Question about Refrigerators
Refrigerator condensation brand new kenmore has heavy condensation shelves walls everywhere.this is the 2nd unit after the 1st one was removed and the next day our hardwood floor was all buckeled.
  • Refrigerators Master
  • 1,606 Answers
Call the Kenmore factory service people . There is a year warrenty on all parts and labor .
Posted on Sep 07, 2009
Frost build up
Hi
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt. Determine the temperature setting. The refrigerator should be set to temperatures ranging from 34 degrees to 40 degrees, while the freezer should be below 30 degrees. Adjust the temperature setting which will naturally improve the ice buildup that's been caused by the wrong temperature setting.
Move the refrigerator away from the wall. Oftentimes, this simple action is all that is needed because the unit is not getting enough air circulation behind it. Also, some refrigerators have vents underneath the unit, which are easily clogged with debris. Clean these vents and coils.
Remove food and shelving from the refrigerator and freezer portions of the fridge. If ice build up is happening in the freezer, the drain in the freezer may be clogged. With the unit off, remove coverings to expose drain and pour hot water down the drain hole until it comes out into the drain drip pan under the fridge.
Check the condenser coils. The evaporator coils could be causing the problem of ice build up. If this is the case, professional repair is likely needed to replace the motor, thermostat or other problems within the fridge.
Check this link for a detailed idea:-
http://www.appliance-repair-it.com/refrigerator-not-cooling.html
Please get back to us if you have further query or else please accept the solution.
Sep 07, 2011 | Refrigerators
Tip
Oasis co4778r if compressor will not start
If the compressor on this case does not start install a set of gauges on unit and make sure pressures for 404a are correct for your ambient temp. at 70F you should have around 155psi on suction and discharge. if pressures are good and no power from relay on emerson board then remove bottom shelves from unit exposing evap fan/txv/coil. you will find a high pressure switch and a low pressure switch. cut wiring to both switchs and ohm them out to make sure they are closed. if one or more is open and your pressures are okay replace the switch. There are dilcores on switches so it can be done with out reclaiming if you are quick. if high pressure switch is faulty and does not open during hot pull downs the unit may trip on internal relief in compressor. 404a will run very high temp and pressure and may shut down up to 5/6 times on hps before unit suction and discharge come down. make sure condenser coil is very clean. wash with hot water and degresser if needed.
General maintence should be carried out on these units often such as cleaning the condenser. cleaning condenser pan and float check proper operation **** all dirt from pan and float with shop vac and wipe up all sluge from heater elements. remove bottom shelves to the evap area and vacuum any loose particals from inside and make sure drain is clear.
if you have product in case that is not keeping cool you may have to remove all shelves and remove back wall and vacuum dust from grates in back to get good air flow.
on Aug 03, 2012 | Oasis Structural Concepts CO4778R-E3...
We understand that your problem is: I have a Whirlpool refrigerator that has water condensing on the walls and shelves and running down to collect in small pools on the lower shelf and at the base of the...
check the door gaskets, if they are not sealing properly, it will allow warm air to enter the refrigerator. when the warm air mixes with the cold air it forms moisture and condensation occurs.
May 05, 2011 | Whirlpool Refrigerators
Water is collecting at the bottom of the refrigerator under the drawers
You may have a bad gasket, which is allowing moisture laden air to be sucked into the refrigerator. The moisture then condenses on the walls / shelving, and finds its way to the bottom.
Feb 13, 2011 | Kenmore 64802 Top Freezer Refrigerator
Model: 253-54743301 Kenmore Refrigerator\r\nlost cooling in both Refrigerator and Freezer
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Jan 07, 2011 | Kenmore Refrigerators
Condensation around refrig walls
Either the door gaskets are not sealing properly or the doors are not completely sealing. The moisture is from air entering the refrigerator and the moisture in the air condenses into water. Check your doors and gaskets for leaks or gaps.
Sep 14, 2009 | Refrigerators
Heavy condensation in kenmore fridge brand new
Call the Kenmore factory service people . There is a 1 yr factory warranty for parts and labor .
Sep 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
U-line 75WC wine cooler - rust on inside back wall
This happens when the racks get too close to the evaporator. Or bottles. You can try to use hot water but usually you will need to buy new racks for the unit.
Sep 17, 2008 | U-Line 75WC Wine Cooler
Spitting refrigerator
HI ... TRY TO FLUSH OUT THE DRAIN LINE FIRST. SOME ARE ONLY VISIBLE BY LOOKING THROUGH THE BOTTOM AT THE REAR OF THE FRIG. THE TUBE IS SUPPOSED TO DRAIN INTO A PAN DOWN THERE. THE HEAT FROM THE CONDENSER EVAPORATES IT. GOOD LUCK
May 02, 2007 | Kenmore 94499 Refrigerator
Refrigerators Logo
128 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
