real expertise is required to correctly get at and replace the chips.
SD TECH
May 11, 2010 | Mitsubishi WS-55413 55" Rear Projection...
The audio on my Mitsubishi model WS-55413 just went completly out
was to little info .... is it on all inputs, if you turn up the sound all teh way do you hear hissing from the speakers....
have you reset you cable box i go out on at less one call a mounth that no sound is the cable box
Feb 15, 2010 | Mitsubishi WS-55413 55" Rear Projection...
Where are the fuses on the mitsubishi ws55413
THERE ARE ALOT OF FUSES ON THIS CHASSI THEY ARE CALLED PICO FUSES GOOGLE THAT FUSE
Feb 10, 2010 | Mitsubishi WS-55413 55" Rear Projection...
Mitsubishi WS 55413. Ongoing rolling screen.
First check for the coolant/fluid leakage from the picture tube on to the signal board. Wipe it with paper towel and dry it will the hair dryer. I hope there's no corrosion yet.
Dec 28, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55413 timer light flashing. tv will not power on
you have some caps that have failed in the dm module
that will have to be replaced to correct the problem
if your know how to change them and have the tools the caps can be obtained through most electroinc parts suppliers
there 1000mfd 16v we increase working voltage to 35WV
if you can change them let me know and i can give you locations on the board and the dm stands on the right side of chassis at rear
Oct 24, 2009 | Mitsubishi WS-55413 55" Rear Projection...
TV wont stay on
you may have a convergence problum if your convergence ic,s are shorted, you will need to check the convergence fuses in the power supply.
May 06, 2007 | Mitsubishi WS-55413 55" Rear Projection...
Open Questions:
See all Mitsubishi WS-55311 55" Rear Projection Television Questions
Mitsubishi WS-55311 55" Rear Projection Television Logo
235 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
