Projection tv NO AUDIO - Televison & Video
  • ceejplaneswa Sep 07, 2009
    projection tv magnavox MODEL 60P8342 SET HAD A CONVERGENCE PROBLEM REPAIRMAN REPLACED SSM BUT NOW NO AUDIO
  • ceejplaneswa Sep 08, 2009
    MAGNAVOX MODEL#60P8342
  • 3,741 Answers
First try reset To reset the audio, go to the on-screen menu and select the setting for audio and make sure it is on stereo rather than SAP (second audio channel).
if still the same problem after reset then its audio amplifier problem as it has lost its connection to power supply so you get video but no andio.get the audio amplifier checked and replaced.many times it gets internall loose so no sound comes.also remove all the wires connected to the tv wait for 10 mintes then reconnect again n checkout.
the parts for replacement can be ordered from
www.radioshack.com
or from at
www.shopjimmy.com
thanks.please keep updated.please do rate the solution if helped.thank you for using fixya
Posted on Sep 08, 2009
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
To help you I need to know Brand and model number of this TV
Posted on Sep 07, 2009
  • SD Tech
    SD Tech Sep 07, 2009
    This set should have a small signal module that plugs into the Small signal board--it controls everything--I have seen it cause no audio or remote problems--have whoever replaced the large board check to make sure they got the small board plugged in correctly--if it has a small signal module that plugs into the small signal board and they did not get it just right---this could be your problem
    Brigadier General:
  • 4,090 Answers
The brevity of the information is not too helpful.
Did the sound just stop
was the TV off and was working before ( when?)
Is there a series of flashing LED on the On/Off button
But a wild guess is that your controller board on the audio chip has faiiled
I would like to connect my my hp laptop to my Sony Grand WEGA KDP-57WS550 57 in. Rear Projection HDTV-Ready Television to watch netflix
You need to connect your PC to either your TV or your receiver. Also, if you have XBox, you can watch Netflix through it (thought I'd suggest, just in case).
Take your PC (or take a photo of your available outputs from your PC) and a photo of your available inputs (on your TV or receiver) to Best Buy or similar computer store. They can help you learn which connections you need.
Most likely you'll need a DVI to HDMI cable for video, and maybe a separate audio cable from your headphone connection on your PC to your TV (or receiver). You'll only need a separate cable for audio if your HDMI input on your TV does not support audio.
I am going through this same problem with my TV connecting Apple TV. I am checking now whether my old rear projection tv's HDMI input supports audio (same as yours). I've connected Apple TV to my rear projection TV. I have video, but no sound. Either my TV doesn't support HDMI audio, or I need to change a setting on the TV to enable that sound to work. If the TV does not support HDMI audio, I will need to connect Apple TV directly to my receiver via a digital optical cable for sound.
Hope this helps.
Jun 22, 2011 | Sony Grand WEGA KDP-57WS550 57" Rear...
How to hook VCR/DVD player to our TV? 60 inch Projection TV
It's easiest to hook up the rca plugs, the ones colored red, white and yellow. Run the audio and video out of the player to the audio and video in jacks on the back of the tv.
Jan 02, 2011 | Philips Magnavox 9P6034C 60" Rear...
Tv has audio but no picture. tv was working perfectly fine last night with audio and pic but now no picture
kindly check ur video cable if ur r useing audio/video cables for you tv
if not u need to check for ur tv tube
Jun 04, 2010 | Mitsubishi WT-46807 46" Rear Projection...
Audio stopped working with my sony kdf-42we655 tv.
Reset the Audio back to factory setting.Should work, some wrong setting in ur setting.
Jan 13, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have no audio on my RCA Scenium rear projection
Replace Audio output ic. Make sure you do not have sound turned off.
Sep 28, 2009 | RCA Televison & Video
No Sound on my rear projection TV...audio plays
Check the audio amplifiers IC of the tv
Aug 11, 2009 | Televison & Video
No tv audio through dvd home theatre?
CHeck your TV's settings. Assuming that you are connecting to your home theater through the rear "audio out" jacks. You'll have to go into the tv's audio setup to tell it that you want to use external speakers.
Jan 30, 2009 | Zenith D52WLCD 52" Rear Projection...
DLP Projection tv, Models WD-52631,57731,65731. The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv...
DLP Projection tv, Models WD-57731, The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv system shuts down. I reset it a few times but that doesn't change the problem
Jul 26, 2008 | Televison & Video
Surround sound
to connect audio from tv to receiver.Use the monitor out(audio) from tv to receiver .The tv will only put out left/right audio .Also when using the audio out from Sony tv sometimes you cannot use both the internal speakers from tv and audio out from tv to receiver at the same time..Make sure audio is set up on TV menu for audio out..
Nov 20, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
