Question about Sony KDF-E55A20 55 in. LCD Television
Sony tv kdfe55a20
Lamp light in red
    Scholar:
  • 137 Answers
You have a defective lamp. Lamps are setup so that they can be changed by customer. Part Number A-1085-447-A
Best regards
CircuitCity
Posted on Dec 08, 2007
Kdfe55a20 won't turn on at all It's a Sony
which LED lights on front are on and or blinking?
If the red or others blink look to see if they are blinking a specific number of times--like red one blinking 3 times, pause and repeating--this is a error code and may indicate what problem in set is.
Apr 24, 2012 | Sony Televison & Video
I have a SONY KDFE55A20 TV. The picture and sound go blank and come back on in about 30 seconds. I get a red flashing light only if I turn the tv off and back on. It flashes 5 times and repeats. The bulb...
Sorry friend, but the only sure thing is that you're getting a lamp driver error. Odds are you're either having an issue with the ballast or your power supply can't supply the voltage needed. If you're good with electronics you can check the voltages on the power supply and try to rule that out. Otherwise you should take the set in for repair. Good luck.
May 05, 2011 | Sony Televison & Video
Tv goes black every 5 minutes or os sony wega
If tv goes black and you still have the sound you have a bad lamp.
Sep 08, 2009 | Sony Televison & Video
Sony grand vega 55" will blink green for three times than red blinking under the power light. nothing comes on no sound, no picture and no fan's are running. Tried to change the bulb, power board...
Your problem is your thermal fuse.It is located around the bottom of the compartment that houses the lamp. You will have to remove the lamp and take the bottom back panel off. Then you will have to remove the fan. I ordered the thermal fuse so I would know what I was looking for when I started to replace it. If you take your time and are patient enough you can fix it yourself. I fixed mine and it's working great.GOOD LUCK!!!
May 15, 2009 | Sony KDF-E55A20 55 in. LCD Television
Replaced lamp in my sony55 inch tv still have lamp error 1
hello, if your still getting the lamp error then your lamp cover is'nt on right i'ld suggest taking cover off then re-installing it if the t.v. is'nt reading the lamp cover then it'll give you this error after re-placing the lamp, also take the lamp out and re-connect make sure the 2 prongs are on the lamp tight.
Mar 31, 2009 | Sony KDF-E55A20 55 in. LCD Television
Sony LCD Projection TV turning OFF.....help!!!
Look carefully at the front lights. Usually when these sets shutdown they have a blink code on either the standby light or the lamp light. Update this with those counts. In the meantime, you may be seeing a problem with heat. If the lamp area gets too hot, the set will shutdown the lamp. Once the area is cool again, the lamp will fire.
Update this and we'll hopefully fix the both of them.
Dan
Apr 09, 2008 | Televison & Video
Sony kdfe55a 20
2 YEAR IS TIME TO RPLECE LAMP
Mar 30, 2008 | Sony KDF-E55A20 55 in. LCD Television
Where is the thermal fuse located and how can I replace it on a Sony Grand Wega model KDFE55A20?
It's actually pretty simple to replace.
Go to
http://www.agoraquest.com/viewtopic.php?topic=31806&forum=70
and request the troubleshooting package. It has step by step on how to replace the thermal fuse and where to get the parts.
No power RED Standby LED flashes 6 times/KDF55XS955, KDF60XS955, KDFE55A20, KDFE60A20
Mar 27, 2008 | Televison & Video
Sony KDF-E55A20 55 in. LCD Television Logo
119 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
