Question about Toshiba 26LV610U LCD TV
I have 5 channels that have no sound at all and 1 channel that is now playing in spanish
    Habit-Forming:
  • 108 Answers
Your SAP ( second audio programing ) is turned on. There is either a button on the remote or in the audio section of the menu there is a way to turn it off. If you still have the user manual it will tell you how to turn it off.
Posted on Sep 07, 2009
  • 93 Answers
Go to your menu , select audio, turn sap or second audio off
3 Suggested Answers
  • 208 Answers
SOURCE: one channel in spanish
Turn off the SAP and will correct the problem.....
Posted on Feb 05, 2008
freetek
  • 5568 Answers
SOURCE: model LD 200 EMB
This may sound stupid and not help anything but I would change the batteries in the remote first; that's the simplest possibility.
What the set is doing is selecting a function, the first is 'Auto tune' during which the set is looking for usable channels on the 'off air' (antenna) input. I suspect you have cable or satellite meaning that there will not be any signal at the antenna input and the set just looks at each standard channel frequency and then gives up.
The language thing; this is curious but also a sign that it has switched to the menu mode where you also need to be if you want to do a channel search on purpose.
If the remote is not at fault, then it is an internal problem you will not be able to repair on your own.
The circuitry that interprets the received infrared signal from your remote has started producing noise or the output from that after a decoder, has gone noisy and is just choosing functions on its own.
The blue screen is what most sets use as a default when no signal is found at any input.
Unfortunately. Emerson, RCA, Zenith and a few others are US names we once trusted but now have been acquired by Asian manufacturers who are building junk with labor pulled from the fields to assemble high tech gear.
Posted on Aug 27, 2008
Why the sound only on certain channels and some channels start speaking Spanish?
You most likely have the SAP (Second Audio Program) feature enabled. Many shows do not have this sound track and that is when you hear nothing. When the SAP is on, it is usually in Spanish for English-speaking programs. Check your TV remote for SAP and see if you can disable it.
Oct 09, 2015 | Televison & Video
Magnavox tv converter box some channels have no sound
When you program your HD converter, it searches for all available channels in your area and you may find, as I have, channels you never knew existed. As for the audio problem, some of the found channels may be so weak that all you get is the picture - no sound. You can delete the problem channels but they are likely to pop up again on your next programming run.
Feb 03, 2013 | Insignia Digital-to-Analog Converter for...
No sound HBO chanel
Check both the set and a box if used are not having SAP engaged, secondary audio program==meant to play channel in spanish etc if available===it will blank the sound when no foreign language is present from the channel.
Dec 23, 2012 | EQD Auria EQ3288 32 in. LCD TV
Some of my channels are only in spanish, some have no sound
Look first in the menu for the set and then in the menu for a box if used:
In either place if set is set to SAP (secondary audio program) some channels will be in Spanish or have no sound.
It can be the setting in the TV or a cable or sat box if used.
Oct 23, 2012 | Mitsubishi VS-60111 60" Rear Projection...
My truflat is speaking spanish on some channels and some channels showing picture and no sound . and the when i turn stereo,mono,and sap pops up.
you have teh audio set in SAP mode. Some nits have the audio mode button on the remote. Otherwise go into the audio setup menu and choose MTS(stereo) or mono.
Apr 28, 2010 | Televison & Video
The sound on the tv is messed up
if you are using a digital sat receiver that is spanish not all the channels will come in english , ill assume that your living in spain and have digital+
for the sound problem use a scart cable then check the sound settings are set to normal
post back if your still having problems
Sep 08, 2009 | Sylvania LD370SS8 37 in. LCD Television
CT-36D12
Instead of explaining the SAP/Stereo function to you, the easiest way to get the TV back to normal is while the set is on press the ACTION and POWER buttons at the same time and hold them until the CHK screen appears. Once that does release the buttons and then press the action button again to exit the CHK screen. Your TV is now back to the factory settings and will need to have the channels programmed again. By the way the SAP/STEREO button on the remote should be near the upper left hand corner of the remote itself.
Mar 25, 2007 | Panasonic CT-36D32 36" TV
TV plays some channels in spanish
The tv may a SAP circuit fault (Second Audio Program). This circuit can mess up and cause some channels which are carrying SAP to put out the wrong language. I've seen this happen a few times. AN IC may have gotten zapped when the transformer blew. Possibly the microprocessor IC. Stargazer
Mar 03, 2007 | Durabrand DWT2405 24" TV
Some channels have no sound some are in spanish
With your remote, go into the menu, find the audio setup and click off the SAP. Thats the Second Audio Program. Some Broadcasters send a second lanquage along with the regular audio. Someone must have been looking around or playing with the remote and turned on the SAP.. Good Luck PS please do not forget to rate this thread
Oct 18, 2006 | Orion STV2763 27" TV
Toshiba 26LV610U LCD TV Logo
191 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
