Question about RTO Gas Motor Scooter
Fuel bowl on my 50cc scooter keeps empting and killing the engine I keep adjusting the carb fuel screw on the carb but I still have the Fuel bowl empting. Does anyone know if I need to turn the fuel screw to the right or left or what I need to do to the carb?
  • 636 Answers
It has nothing to do with the adjustments, what is going on is your float is stuck in the carb , you will have to take the float bowl off , float is sticking than you will have to try and clean the needle and seat valve.
Posted on Sep 07, 2009
Testimonial: "Thankyou The scooter is a jonway and it is new should I be having this type of problem. Do I need and expert to preform the sticking float correction?"
Have a Tao Tao Moped 49cc. Runs ok but when I accelerate it dies. What are options
Hi, Richard and the usual suspects are:
1. Idle port, transfer ports, slow air jet clogged.
2. Idle adjusting screw set too low.
3. Air fuel mixture adjustment too lean.
4. Pilot/slow fuel jet clogged.
5. Faulty accelerator pump.
6. Float level too low.
7. Float bowl contaminated old fuel, water, dirt, rust, etc.
8. Carburetor bowl vent line clogged/blocked/pinched.
9. Fuel line to carburetor kinked or pinched.
10. Fuel filter clogged.
11. Intake manifold leak.
12. The gas cap is not venting properly or fuel tank venting system blocked.
13. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
14. Needle and seat stuck closed in the float bowl.
15. Multi carburetors not in sync.
16. Faulty fuel pump.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
TaoTao 50cc scooter won run good Help please
Scooter dies when adding throttle It Is The Ride
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
TaoTao 49cc Scooter Parts
TaoTao ATM50 A1 Owner Manual
Oct 09, 2017 | Motorcycles
My 50cc scooter(chinese) hesitates at full throttle, almost like it wants to stall and then it kicks back in. Could this be a problem with the carburetor valve?
Hi, Randy and the usual suspects are:
1. Inlet system air leak.
2. Enrichener valve not seated or leaking.
3. Damaged or restricted fuel tank vent system.
4. Restricted fuel supply tract.
5. Dirty or damaged air cleaner element.
6. Plugged bowl vent or overflow.
7. Worn or damaged needle or needle jet.
8. Vacuum piston assembly malfunction.
9. Loose or plugged main jets or passages.
10. Improper float level.
11. Accelerator pumps inoperative.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Chinese Scooter Club View topic Hesitation On Acceleration
Why is the engine bogging under acceleration Suzuki FA50 Moped
scooter keep bogging down under throttle
1 HOW TO FIX Most common MOPED Carb problem
How to tune in scooter carburetor
Mar 24, 2017 | Motorcycles
My 50cc Scooter has a brand new carb but gas is leaking from overflow ???
Hi, Kim and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Carburetor is leaking gas out of overflow tube need help
Carburetor Carb Leaking Gas How to Fix Repair it Motorcycle Honda DIY...
http://www.49ccscoot.com/manuals/Hyosung_SF50_Service_Manual.pdf
50cc scooter parts QMB139 49cc 4 stroke parts moped parts QMB139
http://www.yamaha-motor.com/assets/service/manuals/2008/zuma_lit-11626-21-15_1548.pdf
Jan 04, 2017 | Motorcycles
I need to know the proper tuning of ucal mikuni carburetor with mixture adjusting screw on bottom of cabr (beneath float bowl), an idle adjust screw and pilot screw (hopefully pilot fuel screw since s
Why did you need to clean the carb? Routine servicing of the aircleaner would keep the carb clean for life. The pilot screw should be 1.5 turns out approx. with a small adjustment either way. Idle speed is set to a smooth low idle.If this doesn't fix it have you got something in the carb not replaced correctly? The float needle/float assy? How did you clean it? Have you introduced fluff/dirt into the carb and did you blow it clean with an airline?
Oct 09, 2014 | Motorcycles
50cc Scooter won't rev up, Keihin PD18J carb
my 50cc scooter will idle at first and rev very well but wont idle what can this be
Jul 08, 2012 | Motorcycles
My yamaha 50cc moped struggles for power on a cold start,what could the problem be
Hi, Rachel797 and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on blue links below. Good luck and have a wonderful day.
Scooter Troubleshooting Scooter won start All about Scooters
http://www.scootertherapy.com/startinghints.html
Yamaha YQ50 Service Manual
OEM parts for Yamaha
YAMAHA AEROX YQ50 Owner Manual
Apr 25, 2012 | 2006 Yamaha Aerox Race Replica
Generator not running
This sounds like a jet is plugged, if fuel is getting into the bowl. You need to take apart and blow out all of the jets. (The secret on the adjustment screws is BEFORE ANYTHING, measure EXACTLY how many turns clockwise, until the screw (jet) bottoms out. Then you can get back to an adjustment that is at least close, when you're done blowing everything out.) Pull the carb, use spray carb cleaner and blow all passageways out... remove any particulate matter you find....
While there, also clean the inlet (float) valve, but now with cleaner, if it is a rubber looking seal area. You just want no chunks of foreign material.
Nov 24, 2011 | Electrical Supplies
On a kazuma 50cc engine carb adj screw location
The lower of the 2 screws is the fuel/ air mixture- the upper screw is the idle adjust screw
Jan 22, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
Gilera runner 50cc wont start
Don't do the gas down the spark plug thing. It's a bad idea. Do the following >
Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetor. There should be a screw on the lower side or bottom of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the idle screw and the air screw on the outside throat of the
carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward. Put the rest of the
carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road.
Please rate this solution. Thanks!
May 25, 2009 | 2005 Gilera Runner VX 125
Quad bike keeps cutting out
ALWAYS have a fire extinguisher on hand when working on carburetors.
Drain the carburetor. There may be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward. Before putting the slide back in the throat of the carb, move the clip on the jet needle one notch lower. Put the rest of the
May 17, 2009 | 2004 Factory bike Chrono SM 250
RTO Gas Motor Scooter Logo
823 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
