Question about Whirlpool Calypso GVW9959K Top Load Washer
My drain pump was clogged with parts of a rug. I took it off and apart and got it all cleaned out reinstalled everything now when I try to turn it on the LCD read out says CE. I don't have the manual what does that mean?
  • 3 more comments
  • tomaslaw0503 Sep 07, 2009
    I looked for the make and model number can't find it. Where are they normally located?
    This what I found.
    MOD-GVW9959KQ2
    SER-CR2773492
    TYPE-170
    Does this help?
    Sorry Lee,
    The make is a Whirlpool Calypso top loader
    Thanks, I will check.
    Thanks Lee, That did it I didn't reconnect some wires.
  • 4,472 Answers
Do you have the make and model number of the unit? Once I have this information I will be able to assist you further.
Thank you,
Lee
Posted on Sep 07, 2009
  • 1 more comment
  • Lee A.
    Lee A. Sep 07, 2009
    Usually you can find it on the back of the machine.
    Thanks,
    Lee
  • Lee A.
    Lee A. Sep 07, 2009
    Communication error. This means the two boards are not communicating. Being that you have just done some work on the machine check all the wiring connections. Hope this helps.
    Thanks,
    Lee
  • Lee A.
    Lee A. Sep 07, 2009
    I am very glad to hear that. I believe you should have the option to accept my solution.
    Thank you for using fixya and have a great day,
    Lee
Washed a small bath rug in the machine. The piece of rug said it was washing machine safe. The rug broke apart as I was washing it and now the washing maching will not drain. I have to open the bottom...
This becomes a long drawn out process in which you have to remove the pump and the entire drain line and wash all the backing out of the machine also you have to remove the lines that go from the tub to the pump as well and even after you finish cleaning out the drain system you still will have more pieces stuck inside the tub area that you have to clean out as well. Easiest way take the machine outside or to an area you can use a hose on the unit where after you disassemble the entire pump area that you can wash the tub out of all the small pieces of the rug backing I had the unfortunate repair of doing this to someones rubber backed rug cept it took all the rubber off the back of the rug. It took about 3 hours with hooking and rehooking the drain lines and unclogging them over and over due to this unit I was working on was in a basement and no access to a hose If you have any further questions message me back and please remember to rank how this opinion has helped it allows me to continue helping others in similar situations in the future Thanks again Rick
p.s do this repair yourself a repair technician would charge about 200 to repair the unit due to the amount of time
Apr 28, 2011 | Samsung Washing Machines
Tip
Fisher & Payel washer wouldn't work
A repairman examined my washer and told me I needed a new drain pump. The washer wouldn't drain the water out after filling. I suggested he check the drain because I had recently washed a rug and suspected the drain as clogged with lint. He took out the drain pump and diagnosed that I needed a new pump. After he left, I watched a youtube video on this problem. They man in the video carefully showed how to remove the drain pump. I then removed the drain pump myself and found an inch size ball of lint that was clogging the drain pump up inside. I removed the lint and reinstalled the same pump and the washer has worked fine ever since. I learned this after an expensive service call fee and he wanted to charge me another $150+ for new drain pump and installation.
on Jan 22, 2010 | Fisher and Paykel GWL11 Top Load Washer
Clogged up. Washed rubber backed rugs and the rubber shredded. It wont drain. How do I clean it out?
¡æThe drain pump filter
The drain filter collects threads and small objects left in the laundry. and rubber from rugs
Check regularly th
1. Open the lower cover cap
with a tool such as coin.
Turn the drain plug to pull
out the hose.
at the filter
Unplug the drain plug ,
allowing the water to flow out.
At this time use a vessel to
prevent water from flowing
onto the floor. When water does
not flow any more, turn the
pump filter open to the left
is clean to ensure smooth running of your machine.
Remove any foreign objects from
the pump filter . After
cleaning, turn the pump filter
clockwise and insert the drain
plug to the original place.
Close the lower cover cap
Dec 20, 2010 | LG WM-2277HW Front Load Washer
Wash machine won't drain. I tried to clean a very old dirty rug and when I opened the door, it was shredded. I cleaned it out but, it wont' drain the water out.
your pump / drain in the bottom is clogged up turn the machine over after taking out all the water and then !! remove the pump and clean it and the drain hose
Jan 19, 2010 | Washing Machines
Washed a bathroom rug, which fell apart in the
The little pieces off of the bottom of the rug are clogging up the pump. Clean out pump.
Jan 15, 2010 | Dryers
Maytag Neptune won't drain
your pump is clogged with matt mud...
remove the back panel
the pump will be right on the left
two hose clazmps
you will loose a gal water
1/4 turn on the pump it will now come out
disconnect the two wires...
clean the pump out and try to clean out sump hose and drain hose
sump from tub to pump
darin pump to drain
reassemble your done
Oct 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Wm2688h will not drain anymore.
You need to take a flashlight and look into the suction port on the pump. Make sure the pump is not clogged and check the pump impeller. Make sure that no blades are broken or missing and the impeller should spin freely. If any blades are missing or broken on the impeller or if it will not turn freely, the pump will have to be replaced. Hopefully, it is just a clogged pump. Hope this helps and best wishes.
Aug 08, 2009 | LG WM2688HWM TROMM SteamWasher
Help!
When the backs of the rugs fall apart, they tend to bunch up in the pump and form a pasty substance that keeps the motor from turning. Since the unit knows there is more water in there than what should be, it tries do keep draining even when the unit is turned off (the buzzing noise you're hearing) The first thing you need to do is remove the lower front panel (the screws are on the botom side of it. Once you take those out the panel (with a little wiggeling) will come down then out. On the bottom of your washer, you will see a white piece of plastic. This is your pump where the remanants of your rugs have ended up. I would recommend a large bowl, towels and a wet/ dry vaccume at the ready before the next step. On the front of the pump, there is a knob whcih you turn counter clock wise to open. I recommend putting the edge of the bowl under the pump while you SLOWLY turn the knob. DO NOT OPEN IT ALL OF THE WAY INITALLY! Drain water out a little at a time. Once your bowl is full, screw the knob back in, dump the water and repeat until all of the water is out. Once the water in not flowing anymore, then open the knob fully and pull it out. You will see a white clump of the rub backing.Once you dispose of it, fill then drain your washer again. More remanants of the rug will wash into your pump. Continue this fill, drain pump clean procedure unit the trap comes out fairly clean (it will take many loads to get the last bits out from everywhere inside your washer)
Jun 17, 2008 | GE WBVH6240F Front Load Washer
Kenmore Energy Washer front load - about 5 - 7 years old
Hi mommo2,
I really hate those little rubber pieces that come off of those rugs, they really gum up everything. Just for future reference try to wash those outside with a water hose and a scrub brush. It will save you lots of money in repairs.
As for your current problem try to get as much out of the tub as possible. Then you will have to remove the small kickplate on the bottom of the washer. Get you some towels and a maybe a flat pan to catch some water. The panel will have a few screws around it that will need to be removed. Once you have removed the panel you will see your pump. The front of the pump has a filter that can be unscrewed and removed for cleaning. Unscrew the filter and get ready to catch some water. Maybe as much as a couple gallons. Once you have cleaned it out put the filter back in the pump and leave the panel off. Run the washer throught another cycle and clean the pump out again. You may need to repeat this several times. Hopefully this will solve the problem, if you still have draing issues you could have a clogged drain and for that you may need a plumber. Well good luck to you and I hope I helped. Mike Anderson mca0824@aol.com
May 02, 2008 | Kenmore 43142 Front Load Washer
Clogged pump on Affinity Washer
Exactly the same problem. Washed a small area rug that appeared to have pretty much disintegrated. Machine would not drain. Got the same e 20 code. Checked the drain hose, and it was fine. Reamed the house drain just to be sure. Drum appears to have drained, but now the motor runs, and no water enters the machine. Both water hoses are flowing. No further error codes. Nada.
Apr 20, 2008 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
12 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
